ASRock K7S8X R3.0 - osnovna plošča kupiti ali ne?
PALOMINO ::
Torej omenjeno osnovno ploščo dobim novo za 9.000,00 sit, jo kdo ima morda kakšne pozitivne/negativne izkušnje z njo.
Sestavljam namreč en low-cost sistem in se mi zdi zanimiva cena...
Hvala za nasvete in pomoč.
MEDENA ::
hehe
kolega kupu 10kom v pelugu po 28€
ASRock K7S8X, R3.0, SiS746FX (DDR)
CPU Socket 462 , supporting AMD Athlon, Athlon XP, Duron
FSB 333/266/200 MHz
Chipset SiS746FX
Hybrid Booster CPU Multiplier,
CPU Vcore adjustment,
CPU Frequency Stepless Control
ASRock U-COP, Boot Failure Guard (B.F.G)
Memory 3 x DDR DIMMs, DDR400/333/266
DDR 266/200 Max. 3GB
DDR 333 Max. 2GB
DDR 400 Max. 1GB
Slots 1 x AGP 8X/4X 1.5Volt
PCI 5 slots, PCI 2.2
VGA N/A
Audio AC97 CODEC
5.1 Channel 3D
LAN 802.3u, 10/100 Ethernet LAN, WOL supported
Modem N/A
Connector IDE 2 x ATA 133/100/66/33
Floppy 1 connector
1 x SIR
ASROCK I/O Keyboard PS2 x1
Mouse PS2 x1
USB 2.0: 4 ports default on rear panel + 2 ports upgrade via header
Serial 1
Parallel 1
Game/MIDI 1
LAN 1 x RJ45
Audio I/O Line In/Line Out/Mic.
ASRock U-COP ASRock Universal CPU Overheating Protection
Other Connector CPU/Chassis FAN connectors
20 pin ATX power connector
CD/AUX/ audio in
Front panel audio connector
BIOS Feature 2Mb AMI BIOS with ACPI, SM BIOS 2.3.1, PnP
Manageability WOL,WOR
Support CD Drivers,
PC-cillin 2002,
ASRock PC DIY Live Demo,
Audio Player, etc..
Accessories Multi-languages Quick Installation Guide
Support CD
Floppy/ATA 100 cables
Form Factor ATX , 12"x7.5"
baje je OK
Realman ::
JAz tudi moram reci, montiral kar par komadov.Dela rock stabil.Ima skoraj vse kar danes rabis, soliden 5.1 zvok, USB 2.0, DDR 400,dosti PCIjev, pa se izredno stabilna je.Seveda pa ni to plata za navijalce.ZA vsakega, ki pa nima namena nic navijat, ampak hoce samo stabilnost in cenenost, pa je ziher best buy.
Malo pa lahko tudi frekvenco dvignes, ce hoces.
Smorny ::
Jaz sem si nabavil to plato za 24/7 sistem in dela stabilno. Omejuje me le 5% za dvig volžate proca, ampak sem vseeno spravil durona 1600 na athlona 2100+ pri 200 fsb. Mi je pa integrirana zaščita rešila proc pred skurjenjem, ker mi je odpadel enkrat ventilator. :\ Moja napaka pač.
Glede na zmogljivost/ceno je to prav gotovo best buy.
btw: mam že volt mod nagledan, tako da bo šlo le še navzgor :D
Ampak, če hočeš stvar totalno zajebati potrebuješ računalnik!
http://www.smorny.com/
  • spremenil: Smorny ()
jest10 ::
Tudi jaz jo imam. Super plata za svoj denar! Stabilna, dovolj hitra in tudi navijati se da kar dobro- jasno pretiravati ne moreš
Meni laufa na njej duron 1600@1860MHz, drugače se na tej plati navije do približno 1950MHz samo me ovira ram.
Smorny:
Mi pokažeš kje si našeu kaj za voltmod? Bi mi prav prišlo:D
  • spremenilo: jest10 ()
Smorny ::
Evo ti LINK
Če ne bo ravno ST L6917B, ampak en drugi, se ti ni potrebno bati, ker je po fukciji čisto isti (sem pogledal spec.).
to plato se splaca kupt, ce ne igras igrc... (ta chipset je za cca 10% pocasnejsi od kt600 in se neki vec od nf2)
za vsa ostala opravila je pa popolnoma zadovoljiva.:)
jest10 ::
Niti ne. V določenih stvareh je celo nahitrejši.
Nikakor pa ni 10% počasnejši
ne res ni 10%, ampak samo 8%.
res pa ma zadeva precej hitr IDE kontroler.
ginekolog ::
Jaz imam podobno, sem zelo zadovoljen. Sicer pa:
http://www.ocworkbench.com/ocwb/ultimat...
Forum za te plate.
Divers do it deeper.
jest10 ::
opla!
voltmodi:D
boštjan ::
zelo priporočam za office in internet
dexter_II ::
evo se ena sestavljena danes (:D hvala OZZY-u)
za 30EU dela cist cool
lepo za kak net, word...duron 1600 (zazene se tudi lepo pri 166x12 in`overvoltage enabled`,sam trenutno ne rabim)
meni zlo lepo razporejena plata, posebej kje je power prikljucek od plate, pa se taka mala je:)
edin se eno brezhibno agp4x kartico si moral zrihtat (upam da od postene osebe:\ )
Šimpanz ::
Dejstvo je da so Asrock plate v zadnjem času zelo cenjene pri nas. Dobiš solidno plato za nikakvo ceno.
jest10 ::
ASRock K7S8X lastniki, pozor!
Oddelek: Navijanje
474117 (2703) mtic
Sempron 2400+ in A7S8X-MX
Oddelek: Navijanje
332077 (1845) Hardstyle
Procesor AMD 2500+ Barton
142120 (1935) jest10
Poceni plata za Bartona 2500 ?
201835 (1497) lopov
Katera poceni plata
122076 (1891) jest10
