uiber pocas :(
uiber pocas :(
sumi ::
SMRK, SMRK, SMRK!!! Za koji k**** mam jz tok slabo povezavo = 14400 bps?!;((
Zakaj! Komu v dobro?!?!?!
No skratka moj modem je Rockwell HCF 56K Data Fax RTAD PCI! Vse je OK nastiman ampak nic ne de!:(
A je mozno, da so kle res tok slabe linije - stari kabli?!? Was kann ich hier machen? Ljepo vs prosijm za pumoc!!!:8):\:8)
Huey P ::
si mel prej večjo hitrost?
se je to pojavilo samo zdaj?
je modem nov?
..::DOOM III: The Legacy::..
sumi ::
ma to je ze skoz!;(( Sam ucasih mi skoc na 16800 bps! :) Ampak prepustnost pa nc ne skace pa pada! Downloadam lohk sam z 1.1 kilo pa nc vec!
Lahko mn:D
Modem je pac kupljen z racunalnikom! Zele bo kksn let odkar ga mam!
A nej poklicem telekom al was? bojo oni znal to obrazlozit???!!!!
Huey P ::
Kakšen modem pa maš? Vsi 56k modemi niso glih to kar naj bi bili...
McHregec ::
Včasih je rešitev v tem da izklopte V90 protokol al K56flex. Naredi reg file in napiš not naslednje:
REGEDIT4
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\MSTCP]
"DefaultRcvWindow"="4288"
"DefaultTTL"="64"
"PMTUDiscovery"=dword:00000000
"PMTUBlackHoleDetect"=dword:00000000
"Tcp1323Opts"=dword:00000003
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\NetTrans\0000]
"MaxMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\NetTrans\0001]
"MaxMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\NetTrans\0002]
"MaxMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\NetTrans\0003]
"MaxMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\NetTrans\0004]
"MaxMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0000]
"IPMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0001]
"IPMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0002]
"IPMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0003]
"IPMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0004]
"IPMTU"="576"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\MSTCP\Parameters]
"SackOpts"="1"
"MaxDupAcks"=dword:00000003
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Modem\0000]
"Default"=hex:3c,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,40,01,00,00
"DCB"=hex:1c,00,00,00,00,c2,01,00,11,00,00,00,00,00,0a,00,0a,00,08,00,00,11,13,\
00,00,00,ac,7b
"VoiceSwitchFeatures"=hex:48,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00
"UserInit"="&K3W2"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Modem\0001]
00,00,00,ac,7b
00,00,00,00,00
"UserInit"="&K3W2"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Modem\0002]
00,00,00,ac,7b
00,00,00,00,00
"UserInit"="&K3W2&"
Tole bo mogoče mal zadevo pohitril.Če pa hočeš izklopi 90 protokol pa napiš v posebne nastavitve tole: ATS32=98
Destroyer Of The Worlds.
ChiefThunder ::
Možno je, da so res tolk slabe linije. Kolega ima isti problem, mu vleče sam z 16000 b/s...
... po liniji najmanjšega odpora. ;)
sumi ::
fantje moji!:'(!
Nc ne dejla! Tist sm napisu u register pa zagnou pa use naredu pa se vedno isto!
Sej modem je pa PCI Rockwellov (pise gor)
sumi ::
aja! puzabu sm povedat (oment:))) da ma soskolc k zivi 10 metrov stran u Siski (to je sam cez progo - siska pac zravn bezigrada) kr zajetnih 6.3 kilo pr prenosu! In to konstantno, pa nima nobenga ISDN.... Navadna linija tko k jz! Aja pa ucasih mu starta kr z 20 kilo, sam se obdrzi sam kksno minuto pol pa pade na 6!8-)
Pr men pa kvecjemu zacne z 0.5 kilo ne pa 20!>:D
Elemen_T ::
Ozključ vse TEL. priključke in vklopi samo modem. Poskusi še enkrat.
Probi drug ISP npr. arnes in siol.
Kliči na telekom in prašaj kaj je narobe oz kako je z linijo na tvojem področju.
Če od tega ne bo pomagalo nič potem je nekaj narobe z modemom
KamikazA ::
No vsa stvar je verjetno v tem, da si ti priklučen na centralo preko PCM enote. To je enota, ki na eno parico priključi 2,4,8,11... naročnikov. To pomeni, da se po enem kablu pogovarjate vsi sosedi. In zaradi tega je penos "nekoliko" slabši.
Jaz ti predlagam da kutijo neseš do prijatelja in pogledaš koliko ti tam vleče. Verjeto se meli včasih dvojčaka. Uganil?
Jej, pij in kavsaj,
za večnost se ne ravsaj! F.P.
Huey P ::
sumi;
Tista zadeva z 6 kilo... Meni tud včasih piše, da mi z 20 k dol vleče - to so le Windowsove prevare...
sumi ::
TAKO JE!
ucasih je biu dvojcek! Sam sm mislu k so neki kopal pa to sranje da so tud kablovje zamenal! Ampak zgleda da sm se zmotu!!!!! Tko se lohk sam slinm pr drugih frendih, ker jim dobesedno dobr POVLECE>:D(?)
Ce pa nesem racunalo k ockatu:D v sluzbo mi pa prek isdn linije vlece 6 kilo! Juhuhuhu
Sam po pravic povedan komu se pa da to kisto skoz k fotru pa pol dumov nost?!:O
Pa se neki: a je res da ce bi atek postimal ISDN ne bi blo vecje spremembe, ker je linija pac samo do centrale, ta pa po njegovem ze skor razpada?! Reku je da bi pol vlekl cca sam 2 kilo vec! kar je zame amerika, zanga pa KOSOVO-treba bi blo skoz placvat.......:\
OZZY ::
Moja bejba ma isto dvojček in se ji na linijo poveže normalno 44000 bps. Deluje pa tudi nornmalno z isto hitrostjo kot pri men. Je pa glede na starost bloka to kar dobro. Edino, če niso linij kar menal.
Go with the flow.
sumi ::
opa opa! Ne sej jz nimam vec dvojcka, zeh sm edinc! Mislm da bo tisto kr res, da so kablovji zanc!
malinavc ::
Sumi: pr men je blo cca. pol leta nazaj popolnoma enako, sam z drugim modemom.
Rešitev: poklič na Telekom in jim zatež, ORENK, tak k sm jim jst, en tedn sm jih vsak dan non stop klicu pol sm pa moru poslat neki v novo mesto na telekom de naj zamenjajo nek FCM4 z PCM5 al neki podobnga, pozanimaj se kak je točno.In potem je kak tedn kasnej že ˝letel˝ z 4 kb/s in to z 33,6 modemom.To nared pa ti bojo sigurn zrihtal!
...odvisno s katere perspektive gledamo...
sumi ::
fala ti neskoncno!!!:D:\:D
Od nekdaj ljubim malinovc (kot sok seveda):P
malinavc ::
jah tuki sm pa rad pomagu ker vem kak je men šlo na k****c ko nikamor ni šlo, tut ko sm dal not 56,6k modem je isto blo...
diso ::
pokliči na telekom in vprašaj če si priklopljen na PCM. jest sem tudi bil zato sem si kupil isdn (25000 sit)
sumi ::
Ekola! Koncno sm se pravu poklicat na telekom! Sledi: ˝Ja, prikljuceni ste na PCM, jz vam tukaj ne bi znal kaj pomagati, najbolje pa bo da pošljete faks na 0808082 ter pocakate na odgovor!˝
A mi lohk kdo pove kaj za vraga to je - PCM?
crusader ::
Isto se je dogajalo meni k sm bil zrlo srečen če se mi je povezalo z 28kbs.Pol pa smo neke nove kable napeljevali pa se mi poveže z 52kbs in vleče dol tudi po 7-8kb.Juhej8-O
Ali je Windows 7 zaščiten pred Wanna Cry virusom?
Oddelek: Operacijski sistemi
72672 (2351) MrStein
Windows XP težave...
142359 (2225) edey
Obnovitev sistema ne deluje
52508 (2442) mpucko6
Gajba piva za rešitev mrežneag problema Vista-W2K
Oddelek: Omrežja in internet
303633 (2757) just_a_cook
vejica na numerični tipkovnici
71937 (1744) gumby
