Forum » Pomoč in nasveti » A mam virus?
A mam virus?
The B ::
Tkole: dobivam opozorila od raznih poštnih strežnokov da njihovim uporabnikom pošiljam maile z virusi:
"This Message was undeliverable due to the following reason:
Your message was not delivered because the destination computer refused
to accept it (the error message is reproduced below). This type of error
is usually due to a mis-configured account or mail delivery system on the
destination computer; however, it could be caused by your message since
some mail systems refuse messages with invalid header information, or if
they are too large.
Your message was rejected by [10.10.10.22] for the following reason:
Unacceptable content Your email messages contains a virus.
Please reply to Postmaster@siol.net
if you feel this message to be in error."
Sam nej bi jih pošiljal ljudem ki jih ne poznam in nimam njihovih naslovov shranjenih na računalniku. Mam tud inštaliranega nortona 2003 ki je redno samodejno posodobljen in enkrat na teden pregleda sistem. Ravnokar sm ga pa še ročno in pregledal sistem pa ni nč najdu.
A mam virus? In če kako se ga znebit.
Aja drgač vse dela normalno.
Hvala!
B
they are too large.
Hvala!
B
The End Is The Beginning Is The End...
http://blaze.sopca.com/
Redkvica ::
Enake maile sem jaz dobivala včeraj, pa sem potem pognala on-line iskanje virusov. In je našlo tri menda okužene datoteke na mojem PC in poštimalo. Teh on-line razvirusovalnikov je več sort, recimo www.pandasoftware.com/activescan/. Ali pa seveda si kupiš kak antivirusni program in ga redno posodabljaš.
The B ::
Hmmm... Sm zalavfu tole pando in je najdla tri okužene maile (une k sm jih dubu vrnjene ker majo virus) in nč drucga. A ni to mal čudn. Če so bli maili res poslani iz mojga računalnika in majo virus (panda pravi da so mel netsky) zakaj pol ni nč drucga okuženga? In zakaj norton nč ne najde? Ideje? Pa še to: a zdej mam al nimam virusa?
B
B
Redkvica ::
Saj mogoče so se maili pošiljali s kakega drugega računalnika, ki je bil res okužen, pa je imel tvoj naslov v adresbuku. Ker tile okuženi maili se kažejo včas kot da so poslani s čist od nekje drugje, kot so v resnic.
Sicer se je meni pokazalo isto kot tebi, mimogrede. Samo ni mi uspelo videt, ktere tri datoteke je prepoznal kot okužene, ker sem imela težave s povezavo.
| » | Maili iz SiOLa ne preidejo na Yahoo mailOddelek: Omrežja in internet | 2719 (2514) | BlueRunner |
| » | Poslijanje majla preko SMTP (IIS); kako?Oddelek: Omrežja in internet | 2132 (2049) | Microsoft |
| » | mail server - kako, kateriOddelek: Programska oprema | 4513 (4382) | 64202 |
| » | Čudne stvari na mejluOddelek: Omrežja in internet | 1321 (1166) | CaqKa |
| » | Čudn email - Mail delivery failedOddelek: Pomoč in nasveti | 1777 (1619) | Kaboom |
