TSC cannot be used as a timesource (debian/kernel 2.6.4)
talmai ::
Brez razloga mi je zmrznil računalnik. Fizično sem ga restartov, vendar pride do problema.
Checking root file system...
fsck 1.35
/dev/hdb5 contains a filesystem with errors, check forced.
Spurious 8259A interrupt: IRQ7
Loosing too many ticks!
TSC cannot be used as a timesource. <4> Possible reasons are:
You're running with Speedstep
You don't have DMA enabled for you're hd (see hdparm)
Incorrect TSC synchronization on a SMP system (see dmesg)
Falling back to a sane timesource now.
/dev/hdb5:
Unattached inode 130973
fsck failed
In potem mi reče, da naj zadevo manualno zrihtam, ter me vpraša za root password.
  • spremenil: talmai ()
moj_nick ::
Si pravilno naredil menuconfig?
Ti je kakšen 2.6 kernel že delal?
110111001001010001010000
talmai ::
Ta isti kernel mi je že lepo delal.
Menuconfig? Sem bolj začetnik
volkec ::
moj_nick kernel je uredu skompajlan najprj je blo 2.6.3 pol pa 2.6.4 pa nuben zdej ndela k prej je ... tko d kernel neb smeu bit vzrok pomoje ... jez bl summ na hardware al p kej tacga :))
Prehod iz kernel-2.4.26 na 2.6.10 in problem
181780 (1639) Shaman
Predolgo nalaganje kernela
Oddelek: Operacijski sistemi
141829 (1705) BigWhale
SuSE ne vidi FAT32 particij
61456 (1387) root
Debian boot
111149 (1049) BigWhale
problemi z linuxom
91363 (1118) b
