Forum » Operacijski sistemi » TSC cannot be used as a timesource (debian/kernel 2.6.4)
talmai ::
Brez razloga mi je zmrznil računalnik. Fizično sem ga restartov, vendar pride do problema.
Checking root file system...
fsck 1.35
/dev/hdb5 contains a filesystem with errors, check forced.
Spurious 8259A interrupt: IRQ7
Loosing too many ticks!
TSC cannot be used as a timesource. <4> Possible reasons are:
You're running with Speedstep
You don't have DMA enabled for you're hd (see hdparm)
Incorrect TSC synchronization on a SMP system (see dmesg)
Falling back to a sane timesource now.
/dev/hdb5:
Unattached inode 130973
fsck failed
In potem mi reče, da naj zadevo manualno zrihtam, ter me vpraša za root password.
fsck 1.35
/dev/hdb5:
fsck failed
- spremenil: talmai ()
moj_nick ::
Si pravilno naredil menuconfig?
Ti je kakšen 2.6 kernel že delal?
110111001001010001010000
volkec ::
moj_nick kernel je uredu skompajlan najprj je blo 2.6.3 pol pa 2.6.4 pa nuben zdej ndela k prej je ... tko d kernel neb smeu bit vzrok pomoje ... jez bl summ na hardware al p kej tacga
| » | Prehod iz kernel-2.4.26 na 2.6.10 in problemOddelek: Pomoč in nasveti | 1780 (1639) | Shaman |
| » | Predolgo nalaganje kernelaOddelek: Operacijski sistemi | 1829 (1705) | BigWhale |
| » | SuSE ne vidi FAT32 particijOddelek: Operacijski sistemi | 1456 (1387) | root |
| » | Debian bootOddelek: Operacijski sistemi | 1148 (1048) | BigWhale |
| » | problemi z linuxomOddelek: Operacijski sistemi | 1363 (1118) | b |
