Forum » Pomoč in nasveti » problem instalacije Win XP
StarY ::
Hja, enostavno ne morem instalirat Win XP beta2 na moj comp!
Domnevam, da je problem v maticni plosci MSI 815EP PRO RAID in sicer v RAID krmilniku, saj mi pri nalaganju Device-ov (tm pri 29 minuti do konca instalacije) sporoci prvo:
Software instalation
has not passed Windows logo testing to verify its compatibility with Whistler....
odgovor:
yes/no
izberem eno al pa drugo, cez nekaj sekund mi butne blue screen z napako v file-u evian.sys.
Ta evian.sys je na disketi z driverji za Fastrak 100 lite, ki je na MB!
DAMN!!!
A so kje novi driverji za ta nesrecni krmilnik???
odgovor:
yes/no
DAMN!!!
StarY ::
sem ze resu in sicer moras DL nove driverje z MSI strani in sicer Build60 verzija D39 (ne D33, ker ti sesuje instalacijo)...
no, vseh problemov jasno se ni blo konec
je blo treba se kar nekaj stvari nardit:
1. Delete idwlog.exe and sysparse.exe from the i386 folder of the installation folder
2. Replace winlogon.ex_, setupreg.hiv and setupp.ini (i386 folder also) with those provided in the
files provided in the PreInstall folder.
(II) Post Installation After 100% and final reboot (Safe Mode):
1. Boot into Safe Mode - F8 at startup
2. Start -> Control Panel -> Admin Tools -> CPU Management -> Local Users
-Delete Microsoft Account and Help Account
-Change guest password
-Rename Administrator
3. Now U need to edit the Registery which is Really easy to do
-Start -> Run
-regedit
-HKEY\Software\Microsoft\WindowsNT\CurrentVersion\
-Modify "RegDone" to 1
-HKEY\Software\Microsoft\WindowsNT\CurrentVersion\WinLogon
-Modify "Activation Required" to 0
-Modify "SFCDisable" to 1
-Close Regedit
4. The final step:
-Start -> Run
*Copy and past these commands one at a time in the run box.
- regsvr32.exe -u regwizc.dll
- regsvr32.exe -u licdll.dll
In stvar zdele dela in JE carska!!
-Start -> Run
-regedit
-Close Regedit
4. The final step:
-Start -> Run
| » | Internet Explorer auto run on startupOddelek: Pomoč in nasveti | 1321 (1088) | amigo_no1 |
| » | win 7 poteklo 30 dniOddelek: Pomoč in nasveti | 2969 (2448) | Kron |
| » | LiteStep problem!Oddelek: Programska oprema | 1548 (1468) | veteran |
| » | Kaj naredite po namestvi xpOddelek: Operacijski sistemi | 2291 (1846) | bojsi |
| » | Kateri windowsOddelek: Programska oprema | 1945 (1796) | sazo |
