Odkritje današnjega dneva: __int__
HotBurek ::
Dobro jutro.
Evo, tole sem danes odkril.
Primer spodnje kode:
class FullCool:
    def __int__(self):
        self.width = 0;
def call1():
    fc = FullCool();
    return fc;
if __name__ == "__main__":
    test1 = call1();
    print(test1.width);
In ta koda vrača error:
AttributeError: 'FullCool' object has no attribute 'width'
In nisem našel druge rešitve, kot da v funkciji call1() ponovno nastavil vrednost za width.
Sam vseeno, neki to ne štima, in sem šel vprašat spletnega pomočnika.
In ta pravi:
Zanimiv typo (init vs. int), ker python parser nič ne javi, da je kaj narobe, pa tudi autocomplete v IDE-ju lepo pokaže, da je width property na voljo.
Well done.
root@debian:/# iptraf-ng
Please resize your window
  • spremenilo: HotBurek ()
133780 ::
se reče temu slučajno operator overloading sicer?
Ja, ti da mislit kak copy paste nateg so ti generative AI boti, folk pa meče milijarde noter.
Zimonem ::
karafeka je izjavil:
Odgovor katerega mu je dal ai je bistveno boljši kot so ga na islotechu. Saj najbrž bi tudi na medoverju Dobil boljši odgovor.
Poglejmo kaj pravi deepse3k
The error occurs because the class `FullCool` does not properly initialize the `width` attribute due to two critical mistakes:
1. **Typo in Initializer**: The method name is `__int__` instead of `__init__`.
Python requires the initializer to be named `__init__` to be called automatically when creating an instance.
2. **Missing `self` Parameter in `call1`**:
The method `call1()` is defined without parameters, but it should be called without arguments. The issue here is actually that `call1` is a function, not a method, so it doesn't take `self`. The real problem is in the class definition.
### Corrected Code:
```python
class FullCool:
def __init__(self): # Corrected method name
self.width = 0 # Initialize the attribute
def call1():
fc = FullCool()
return fc
test1 = call1()
print(test1.width) # Output: 0
### Key Fixes:
1. Changed `__int__` to `__init__` (correct initializer name).
2. Ensured `__init__` includes `self` as the first parameter.
3. The `width` attribute is now properly initialized when `FullCool` is instantiated.
### Why the Error Occurred:
- Since `__int__` is not the initializer, it was never executed when creating `FullCool()`.
- The instance `fc` had no `width` attribute, causing `AttributeError` when accessed.
The corrected code will now output `0` as expected.
Zato pa so sedaj popularni coding agenti, ker sežejo dlje od avtocomplete
Je pa tema res povsem nedostojna za šlo tech.
  • spremenilo: Zimonem ()
133780 ::
Eni uporabijo konfigurabilne prompt kreatorje za specifikacije in omejitve, se ne zapravlja časa s približevanjem želenemu outputu glede vsebine in formata ampak se prej 'zmodelira' in shrani, mogoče razmisliš kaj v tej smeri? Čez čas postane fine tunanje zoprno, prompt pa daljši - to velja za ekstremne norce, socialci ne kompliciramo toliko, smo navajeni skromnosti.
DamijanD ::
Tega dela pa ne razumem:
sealcradle ::
Zato se pa rece "it's a constructor, init?".
garamond ::
DamijanD je izjavil:
Tega nihče ne razume, še najmanj pa Zimonem in LLM, ki je to spesnil. HotBurek je dobil pravilni odgovor dobesedno v prvi repliki (pa ga niti ni zares potreboval). Tak copy-paste odgovor je pa čisti spam, na ravni LMGTFY odgovora.
A parody of extremism is impossible to differentiate from sincere extremism.
Zimonem ::
Prekleto pa res. Iz tega kosa mesa še nekaj bo. Sedaj nam bo pa dragi garamond razložilil kaj je operator overloading. Kjer ni nikakeršnega operatorja. Potem pa kako se obnaša objekt brez konstruktorja v razredu. Res da natvezil llm stvari. Ampak ko to posvečeno bitje forme požegna operator overloading.... Bruh
Zimonem ::
Aja ob tem da se je llm sposoben revidirati v nekaj sekundah in prizna napako pri funkciji. Ti se ne boš nikoli.
acookook ::
Ajde burek, domača naloga.....https://slo-tech.com/forum/t804702/p856... najdi http endpointe.
133780 ::
zimonem, __int__ je int() type casting operator,
python osnova
Oddelek: Programiranje
213019 (2332) detroit
android črta
412979 (2250) g333kk
[android] crash
61830 (1639) messi
Ste pripravljeni na konec sveta?
142425 (2303) Zero0ne
tomcat in datasource
132678 (2435) infiniteLoop
