Forum » Programiranje » Pomoč pri enem SOAPu
Jure14 ::
Rabim pomoč pri klicu enega servisa s curl.exe
Bolj ko gledam, manj vidim težavo.
Mora biti nekaj zelo očitnega :-)
Torej rad bi klical servis
https://portal-sola.evs.gov.si/ws/vsz/1...
Za začetek funkcijo "ping"
ping_request.xml:
klic CURL-a:
curl.exe -X POST -H "Content-Type: text/xml; charset=utf-8" -H "SOAPAction: \"http://evs.gov.si/ws/vsz/1.0/ping\"" --cert c:\evs\certificate.crt --key c:\evs\private.key --cacert c:\evs\certificate.pem -d @c:\evs\ping_request.xml -o c:\evs\response.xml https://portal-sola.evs.gov.si:443/ws/v...
Pa obračam parametre okoli, pa vedno dobim
"Cannot find the declaration of element 'vsz:ping'"
Česa ne vidim?
ping_request.xml:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:vsz="https://evs.gov.si/ws/vsz/1.0">
<soapenv:Header/>
<soapenv:Body>
<vsz:ping/>
</soapenv:Body>
</soapenv:Envelope>
klic CURL-a:
Česa ne vidim?
MH0 ::
Ej vsa leta sem imel pri web servisih probleme samo zaradi takih, ki so requeste na roke skup packali. Oni, ki wsdl uvozijo in vse prepustijo avtomatiki, rešijo zadevo v dveh minutah. Poskusi ne delati na roke.
Cleon ::
Tole mi zgenerira postman glede na WSDL. Certifikate moras dodat sam.
Zgornji request vrne response:
Ping ni zasciten.
EVS dela in na https in http, tako da je irelevantno, razen ce imas tezave s certi (pac uporabi http).
curl --location 'https://portal-sola.evs.gov.si:443/ws/vsz/1.0' \
--header 'Content-Type: text/xml; charset=utf-8' \
--header 'SOAPAction: https://evs.gov.si/ws/vsz/ping' \
--data '<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
<soap:Body>
<Ping xmlns="https://evs.gov.si/ws/vsz/1.0"/>
</soap:Body>
</soap:Envelope>
'Zgornji request vrne response:
<?xml version='1.0' encoding='UTF-8'?> <S:Envelope xmlns:env="http://schemas.xmlsoap.org/soap/envelope/" xmlns:S="http://schemas.xmlsoap.org/soap/envelope/"> <env:Header/> <S:Body> <ns0:PingResponse xmlns:ns0="https://evs.gov.si/ws/vsz/1.0"> <je_uspelo>D</je_uspelo> </ns0:PingResponse> </S:Body> </S:Envelope>
Ping ni zasciten.
- spremenilo: Cleon ()
misek ::
V ping_request.xml imaš tudi http namesto https.
EDIT: Pardon, moj typo :)
Tole meni deluje:
Tole meni deluje:
curl -k -X POST -H "Content-Type: text/xml; charset=utf-8" -H "SOAPAction: https://evs.gov.si/ws/vsz/1.0/ping" -d @ping_request.xml -o ping_response.xml https://portal-sola.evs.gov.si:443/ws/vsz/1.0
- spremenil: misek ()
Jure14 ::
Super, hvala!
Tisti 1.0 je bil preveč.
Za certifikate že imam pac, crt in key datoteke.
- spremenilo: Jure14 ()
| » | Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Programiranje | 390719 (130722) | Macketina |
| » | PHP davčna blagajnaOddelek: Programiranje | 9078 (7102) | brble |
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3682 (2412) | peterv6i |
| » | Ipv6 dosegljivostOddelek: Slo-Tech | 3574 (2788) | AndraZK |
| » | Subvencija za študentski domOddelek: Šola | 3408 (3023) | xardas |
