Forum » Šport » NBA sezona 2024-2025
Legon ::
Hvala, a zacnemo s pripravami LD77? Ta vikend je ima pripravljalno tekmo z reprezentanco proti Grkom.
arnecan1 ::
V Atenah KO-jali Šariča v nekem klubu.
Izgleda, da je bila kriva pijača. Poleg pa je bil tudi Ivica Zubac. https://novice.svet24.si/clanek/novice/...
https://twitter.com/mikejbabcock/status...
- spremenil: arnecan1 ()
Duhec ::
Tri okrepitve pri Dallasu: Naji Marshall, Quentin Grimes in Klay Thompson.
Slednji je specialist za trojke.
Vir: https://www.rtvslo.si/sport/kosarka/lig...
https://normio.si/
Samael ::
In a largely unprecedented financial concession to give roster flexibility to a contender, New York Knicks star Jalen Brunson has agreed on a four-year, $156.5 million extension, his agent Sam Rose of CAA tells ESPN --- $113M less guaranteed than he's eligible to receive in one year.
https://x.com/wojespn/status/1811867780...
Čeprav, v resnici je vzel samo garantiran denar, ki mu ga lahko ponudijo to sezono, namesto za večjo vsoto počakal še eno leto in tvegal - samo ena poškodba stran, pa se lahko igralec obriše pod nosom tudi za to. Je pa to seveda voda na mlin Knicksom.
The deal --- which will cost Brunson $37.1M over the next three years --- comes with a fourth-year player option, Rose said, and that would set up Brunson to recoup the rest of the $113M on a four-year, $323M extension in 2028 or a new five year, $418M deal in 2029.
https://x.com/wojespn/status/1811867939...
Samael != Samuel
- spremenilo: Samael ()
Samael ::
Kyrie si je na treningu zlomil roko. Predvidoma dva meseca pa pol out predno začne ponovno trenirati.
Ah, well... (to je pač smola).
Samael != Samuel
globoko grlo ::
Ja sm prebral sam naslov novice, pa mi ni blo jasn kaksn zlom neki. Mah nej gre ta dalas u 3pm.
Legon ::
ja, to bo precej zakomopliciralo sezono, odvisno od poškodbe ampak lahko minejo meseci preden bo Kyrie nazaj v formi.
kixs ::
Tole je kar sranje... kaj hudica je zganjal na treningu - da se mecejo po tleh je kar standardno.
Js bi sel kar v penzijo na njegovem mestu. Res je se casa dovolj za okrevanje, vendar vprasanje na kaksnem nivoju se lahko vrne.
Samael ::
Edino, kar je pozitivno v vsem tem je, da je do začetka sezone še cele tri mesece.
Samael != Samuel
Kalavala ::
Karlo Matkovič pa raztura v poletni ligi 25 PTS (11-13 FGM), 5 REB, 3 BLK. Pa NBA trojke zadeva...
Kurzweil ::
Mene poškodba Kyria ne skrbi, sicer bo rabil kakšen mesec, kar sicer zna stat DAL na koncu kakšnega mesta, če vemo, da je zadnja leta ta borba med 4-5. mestom in mest ki vodijo v play-in/off kar huda. Tudi letos ne bo nič drugače, glede na celotno stanje, zna bit še celo bolj zajebano...
@kixs, penzija zarad zloma roke? Em, ne...
@Kalavala, ja, Matković je povsem sfokusiran na ligo NBA... skenslal reprezentanco in vse mogoče ponudbe, saj je odločen, da zaigra že letos v ligi NBA. Spremljam Matkovića že vrsto let, fant je fizikalec in atraktiven igralcev, direkt za NBA... še kakšno leto nazaj bi rekel, da je preveč limitiran, kar se meta tiče... ampak smo že pri COL zadnjo sezono videli, da je ogromno delal na metu... tako, da me to sploh ne preseneča. Podobno sem spremljal tudi Jokića od mladih nog, tudi on je takole zadnjo sezono pred odhodom v NBA nenormalno veliko delal na metu... pa ne vlečem sedaj neke analogije, da bo Matković novi Jokić, kar bi znal kdo razumat tako... si ga pa znam predstavljat, da bi znal bit povsem proper center... jih ne bom našteval, pomislite malo na te evropske centre, ki jim je uspelo v NBA, od Sabonisa dalje... je pa res, da je kar malce injury prone, podobno kot denimo Jusuf Nurkić. In prav njemu je verjetno še najbolj podoben... mrcina, moč, morje blokad, kasneje tudi razvit met iz razdalje, pa upam, da ne tudi poškodbe, ki jih je Matković že imel nekaj.
Bronny je in bo celotno kariero žrtev svojega očeta... fant ni nič kriv, da njegov foter rad ugrabi klub, kjer igra, tale nepotizem Lebrona pa sploh, res ni potreben v jeseni njegove zavidljive kariere... se je možakar zgleda že pred leti odločil, da bo prvi, ki bo v istem klubu igral s sinom... nima smisla.. saj je vsem vse jasno... na zadnji tekmi je Bronny še nekak bil za silo... na vsej prešnjih v summer league pa obup.
Zanimivo bi bilo videt, kaj bi LAL/Lebron naredil, če bi nek drug klub pobral Bronnyja pred njimi
Sicer pa bo letos zanimivo videt vse te evropejce, ki so bili pobrani draftu... seveda tu prednječijo 3 francozi med top 6 picki, vključno s prvima dvema... skupaj kar 6. Je pa letos bilo draftanih tudi par, če se grdo izrazim, eksotov... po eden iz Portorika, Švice, Nizozemske, Belgije... in celo 2 Šveda... seveda kar malce boli, ko že lep čas ni nobenega Slovenca...
c0ck4m0u53 ::
If citizens cannot trust that laws will be enforced in an evenhanded
and honest fashion, they cannot be said to live under the rule of law.
Instead, they live under the rule of men corrupted by the law. - Dale Carpenter
DrSergioDJ ::
Obup ali ne, še vedno ima boljši TS% kot 2. pick na draftu...
Groot ::
Mislim, da je odgovor na dlani, ne bi podpisal z LAL nove pogodbe in bi pač šel tja kjerkoli bi pač pristal Bronny. Pa saj to je jasno že iz tega, da je novo pogodbo podpisal šele po draftu.
Kurzweil ::
@DrSergioDJ, saj nisem delal primerjave z 2nd draft pickom... je pa itak jasno, da je vsako leto med top picki kakšen total bust... je pa Bronny malce izboljšal statistiko po tisti 3. tekmi v SL
Če je on slab, ne pomeni, da ni tudi Bronny
@Groot, kar bi bil verjetno blessing za LAL... sicer pa po seriji zavrnitev štvilnih košarkarjev, da bi podpisali za LAL, mislim, da vemo zakaj... pa naj bo tako, da dobi Lebron račun za tole mešetarjenje in posredovanje na vseh nivojih. Kot sem napisal, škoda po takšni karieri, da se bo takole osmešil. Sicer ne bom prehiteval,... gledene na trenuten roster in stanje Jamesa in Davisa... bom zelo presenečen, če tale LAL sploh pride do playoffa... do playina še mogoče, če se jim poklopi...
Duhec ::
Stephen pravi, da je bolje za očeta kot tudi za sina, da slednji začne v G-ligi dokler ne bo pripravljen za LA dres.
https://normio.si/
2dark ::
Ta ne bo nikol pripravljen za NBA ligo. Ko ti igralci vodijo klub. Očitno lebron letno prinese res hude milijone Lakersom , da mu to dopuščajo.
(\___/)
(> _ <)
(> _ <)
Kakšna G Liga, LeBron bi rad, da mu sin podaja žogo. Enes Kanter je povedal tisto, kar si drugi mislijo. Bronny je pristal pri LAL zaradi LeBrona. J.J. Redick je postal trener zaradi LeBrona. Noben od zaželjenih igralcev ni prišel v LA. Zaradi LeBrona. Vse se vrti okoli LeBrona, obseden je sam s sabo in s svojo podobo.
Očitno vodi medije in poskuša nadzorovati svojo zgodbo. Jaz prepoznam diktatorja, ko ga vidim in LeBron je dobesedno diktator lige NBA. Če se mu zoperstaviš, te pošljejo v drugo moštvo, to vsi vedo.
Kurzweil ::
Stephen A Smith je ravno toliko relevanten, kot ona maskota klovna v McDonaldsu. Mu pa respect, ker bo verjetno zaslužil več kot Bronny... sej ne vem, ali je že bila podpisana tista pogodba 20-25M$ na sezono... pa za 5 let.
Če bom kdaj kakšnem kolegu, ki je basket fan kupoval darilo, dobi fix dres od Bronnyja.
Bogi Lebron. Je taka... Madonna kosarke. Verjetno bo se pri 45-ih spilal po 2minuti za Lakerse.
2dark ::
Denver je tud postal parodija. Bo zdaj lahko Jokić pokazal, kako vrhunski pa najboljši na svetu je.
Od ekipe, ki je delovala, da bi lahko bilo kaj iz njih so zaradi previsoke pogodeb MPJ uničili celotno ekipo.
Od lani jim je uspelo izgbit Bruce Bowena, Jeff Grenna , KCp-ja in Reggie JAcksona. Mojstri. Jih bo MPJ nadomestil. Model ne dela nič drugega kot trojke meče na polno in solira. PRivoščim jim na polno.
(\___/)
(> _ <)
(> _ <)
- spremenilo: 2dark ()
Groot ::
Tule se pa kar pridružim mnenju. Mi je prav neverjetno kako so vsaj na papirju v Denverju uspešno razbili uspešno zgodbo. Kje za vraga oni vidijo doprinos Westbricka v to ekipo mi je totalna uganka
2dark ::
Težava je , ker so šli dat MPJ-ju tako visoko pogodbo. Modele, ki sam na koš mečejo imaš realno"na vsakem vogalu".
(\___/)
(> _ <)
(> _ <)
Kurzweil ::
Stvar je sila preprosta... Denver je naredil to, kar bi naredila večina ekip. Po tem, ko je DEN osvojil naslov, so se seveda odločili, da podaljšajo vsem po principu zmagovalnega konja se ne menja oz. gremo obdržat čim več ekipe, ki je osvojila naslov...
Če bi DEN letos še enkrat osvojil naslov, se o tem seveda ne bi kaj veliko pogovarjali... se pa strinjam, da ta fant ni vreden 36M$ na sezono.
Se bodo malce premešale karte na zahodu pač... GSW dol... LAL dol... DEN dol... nekako vrh MIN, OKC, LAC, DAL, PHO... nižje pa verjetno precej večji boj za preostala mesta... SAC, NOP, HOU, LAL, GSW... seveda da bo MEM boljši kot lani... tudi od SAS pričakujem, da se bo malce dvignil.. tudi UTA je malce dodal od lani... vsaj zaenkrat, največji outsider POR... pa še iz tega kluba bi naj LAL zelo hotel Aytona in bojda ponujajo bizarne pogoje, tja do maksimuma kot lahko, da vsaj nekoga pripeljejo, ker jim do sedaj ni uspelo še nikogar oz. vsi zavračajo LAL, vsi vemo zakaj...
Bi pa seveda malce še počakal, da se zgodijo še zadnje rošade... poškodbe tudi krojijo, tudi DAL, ki bo štartal z Irvingom brez forme zelo verjetno...
Kurzweil ::
Vidim pa, da iz vseh koncev letijo govorice... da bi se naj DAL zelo zanimal za Juliusa Randla... omenja pa se PJ Washingtona, Gafforda, Kleberja, Hardyja, picke... v raznih kombinacijah... v kolikor sta vključena PJW ali Gafford, sem že avtomatsko proti... niti malo navdušen... bi pa naj v preteklosti DAL že 2x ponudil soliden offer, pa je Randle gladko zavrnil...
Kurzweil ::
Iskreno upam...
Bi pa NYK to pasalo... ker imajo na položajih okrog 2-3-4, predvsem 3-4 že kar malce gužvo... pa vemo, kako je bilo zadnjo sezono z Randlom... po drugi strani pa NYK nima proper centra, prav nobenega... tako da predvidevam, da jim je najbolj diši Gafford... tudi jaz upam, da ni nihče pri DAL tako ubrisan, da gre v to... ker je res trajalo predolgo, da so prišli do več kot solidne visoke linije...
Groot ::
Realno mislim, da je DAL bolj ali manj zaključil kadrovanje. Mogoče če bi se uspeli znebiti še Kleberja ali pa Powlla, ampak dvomim.
Kalavala ::
Za enga blizu vet min še imajo plac. Sicer verjetno Markiff, čeprav bi bolj pg rabli. Pa Lawsona tudi lahko odslovijo.
globoko grlo ::
To je to, zdej je pa obramba popolna :)
2dark ::
Ne vem, če imamo posebej temo, vendar je ameriška reprezentanca komaj premagala tudi nemško.
(\___/)
(> _ <)
(> _ <)
Kurzweil ::
Undrafted free agent Jamarion Sharp is signing a 1-year deal with the Mavs, per Chris Haynes.
San Antonio's Victor Wembanyama has a height matchup now
Gre za 22 let starega in 226cm visokega centra... kolikor gledam je najvišji igralec trenutno v NBA... za njim pa sta z 224cm Wembanyama in Marjanović... potem 221cm Bol Bol.
Zadnji dve sezoni je bil najboljši obrambni košarkar v svoji konferenci lige NCAA in pa, kar verjetno niti ni toliko presenetljivo, prvi bloker like NCA... tudi zadnji dve sezoni.
Upajmo, da bo še za kaj drugega, kot za menjavanje žarnic... za par minut bi bil znal biti uporaben proti določenim centrom v raketi, da naredi malce reda oz. v primeru, da bi manjkal kakšen Gafford ali Lively... bo zanimivo videt, če jim uspe naredit kaj s tem fantom.
Kalavala ::
Tisti ki so ga gledali pravijo da je povsem neuporaben za NBA. Pa pravijo tudi da v zdnjih dveh letih, kljub menda dobremu trenerju v ncaa, ni nič napredoval. Upam da se motijo.
Kurzweil ::
Ja, saj da je bil undrafted veliko pove... tudi overall je malo teh centrov, ki so višjo od 220cm, da je bilo kaj odnjih, če pa že, pa so precej bolj nagnjeni poškodbam oz. se jim kariere rade prej končajo, kot recimo Yao Mingu.
Po drugi strani pa tudi berem, da ima fant glede na svojo višino dobro hitrost in koordinacijo, še enkrat, pravim glede na njegovo velikost.
Jaz seveda od njega na pričakujem nič, z nekaj trudi pa bi se lahko našlo par minut zanj. Seveda odvisno od sistema igra, če se igra počasi, bolj pozicijsko in na postavljen napad, bi še nekak šlo... pri neki hitri, dinamični igri, če hočete moderni košarki, pa seveda ni zanj kruha. Jaz ga mogoče vidim za nekih 5-10 min, da naredi malce reda v raketi kar se obrambe tiče, vključno s kakšno blokado, ker defender pa je bojda OK... prosti meti seveda okoli 50%... imel pa je tudi v povprečju 4 blokade na tekmo... pa za ščepec več točk... gledam prejšnje sezone, ne zadnji, je igral po 30min na tekmo...
Dončič bi lahko zanj ušpilal kakšen pick and roll ... alley-up...
Kurzweil ::
BREAKING: Lauri Markkanen has signed a five-year, $238 million contract extension with the Utah Jazz.
Kurzweil ::
Gledam razne page od Miami Heat in bojda se Goran Dragić te dni dogovarja z MIA, da bi bil del stuffa v front officu. Komentarji pa res povsod pohvalni, predvsem se vidi, da ga imajo fani tega kluba res radi, o pripadnosti temu klubu pa tako ni treba veliko pisat. Imam občutek, da je tole že done deal. Tisti, ki dolga leta gledamo basket vemo, da dober košarkar niti slučajno ne pomeni dober funkcionar... ampak tole bi bilo zasluženo.
2dark ::
Sam mislim, da se bo Goran dobro znašel v takšni vlogi. Pa tudi v vlogi pomožnega trenerja ga osebno vidim.
(\___/)
(> _ <)
(> _ <)
Ni tako sladko. Leta 2020 so v Ljubljani viseli plakati z napisom "TVOJA DRUGA DRUŽINA JE VEDNO S TEBOJ", ne dolgo po tistem so ga brcnili v Toronto. Hinavščina na višku.
Kurzweil ::
@2dark, sem že večkrat zasledil Dragiča v intervjujih, ko je izjavil, da ga karkoli v smislu trenerja niti malo ne zanima.
@Ganon, ko pride do transferjev, je bolj malo ljubezni in empatije... zvestoba se resnično ne kaže na takšen način, kot v Evropi. Minili so ti časi, ko so igralci celo karieri igrali za en klub, pri tam pa niso niti pomislili, da bi šli drugam, pa tudi vodstvo kluba ne. GMi v NBAju so ena posebna kasta, najprej denar, šov, rezultati, potem pa pride čas za prijateljstvo in empatijo.
Folk je pa definitivno v 99% totalno za, da se mu da kakšno funkcijo, ampak tudi pri tem je tako, kot sem prej pisal... za GM gledalci tudi niso prvo merilo. Včasih so tudi precej nemočni, ko si vbijejo v glavo kakšne blockbuster trade, tam je kar nekaj kolateralne škode, da pridejo do svojega. Profesionalnci to razumejo.
Enkrat sem gledal en odličen prispevek na ESPN, kako je ob draftu, predvsem kako postopajo tisti največji oz. tisti z največ in najvišjimi picki. Mislim, da je bilo takrat prikazano, kako je pri OKC, ki je imel oz. še ima cel shitload pickov... tam je GM s svojo ekipo imel za vse mogoče scenarije pripravljene rešitve, odgovore in opcije... nekih par 100 jih je bilo, kaj, komu ponuditi... to je tisto, ko je nek igralec draftan in potem v isti sekundi že zveš, da je v drugem klubu. Tu v neki želji in včasih brez razuma gredo klubi v marsikaj, Dragič je sicer bil zelo zvaležen košarkar, roko na srce tudi poškodovan nekajkrat, tako da je pač bil del deala. GM, back, front office in marketing, so ene povsem ločene entitete... verjetno tisti, ki je oglaševal v LJ to glede Dragiča, niti ni kaj veliko vedel o morebitnih opcijah, kar se trada tiče. Včasih se tudi samim igralcem niti malo ne sanja... GMi tudi ne govorijo veliko, da seveda ne pride do razkritja, tu pa potem stopi na sceno to insiderstvo in novice, za katere sem prepričan, da nekateri novinarji plačujejo, saj od tega krasno živijo.
2dark ::
Ni tako, kot si ti napisal. Pri 34 ih mu je Miami dal novo dvoletno pogodbo, ki je bila več kot velikodušna. 37 milijonov oz. 18.5 milijonov USD, glede, da je imel kronično uničeno koleno.
Riley mu je rekel:" damo ti več, samo če bo priložnost, te bomo trejdal."
(\___/)
(> _ <)
(> _ <)
2dark ::
Realno samo največje legende ostanjeo v enem klubu celo kariero in takšnih je zelo malo. Tukaj ne gre samo za vpliv , ki ga ima igralec na igro moštva, uspehe, pač pa tudi, da je ta igralec kar duša mesta. Čeprav so v preteklosti klubi pokazali res zahrbnost, ko so šli menjat Hakeema , Ewinga proti koncu njunih karier. Tega se enostavno ne bi smeli it. To sta igralca, ki sta tako Rocketse kot Knickse postavila na košarkaški zemljevid. Nekaj podobnega je Atlanta naredila z Dominique Wilkinsom.
Predvsem mi je všeč, da so včasih imel manj simpatij, danes se pa lebronu pod jajca mečejo, pa on odloča kaj in kako.
(\___/)
(> _ <)
(> _ <)
2dark ::
Aleksa Avramović bi naj imel na mizi ponudbi Clipersov in Atlante. Če bo prišlo do podpisa pogodbe bomo pa še videli.
(\___/)
(> _ <)
(> _ <)
| » | NBA sezona 2021-2022 (strani: 1 2 3 4 … 52 53 54 55 )Oddelek: Šport | 367029 (160662) | mersault |
