Forum » Programiranje » SqlAlchemy (RemovedIn20Warning): Migracija na 2.0 ter "autocommit"
HotBurek ::
Dobro jutro fantje in dekline.
Zanima me, če kdo ve, kako bi lahko uredil spodnjo kodo, da mi ne bi več javljalo warning-ov?
Tisto kar bi rad, je, da se problem reši brez uporabe "whit".
Dokumentacija:
https://stackoverflow.com/questions/752...
https://docs.sqlalchemy.org/en/14/chang...
Sample Python koda, kjer izvajam try and fail:
RemovedIn20Warning:
Deprecated API features detected! These feature(s) are not compatible with SQLAlchemy 2.0.
To prevent incompatible upgrades prior to updating applications,
ensure requirements files are pinned to "sqlalchemy<2.0".
Set environment variable SQLALCHEMY_WARN_20=1 to show all deprecation warnings.
Set environment variable SQLALCHEMY_SILENCE_UBER_WARNING=1 to silence this message.
(Background on SQLAlchemy 2.0 at: https://sqlalche.me/e/b8d9)
sql_connection.execute("USE database1;");Dokumentacija:
#!/usr/bin/python3.11
import sqlalchemy;
# sqlhost = "mysql://user1:password1@localhost:3306/?autocommit=true&charset=utf8mb4";
sqlhost = "mysql://user1:password1@localhost:3306/?charset=utf8mb4";
sql_engine = sqlalchemy.create_engine(sqlhost);
sql_connection = sql_engine.connect();
sql_connection.begin();
#sql_connection.commit();
sql_connection.close();
sql_engine.dispose();
root@debian:/# iptraf-ng
Please resize your window
HotBurek ::
Zadevo sem zaenkrat rešil z uporabo future=True:
sql_engine = sqlalchemy.create_engine(sqlhost, future=True);
| » | [MariaDB] Kako napisat SQL za top N by group?Oddelek: Programiranje | 824 (635) | kljuka13 |
| » | [SQL] Referenca na parameter v proceduriOddelek: Programiranje | 1926 (1639) | Ahim |
| » | [Python3] Sortiranje 2D dict-a?Oddelek: Programiranje | 1713 (1426) | marska83 |
| » | python in postgresql (strani: 1 2 )Oddelek: Programiranje | 10168 (9069) | ZaphodBB |
| » | What, why & when - py frameworksOddelek: Programiranje | 1616 (1361) | Mavrik |
