Forum » Igre » X˛ - The Threat
X˛ - The Threat
Tr0n ::
Prihaja se ena space simulacija v stilu Freelancerja in po slikah sodec bo igra zelo zanimiva :).
Tr0n ::
Popravek. Po opisih sodec, je spil veliko bolj zanimiv :).
"You might run into some pirates. You might end up fighting them, and guess what: they might end up surrendering. All of a sudden you have a few more ships at your disposal. If one of those is a transporter ship, you might set it up to run a trade route for you. While you're off gallivanting on your pizza runs, it might be earning some big cash on the side."
"The first inkling you get that X2 might be a bit more than your average shooter is right at the start - the intro movie, all rendered in real-time, and showing you the inside of a space dock. That's right, the inside - in order to dock in X2 you actually have to not only enter a space station's docking port, you also have to maneuver inside the station's cavernous space (no worry, the station's computers put a speed limit on your engines) into a docking bay. While there, you can also check out who else is docked here - might be useful for a trade (or theft). You only have to manually do this until you get a docking computer. Which is nice."
"Maybe you've set a chunk of cash aside, a real nest egg. But you know if you spend it on that ship you've been eyeing you'll have nothing left for armaments. Here's a thought. Why not build a space station? Yeah, so you'll need to hire a transport ship, one of the massive haulers, to bring your components into place - but then you can start trading, or just producing (factories, farms, trade stations are all available). Of course, you'll need to do this in the right place and trade the right goods; you might end up operating at a loss, and you wouldn't want that."
Jummy :).
Jummy :).
Vesoljc ::
sounds good... does it also feel good?
morphling1 ::
Jaz se spomnim že dolgo nazaj X dema, ki je bil prav tako benchmark kot tale X2, grafika je bila tudi takrat huda, samo ne spomnim se da bi tisti X ratal tudi špil, ostalo je pri benchmarku.
Zheegec ::
Zelo huda zadeva, očitno bo kar precej bolj zanimiva od Freelancerja, samo še Freespace2 style bi moral biti (takšno igro, ala Freespace3 že dolgo čakam...) in igra bi bila neverjetna.
Janez Janša, 29.04.2014
Zheegec ::
This is a PRE-ORDER of the English version of X˛ The Threat which is to be released in November 2003. Delivery on the day of release.
Yes, kicks ass
Tr0n ::
Uff, sistemske zahteve so pa dokaj visoke za tale spilcek.
Recommended
MicrosoftŽ WindowsŽ 2000/XP
PentiumŽ III 1300Mhz or equal
256MB RAM
64MB DirectX 8 compatible 3D graphics card
Soundcard (Surround sound support recommended)
1000MB free diskspace
32x CD-ROM
Mouse + Keyboard or Joystick (Optional support for force-feedback)
Optimum
MicrosoftŽ WindowsŽ XP
PentiumŽ IV 1800Mhz or equal
512MB RAM
128MB DirectX 9 compatible 3D-graphics card
48x CD-ROM
Recommended
256MB RAM
32x CD-ROM
Optimum
512MB RAM
48x CD-ROM
frenk ::
Recommended
256MB RAM
32x CD-ROM
...ja seveda
Tr0n ::
X2 The Threat Rolling Demo
V bistvu samo gledas, kaj zmore masina. Se lahko uporablja tudi za bechmarke.
Matwic ::
Dobra novica, 5. novembra 2003 je sel X2 v razmnozevanje. Uradni izid za Severno Ameriko je 19. november.
Je pa ena slaba novica za nas Evropejce, pri nas bo X2: The Threat na voljo sele 6. februarja 2004.
Novica o izidu na uradnem forumu Egosofta
Uradna stran X2
Uradna stran X2
Tr0n ::
A 19-tega? Sem mislil, da ze 15-tega :).
Tukaj se nekaj beta porocil, ki dokaj nazorno opisujejo dogajanje in kaj vse je mozno poceti v X univerzi :).
Predator ::
Tole je bolj kopija od x-beyond the frontier kot freelancerja, čeprav upam, da bojo tudi na veliko skopirali od njega ker
-trgovanje : je bilo sicer razvito, tovarnam si lepo kupil transporterje, da so sami surovine kupovali, pa ostali so k tebi samo lepo hodili kupovat, lahko si tudi celo industrijo (vse potrebne surovine na kupu) postavil, da se niso freighterji cijazili po pol vesolja... samo postane to dolgčas, na koncu je bil pa tvoj glavni dohodek prva kupljena tovarna -power plant, ki je elektriko pod ceno prodajala, ker sem mel najnižje cene in so vsi od 4 sektorjev okoli pri meni kupovali, pa še moja ostala industrija si je lahko pomagala, ker je mela nižje cene; AMPAK hočem en globalen sistem kakšne so cene v sektorjih, kjer sem imel tovarne in kakšno je stanje na vseh tovarnah+naročanje transporterjev in itd prek remote, ne da moraš fizično od tovarne do tovarne letat!
-navigacija: upam da bojo naredili veliko boljši navigacijski sistem ( naj skopirajo od freelancerja, pa ga naredijo povsem avtomatskega, brez da moraš sam klikat da prideš čez je*** space gate/porte... ) ker drugače bo spet trajalo da od 7h, ko igraš, 6,5h letaš okoli.
-boji: ta del z boji me najbolj zanima
, v x-u je bilo bolj tko, rakete neunčikovite ( razen za nasprotnikove glavne bojne ladje pa še to bolj tko tko ), edina sreča je bila to, da si lahko tovarnam nakupil ogromno defence fighterjev in si jih, ko si šel rovarit vzel kot escorto, da so poskrbeli za fighterj,e medtem ko si se ti okrog podil za večjimi ladjami:)
- spremenil: Predator ()
undefined ::
Sem igral originalni X takoj po izidu in je bil dokaj v redu, le premalo opcij je bilo za nadaljno igranje, ko se je zgodba končala.
Tr0n ::
Bah, spil je bil prestavljen na 27. november. Uraden podatek iz X2 foruma.
That makes me a sad panda
- spremenilo: Tr0n ()
Predator ::
danes sem našel x-tension, v bistvu "dodatek" za original x-btf, sicer sem ga samo na hitro preigral ampak ima par stvari, ki so mi všeč in ki so podobne x2, vsaj glede na tisti beta report: remote nadzor na tovarnami ( sicer moraš dropat ene neumne relay satelite ampak korak v pravo smer so naredili...) , warp engine, celo ladjo lahko zapustiš in okrog letaš v space suitu... edino nadzor nad ladjami pa orožja sux!
ampak za kratkočasit do izida x2 bo
Zheegec ::
Kaj je sedaj z igro? Na uradnem forumu jih veliko že ima gold verzijo...
Drugače če bo kdo igral letos to igro - uradni datum izida za EU verzijo je nekje v februarju
Tr0n ::
No, koncno je prispela :).
Po preigranih trening simulacijah mi je dokaj vsec, ceprav je potrebno nekaj casa, da se navadis na vse tipke, kombinacije in menije .. sploh kasneje, ko izdelujes svoje izdelke oz. imas svojo bazo.
Drug minus je strojna zahtevnost. V sektorjih, kjer je dosti aktivitete, postane vse skupaj bolj sluggish na mojem 1800+ in Ti4200 :). Zgleda pa zato spil fenomenalno do vsake potankosti. Lahko bi celi dan samo gledal, kako se ladje prevazajo iz ene destinacije v drugo :).
Drugace pa, obetavno.
undefined ::
Hja Tr0n, hardwareske zahteve se višajo iz dneva v dan, to bi se lahko do sedaj že naučil.
Tr0n ::
Prvi dve misiji se splaca koncat. Dobis tvoj transporter. Samo ni cisto nic opremljen, tak da ga moras najprej nabildat, potem pa mu nastavis skripto, da prevaza stvari, medtem ko ti raziskujes. Automatic money :).
Tr0n ::
Pilot Licence Test / Capital Ship Combat Test / Argon Titan
. Zadeva ima kar 5 turretov. To treba enkrat nabavit :).
- zavaroval slike: Predator ()
[SkA] ::
Erm.. hud špil, sam klinc k se mi sistematsko sesuva nazaj na namizje za skor vsaka "zvezdna vrata" skoz katera grem. Pridem v nov sektor, pokaže lepo vse, pol pa puffff.. back to my desktop.
- spremenil: [SkA] ()
Tr0n ::
Na uradnem forumu ima kr nekaj ljudi podobne probleme, ceprav meni dela brez tezav. Imam pa DX9b in pa nove nVidia ForceWare gonilnike.
Ahiles ::
Spil nej bi mel zelo hud bug al pa neki ki pokvari save game in potem ko nalozis se ti usuje ponavad ksno min po zadnem sajvu.
Se pa dogaja razlicno nekaterim po 20h drugih po 5h igranja men se je po 3 misiji(okol 4-5h igranja) za glavno zgodbo ko bi si mogu kao denar zaluzit za M3 ladjo se mi po 1min usuje po zadnjem sajvu.
Edina resitev je zdej da gres na ksn drug save ki je bol nazaj pa probas drugece kej naredit pa upas da se ne bo spet usul.
Tko da sajvite pogosto pa v veliko slotov.
Tr0n ::
Priporocam, da se pocaka na patch. Ce se ta napaka res pojavlja pri vseh, potem bo patch hitro.
[SkA] ::
Meni na žalost kaj drugega ne preostane. Probal sem s tremi različnimi gonilniki (Forceware 52.16. 52.70, 53.0X) in ponovno namestitvijo DX9.0b .. nič pomagalo.
Enostavno me v drugi misiji, ko morem skozi south gate, vrže nazaj na desktop, oziroma me vrže takoj ko pridem v nov sektor. O well.. on to price of persia.
| » | Gothic 2 (strani: 1 2 )Oddelek: Igre | 7462 (2402) | tetriandoch |
| » | X RebirthOddelek: Igre | 3457 (2499) | Bolf3nk |
| » | Nvidia System utility, kar smo čakali smo dočakali :)Oddelek: Strojna oprema | 2231 (1757) | njok |
| » | Microsoftova neumnost pri xp home editionOddelek: Operacijski sistemi | 2420 (2025) | jlpktnst |
| » | Soyo????Oddelek: Kaj kupiti | 2275 (2211) | piko |
