MySQL problem
MySQL problem
TechFreak ::
Muci me da se z phpMyAdminom nikakor ne morem povezati z bazo - sql me zavrne ceprav sta up. imeni in gesli v config.inc in my.ini Setup fileu enaki.
Vrne mi:
#1045 - Access denied for user: 'piko@localhost' (Using password: YES)
Kaj neki me tok za****?
LP, M:|
Seadoo ::
Poglej če maš userja read in če je za tvoj user domena localhost res naštimana not v mysql-u.
TechFreak ::
V my.ini ocitno tega nimam nastavljenega, ce mora sploh biti tu.
Imam samo:
#This File was made using the WinMySQLAdmin 1.4 Tool
#5.8.2003 23:28:16
#Uncomment or Add only the keys that you know how works.
#Read the MySQL Manual for instructions
[mysqld]
basedir=c:/mysql
#bind-address=192.168.0.1
datadir=c:/mysql/data
#language=c:/mysql/share/your language directory
#slow query log#=
#tmpdir#=
#port=3306
#set-variable=key_buffer=16M
[WinMySQLadmin]
Server=C:/mysql/bin/mysqld-nt.exe
user=eden
password=neki
Seadoo ::
Poglej tle.
MySQL server problem
Oddelek: Programiranje
81905 (1737) Modri dirkač
mysql na windows
Oddelek: Izdelava spletišč
101843 (1759) Ziga Dolhar
SQL
82041 (1940) Trubadur
Napaka pri MySQL pri postavitvi foruma
72115 (2031) DJ-DUST
MySQL users & passwords problem
Oddelek: Programska oprema
91841 (1748) Loki
