Forum » Programiranje » MySQL problem
MySQL problem
TechFreak ::
Muci me da se z phpMyAdminom nikakor ne morem povezati z bazo - sql me zavrne ceprav sta up. imeni in gesli v config.inc in my.ini Setup fileu enaki.
Vrne mi:
#1045 - Access denied for user: 'piko@localhost' (Using password: YES)
Kaj neki me tok za****?
LP, M
Vrne mi:
LP, M
Seadoo ::
Poglej če maš userja read in če je za tvoj user domena localhost res naštimana not v mysql-u.
TechFreak ::
V my.ini ocitno tega nimam nastavljenega, ce mora sploh biti tu.
Imam samo:
#This File was made using the WinMySQLAdmin 1.4 Tool
#5.8.2003 23:28:16
#Uncomment or Add only the keys that you know how works.
#Read the MySQL Manual for instructions
[mysqld]
basedir=c:/mysql
#bind-address=192.168.0.1
datadir=c:/mysql/data
#language=c:/mysql/share/your language directory
#slow query log#=
#tmpdir#=
#port=3306
#set-variable=key_buffer=16M
[WinMySQLadmin]
Server=C:/mysql/bin/mysqld-nt.exe
user=eden
password=neki
Imam samo:
#5.8.2003 23:28:16
[mysqld]
basedir=c:/mysql
#slow query log#=
#tmpdir#=
#port=3306
[WinMySQLadmin]
user=eden
password=neki
| » | MySQL server problemOddelek: Programiranje | 1905 (1737) | Modri dirkač |
| » | mysql na windowsOddelek: Izdelava spletišč | 1843 (1759) | Ziga Dolhar |
| » | SQLOddelek: Programiranje | 2041 (1940) | Trubadur |
| » | Napaka pri MySQL pri postavitvi forumaOddelek: Izdelava spletišč | 2115 (2031) | DJ-DUST |
| » | MySQL users & passwords problemOddelek: Programska oprema | 1841 (1748) | Loki |
