WD My Book
WD My Book
Damjan Klinc ::
Imel sem poplavo in moj primarni računalnik je bil potopljen in je uničen. Sedaj ne morem uporabljati zunanjega diska My Book 1,82 TB zaradi gesla ,ki ga ne vem. Kaj lahko storim ?
Lp. Damjan
styrian ::
Disk je strojno šifriran. Če ne veš gesla, ne moreš nič. Zakaj si ga pa nastavil?
Damjan Klinc ::
Ne vem če sem ga sploh nastavil. Nujno sem potreboval disk in sem ga kupil in priklopil.
Ko sem uporabljal računalnik sem samo kliknil na My Book in se je odprl brez gesla
styrian ::
Potem pač na drugi računalnik namesti isto programsko opremo od WD za ta disk in bi moralo delati.
Če boš disk vzel iz zunanjega WD ohišja, ne boš mogel prebrati podatkov.
GupeM ::
Gre mogoče za bitlocker? Če da, potem si poglej kako to rešit:
https://support.microsoft.com/en-us/win...
Damjan Klinc ::
disk sem moral dati ven iz ohišja ker je bil v vodi, Disk deluje in želi geslo ,ki ga ne poznam
https://photos.app.goo.gl/vvZ75NXApk7Lc...
Tole ne bi delovalo?
Recovery Button
Pressing the recovery button while powering up the device resets the admin user
name and password to default without erasing shared folders or volumes. The
recovery button also resets network configuration to DHCP (obtain an IP address
automatically). Follow the instructions below to reset the device using the recovery
button.
1. Turn off the device and disconnect all cables from the unit.
2. Insert a paperclip or narrow tipped pen into the recovery slot on the back of the
unit. Press and hold down the recovery button.
3. While continuing to hold down the recovery button, connect the power cable to
the back of the unit.
4. Hold the recovery button down until 10 seconds after the power/activity LED
lights on the front of the device, then release the button. The unit may take up to
three minutes to boot up completely.
Note: The default user name is admin and the default password is 123456.
kloko ::
opeter je izjavil:
Seveda ne bi delovalo, če pa pravi, da je dal disk ven iz škatle...
Mislil sem, da bi dal disk nazaj v WD Mycloud ohišje ... če pa je uporabil kakšno drugo enkripcijo, hja ... potem mu ni pomoči. Oziroma, ne, da bi vedel. Mogoče, če kontaktira kakšne vzhodne hekerje.
Damjan Klinc ::
kje dobim url za sliko da vam jo pošljem
Damjan Klinc ::
vres.ales ::
Ne vidijo se slike, naloži drugam
Han ::
Sliko pokaže, če si prijavljen v Google račun.
  • spremenil: Han ()
styrian ::
Če si disk dal ven iz zunanjega ohišja in ga priklopil direktno v računalnik, ne boš mogel dostopati do podatkov.
Ohišje ima hardwerski kontroler ki šifrira disk. Edina možnost je da kje na eBayu dobiš popolnoma isti kontroler, pa še tisto nisem sigure če bi delovalo.
Baja ::
če še maš ohišje, ga razstavi na prafaktorje, elektroniko spucaj z isopropanolom, plastiko pod vodo (no-pun intended). vse skupaj sestavi nazaj in poročaj.
če je elektronika blatna, jo pred isoprapanolom lahko tudi spucas pod vodo.
isto lahko probaš z računalnikom.
  • spremenil: Baja ()
Damjan Klinc ::
Disk mi dela ter kontroler tudi. Disk je čist in pripravljen za uporabo. Ne vem kako naj pridem do gesla ,ki sem ga 2014 po vsej verjetnosti upisl- Kam se zapiše ne vem.
Ohišje ima blažilce proti vibracijam ostalo je pvc ohišje.
Baja ::
kaj se je zgodilo z mašino, da ne dela?
če je vsaj disk iz računalnika preživel, lahko probaš zbootati sistem na drugi masini in priklopiti disk. geslo je verjetno na disku od masine.
Damjan Klinc ::
Drži podatki so gor vendar se ne postavi v win7 . Ostalo lahko dobim dol.
Aja mašina je padla v vodo zaradi poplave (os. plošča uničena ,procesor zakurjen)
https://photos.app.goo.gl/RtViGrpE8b8m8...
https://photos.app.goo.gl/p4sz81DkhpnTw...
Baja ::
zanimivo, win7 bi se naceloma mogli postaviti v drugi masini. si probo varni nacin? lahko probas tudi obnoviti instalacijo z nemstitvenega medija.
po moje ce ti uspe zbootat sistem s starega diska, boš prišel tudi do podatkov na prenosnem
Damjan Klinc ::
ne da mi opcije za varni način
Baja ::
Press and hold the power button for 10 seconds to turn off the computer.
Turn on the computer.
Tap the F8 key until you see the Advanced Boot Options menu.
Use the arrow keys to select the desired safe mode and press Enter .
The computer reboots Windows 7 into safe mode.
Damjan Klinc ::
Samo
1.Lunch startup repair
2.Start windovs normaly
to je to
zajtam123 ::
kolikor jaz poznam WD zunanje diske ti brez gesla ne bo ratalo prit do podatkov.
Žal
crniangeo ::
Sam sem to enkrat rešil tako, da sem virtualiziral disk od windows 7, ter na virtualboxu kreiral virtualko in pointal disk na tistega virtualiziranega.
Men je delalo.
Convictions are more dangerous foes of truth than lies.
Baja ::
Damjan Klinc je izjavil:
Samo
to je to
kaj se zgodi če klikneš 1. opcijo? dobiš več možnosti?
Damjan Klinc ::
me dela v tem je problem
Baja ::
crniangeo ti je dal dober predlog.
ker nisi povedal ne stare konfiguracije ne nove, je mogoče v tem problem. sistemski disk probaj dati vsaj v priblizno enako generacijo.
bi pa znala virtualizacija tudi ta problem rešiti.
WiFi ne deluje
163094 (2563) buttcrack
TOSHIBA satellite L650-11r WLAN driver
153250 (3040) Stupo
Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikon
52690 (2646) riba43
nasvet za XP
244271 (3863) [t502]
w2k boot - blue screen
Oddelek: Operacijski sistemi
81972 (1876) matevzm
