Apache config
Apache config
TechFreak ::
Imamo server, staticni IP, zakupljeno domeno in nalozeni phpDev5.
httpd izgleda takole:
VirtualHost XXX.XXX.XX.XXX
ServerAdmin xxx@email.si
DocumentRoot /homepage/
ServerName www.xxx.cjb.net
ErrorLog logs/dummy-host.example.com-error_log
CustomLog logs/dummy-host.example.com-access_log common
AddType application/x-httpd-php .php .htm
/VirtualHost
Poleg tega sem v WINDOWS\system32\drivers\etc
v hosts dodal XXX.XXX.XX.XXX localhost www.xxx.cjb.net
in skopiral file php4ts.dll v System32.
Javi pa na tem naslovu
Forbidden
You don't have permission to access / on this server.
Apache/1.3.26 Server at localhost Port 80
ceprav folder ni prazen!
Kaj je se za postorit?
LP, M:D
nsignific ::
Hm apache za windowse sm meu ful doug nazaj, ampak se mi zdi da mors folder doloct z windows oznakami, ne linux? Torej polna pot C:\document root\ ne pa unix pot /document root/.
TechFreak ::
Tudi mozno, ni pa to vzrok nefunkcioniranja!
Dajte no folk....razpisite se kaj!
LP,M:D
pivmik ::
nsignific ima prav, zaradi tega ti ne dela.
DocumentRoot /homepage/ --- NAROBE
To je prav, primer:
DocumentRoot c:/webpages
Če so presledki v poti do docroot dej celo pot v narekovaje:
DocumentRoot "c:/moji dokumenti/webpages"
Uporabljaj SLASHE / ne pa BACKSLASHE \
A delaš eno porno stran ki imas toliko te iksov noter x :D ?
LP, Gregor GRE^
Fedora Core 2 in Apache problem
Oddelek: Izdelava spletišč
91618 (1505) atlet
dve spletni strani??
312917 (2466) MRB0rYS
VirtualHost oz. navidezne domene v apache
253157 (2855) Jackass
Apache
111755 (1639) Skrat
FOX server in virtualna domena?
61887 (1789) Ziga Dolhar
