weird science
weird science
Marjan ::
Gaby
Poglejte Nobelovega nagrajenca za podrocje biologije.
http://almaz.com/nobel/2003-prizes.html
BIOLOGY
C.W. Moeliker, of Natuurmuseum Rotterdam, the Netherlands, for
documenting the first scientifically recorded case of homosexual
necrophilia in the mallard duck.
REFERENCE: "The First Case of Homosexual Necrophilia in the Mallard Anas
platyrhynchos (Aves: Anatidae)" (http://www.nmr.nl/DSA8-243.pdf) C.W.
Moeliker, Deinsea, vol. 8, 2001, pp. 243-7. Photographs can be viewed at
http://www.nmr.nl/deins815.htm
Double_J
Ja, kaj misliš, da so samo Homo Sapiensi lahko nekrofili.
On 5 June 1995 an adult male mallard (Anas platyrhynchos) collided with the glass façade of the Natuurmuseum Rotterdam and died. An other drake mallard raped the corpse almost continuously for 75 minutes. Then the author disturbed the scene and secured the dead duck. Dissection showed that the rape-victim indeed was of the male sex. It is concluded that the mallards were engaged in an �Attempted Rape Flight� that resulted in the first described case of homosexual necrophilia in the mallard.
Every Ig Nobel Prize winner has done something that first makes people LAUGH, then makes them THINK.
Pa to je treba tudi vedet. Da je tisti tip dobil tole. Navadne nobelove nagrade za biologijo ni, niti je ni za matematiko.
EZ2BHard
KSPTOS/ROTFL!!! Meni to deluje inscenirano. C.W. Moeliker se slucajno znajde na pravem mestu ob pravem casu, tako da fotografira storilca in zrtev pred in med dejanjem, ampak kljub temu, da grozodejstvo traja celih 75 minut, C.W. Moeliker v tem casu nikogar ne poslje po video kamero, da bi se nespodobno dejanje dokumentiralo kot se spodobi? In to kljub temu, da dela v muzeju, ki ga dnevno obisce vsaj nekaj oseb, ki imajo s sabo video kamero? Hmm.
Zanimive so tudi ostale Ig Nobelove nagrade. Ravno gledam posnetek z letosnje podelitve, je poucen in zabaven, vsekakor priporocam ogled. Baje je C.W. Moeliker na posnetku, komaj cakam, da slisim zahvalni govor!
IG Nobelove nagrade
Posnetek podelitve :)
Identifikacija morske živali
92131 (1874) KoMar-
Podeljene IG Nobelove nagrade za leto 2009
166161 (5212) gzibret
malo nostalgije: kateri je najhitrejši/najboljši socket A procesor
71405 (1276) Blinder
Podeljene 17. Ig nobelove nagrade za leto 2007
326466 (4799) BigWhale
matematika
Oddelek: Šola
81242 (1156) Death
