Firefox backup
Firefox backup
BRBR ::
Menda če si skopiram prodil folder, je videti da si skopiram vse mogoče kar obstaja, tudi cookije ?
glede na to da je tam znotraj tudi cookies.sqlite.
EDIT: menda je ista scena za thunderbird, skopiraš profile folder in imaš backup vsega including vse maile?
  • spremenil: BRBR ()
xxxul ::
ko skopiras profil skopiras vse nastavitve, vkljucno z cookiji, passwordi, history, tabs, etc, celo plugine (mors pa it v novem FF na plugins da jih prvič zažene). mislim da celo certifikate prenese...
Tako je. Ko kopiraš celo mapo "profil", je zraven vse. Takšna kopija je lahko več (deset) gigabajtov velika ...
robert2doxon ::
Having a backup is one of the most important steps to take to ensure that if a ransomware attack does infiltrate your systems, you can still recover with minimal damage. If ransomware still manages to corrupt or encrypt your files despite all your preventive measures, recovery from a backup is the most effective method to restore data and workloads. Recovery from backups is even more resource efficient that using a decryption tool, that is, if you find one.
office 365 backup
  • predlagal izbris: ToniT ()
Ponovna namestitev sistema
111665 (1528) medenko
Trojan.Gpcoder.G (strani: 1 2 )
98203092 (196280) Cold1
backupi za glavne programe
121535 (1190) dmwajtjt
Thunderbird prašanje
Oddelek: Programska oprema
81958 (1809) gregaster
Logitech MouseWare bug (?)
272611 (2207) Swiwer
