Forum » Programiranje » max_user_connections DB
ideep ::
Zdravo,
Mi pove kdo kako kličem v bazi “max_user_connections” opcijo na višjo vrednost, oz.. kako flush-am max_user-connections
Zanima me,če je to to?
FLUSH [NO_WRITE_TO_BINLOG | LOCAL] {
flush_option [, flush_option] ...
| tables_option
flush_option: {
BINARY LOGS
| ENGINE LOGS
| ERROR LOGS
| GENERAL LOGS
| HOSTS
| LOGS
| PRIVILEGES
| OPTIMIZER_COSTS
| RELAY LOGS [FOR CHANNEL channel]
| SLOW LOGS
| STATUS
| USER_RESOURCES
tables_option: {
TABLES
| TABLES tbl_name [, tbl_name] ...
| TABLES WITH READ LOCK
| TABLES tbl_name [, tbl_name] ... WITH READ LOCK
| TABLES tbl_name [, tbl_name] ... FOR EXPORT
} ideep ::
Error
SQL query:
FLUSH USER_RESOURCES
MySQL said: Documentation
#1227 - Access denied; you need (at least one of) the RELOAD privilege(s) for this operation
Tole mi napiše..
Error
SQL query:
GRANT RELOAD ON *.* TO 'xx'@'localhost'
#1045 - Access denied for user 'cpses_otjbqr7we0'@'localhost' (using password: YES)
spodaj napiše kr enga userja ki sploh ni moj se drugače imenuje
SQL query:
Tole mi napiše..
Error
SQL query:
- spremenilo: ideep ()
ideep ::
Error
SQL query:
SHOW GRANTS FOR 'xx''@''%'
#1044 - Access denied for user 'cpses_otjbqr7we0'@'localhost' to database 'mysql'
SQL query:
| » | problem pri sprembi root gesla v MySQL v UbuntuOddelek: Pomoč in nasveti | 1730 (1310) | killa bee |
| » | mysql, insert, values, selectOddelek: Programiranje | 2375 (2202) | slosi |
| » | PHP in mySQLOddelek: Programiranje | 2347 (2055) | rasta |
| » | TXT -> bazaOddelek: Programiranje | 1298 (1185) | Quickbeam |
| » | Rezanje tekstaOddelek: Programiranje | 1293 (1202) | darh |
