MariaDB | DECLARE maxid INT(11);
HotBurek ::
Čer...
Tole sem že imel rešeno, pa nimam več source fajlov, in ponovno iščem...
Kako deklarirati variable maxid pri Mariji (ne tisti, katera je bila na današnji dan v nebo vzeta), rabim INT.
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 6098
Server version: 10.5.5-MariaDB-1:10.5.5+maria~buster mariadb.org binary distribution
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]>
MariaDB [(none)]> USE database_1;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
MariaDB [database_1]> DECLARE maxid INT;
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'DECLARE maxid INT' at line 1
MariaDB [database_1]> DECLARE maxid INT(11);
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'DECLARE maxid INT(11)' at line 1
MariaDB [database_1]> DECLARE trolll INT;
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'DECLARE trolll INT' at line 1
MariaDB [database_1]> DECLARE x, y INT DEFAULT 0;
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'DECLARE x, y INT DEFAULT 0' at line 1
root@debian:/# iptraf-ng
Please resize your window
RedDrake ::
DECLARE dela samo v stored procedurah in funkcijah afaik?
SQL vprasanje (strani: 1 2 )
Oddelek: Programiranje
6810379 (7058) BivšiUser2
[MySql]Sintaksa poizvedbe
62335 (2256) KernelPanic
php, napake in napake :S
Oddelek: Izdelava spletišč
171922 (1679) preem
SQL Error
141531 (1392) Lukas991
Napaka pri MySQL pri postavitvi foruma
72123 (2039) DJ-DUST
