[c++] Dve niti noceta komunicirati
goranv ::
Namen je ustvariti dve niti, katerima posljem njen id in od druge niti. Nato vsaka nit sama sebi poslje dva msg. Problem je nobena nit mi nic ne izpise, razen ce dodam Sleep( 10 ) v funkciji Start() dobim samo dve sporocili
[id: 0] ldwOtherId: 8844
[id: 0] ldwOtherId: 9164
#define THRD_MESSAGE_START				WM_USER + 1
#define THRD_MESSAGE_SET				WM_USER + 2
#define THRD_MESSAGE_GET				WM_USER + 3
#define THRD_MESSAGE_END				WM_USER + 4
#define THRD_WPARAM_SET_OTHER_ID		1
#define THRD_WPARAM_SET_OWN_ID			2
HANDLE	ghMutex;
LPCTSTR lpszMutex = L"enassa";
DWORD	ThreadFunc(		_In_opt_	PVOID	lp	)
	MSG		lmsg;
	DWORD	ldwOwnId	= 0,
			ldwOtherId	= 0;
	bool	lInitFinish	= false,
			ldone		= false;
	HANDLE	hMutex	= OpenMutex( MUTEX_ALL_ACCESS, FALSE, lpszMutex );
	while( !ldone )
		while( GetMessage( &lmsg, 0, THRD_MESSAGE_START, THRD_MESSAGE_END ) > 0 )
			switch( lmsg.message )
				case THRD_MESSAGE_START:
					if( lInitFinish )
						WaitForSingleObject( hMutex, INFINITE );
						printf( "[id: %d] [%d]\n", ldwOwnId, GetTickCount() );
						ReleaseMutex( hMutex );
						ldone	= true;
					break;
				case THRD_MESSAGE_SET:
					switch( lmsg.wParam )
						case THRD_WPARAM_SET_OTHER_ID:
							ldwOtherId	= (DWORD)lmsg.lParam;
							printf( "[id: %d] ldwOtherId: %u\n", ldwOwnId, ldwOtherId );
							if( ldwOwnId != 0 )
								PTMSG( ldwOtherId, THRD_MESSAGE_GET, TRUE, 0 );
							break;
						case THRD_WPARAM_SET_OWN_ID:
							ldwOwnId	= (DWORD)lmsg.lParam;
							printf( "[id: %d] ldwOwnId: %u\n", ldwOwnId, ldwOwnId );
							if( ldwOtherId != 0 )
							break;
					break;
				case THRD_MESSAGE_GET:
					// osnovne vrednosti nastavljene
					if( lmsg.wParam == TRUE )
						lInitFinish	= true;
						printf( "[id: %d] lInitFinish: %d\n", ldwOwnId, lInitFinish );
						PTMSG( ldwOwnId, THRD_MESSAGE_START, 0, 0 );
					break;
				case THRD_MESSAGE_END:
					break;
			Sleep( 1 );
	printf( "[id: %d] ExitThread\n", ldwOwnId );
	CloseHandle( hMutex );
	ExitThread( 0 );
Test1 :: Test1()
	pHandles[0]	= pHandles[1]	= NULL;
void	Test1 :: Start()
// private:
//	Thread		thr[2];
//	HANDLE		pHandles[2];
	ghMutex	= CreateMutex( NULL, FALSE, lpszMutex );
	if( ghMutex == NULL )
		printf( "ghMutex\n" );
	thr[0].Create( ThreadFunc );
	thr[1].Create( ThreadFunc );
	thr[0].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OWN_ID, thr[0].GetId() );
	thr[1].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OWN_ID, thr[1].GetId() );
	Sleep( 10 );
	thr[0].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OTHER_ID, thr[1].GetId() );
	thr[1].Send( THRD_MESSAGE_SET, THRD_WPARAM_SET_OTHER_ID, thr[0].GetId() );
	Sleep( 10 );
	pHandles[0]	= thr[0].GetHandle();
	pHandles[1]	= thr[1].GetHandle();
	WaitForMultipleObjects( 2, pHandles, TRUE, -1 );
	CloseHandle( ghMutex );
// Thread.h
typedef struct ThreadInfo
	HANDLE		h;			// handle
	DWORD		id;			// id thread
	PVOID		lp;			// lparam thread
} THREADINFO, *PTHREADINFO;
class Thread
	ThreadInfo		ti;
public:
	 Thread();
	~Thread();
		@param nFlags, 0 - run, CREATE_SUSPENDED - paused
	_Success_( return == true )
	bool	Create(
		_In_		LPTHREAD_START_ROUTINE		pFunc,
		_In_opt_	PVOID						nParam	= nullptr,
		_In_opt_	DWORD						nFlags	= 0			);
	void	Send(
		_In_	DWORD		ndwMsg,
		_In_	WPARAM		nwParam,
		_In_	LPARAM		nlParam		) const;
	_Success_( return > 0 )		DWORD	GetId() const;
	_Success_( return > 0 )		HANDLE	GetHandle() const;
// Thread.cpp
Thread :: Thread()
	ti.h	= NULL;
	ti.id	= 0;
	ti.lp	= 0;
Thread :: ~Thread()
	if( ti.h != NULL )
		CloseHandle( ti.h );
		ti.h	= NULL;
		ti.id	= 0;
		if( ti.lp != nullptr )
			HeapFree( GetProcessHeap(), 0, ti.lp );
			ti.lp	= 0;
bool	Thread :: Create(
	_In_opt_	PVOID						nParam,
	_In_opt_	DWORD						nFlags	)
	ti.h	= CreateThread( nullptr, 0, pFunc, nParam, nFlags, &ti.id );
	if( ti.h != NULL )
		return true;
	return false;
void	Thread :: Send(
		_In_	DWORD		ndwMsg,
	PTMSG( ti.id, ndwMsg, nwParam, nlParam );
DWORD	Thread :: GetId() const
	return ti.id;
HANDLE	Thread :: GetHandle() const
	return ti.h;
[Java] Objekt poslan k metodi v kakšnem stanju?
Oddelek: Programiranje
211923 (1370) shadeX
slovenski prevodi programerskih izrazov
494578 (3513) sverde21
Komunikacija med thread-i
134381 (4187) zlatko
OpenGL orr v ansi c
122167 (1955) igor12
Odpiranje dat.exe v VB
123851 (3644) webblod
