Forum » Kriptovalute in blockchain » kripto splošna debata
Trump je master prevarant, se ne bi čudil če ima strategijo "first meme coin pump&dump -> buy cheap BTC/ETH -> later regulation to increase BTC/ETH price -> profit" :)
- spremenil: Lonsarg ()
Špricer ::
Za opomin, da se nikoli ne verjame politiku. Vse kar izreče je avtomatsko laž.
Pusti do 2027. Bo takrat bolje, če ne bo hude regulacije. Sicer si pa zamudil vlak.
Mah. Ni šlo pod 100k in da dokupim še kaj, če bi bilo -15% pa sploh all-in. Skos neki -5.2% pa nazaj gor... ampak v tem crabbingu sem največ spušil, tko da bolš da zaprem vse skupi.
- spremenilo: Špricer ()
Špricer ::
Trump Does Not Repeal Biden's Executive Order 14067 on Digital Assets
Donald Trump, the 47th President of the United States, revoked 78 executive orders on his first day in office. However, Executive Order 14067, introduced by President Joe Biden, remained untouched. This decision has sparked significant debate, particularly among cryptocurrency advocates, as the order has been linked to policies seen as restrictive to the crypto industry.
Financial analyst Adam Cochran highlighted this omission, emphasizing that the executive order grants regulatory agencies broad authority over cryptocurrency-related businesses. Cochran criticized the administration for maintaining what he referred to as "Operation Choke Point 2.0," a policy some allege restricts crypto firms' access to banking services, similar to the original Operation Choke Point targeting high-risk industries.
tilio ::
Za perspektivo...iz članka RTV:
Bolano...
Trumpov kriptokovanec se je medtem le nekaj dni po izdaji tako močno podražil, da je bila njegova tržna vrednost dvakrat višja od Krkine.
Bolano...
- spremenilo: tilio ()
Neon87 ::
kriptobog ::
ferko2 ::
Bom šel not z vsemi preostalimi evri ki so še na bitstampu... mogoče še naloudam iz banke. jbg vseen bolš xlm za 10-20% plusa kot pa meme pa pušiona.
Kripto ::
zalozite se s stellarjem dokler je se cas.
Ali prihaja kakšna novica, kaj bi bil razlog za potencialno rast?
Da. Konec meseca
Do kje se bo pumpalo XLM?
Wealth is mindset!
Se pumpa kaj točno?!?
XLM pa res ne oz. vsaj še ne. Praktično je skoz v rdečem. Ne rečem, da ob splošni evforiji ne bo šel tudi ta gor.
Neon87 ::
kriptobog ::
Neon87 ::
tilio ::
Se pumpa kaj točno?!?XLM pa res ne oz. vsaj še ne. Praktično je skoz v rdečem. Ne rečem, da ob splošni evforiji ne bo šel tudi ta gor.
Jaz ga imam ze zdaj skoraj 100% v profitu. Amapk itak je vseeno- Tudi za xrp me niste jemali resno ;)
XLM je nastal iz XRP potem, ko se Jed McCaleb ni strinjal več s tem kar so si pri Ripplu želeli naredit iz XRP-ja:
McCaleb was likely concerned about the level of centralization within Ripple. Ripple Labs held a significant portion of XRP tokens, which raised questions about the network's decentralization
Zakaj bi XLM imel kaj vrednosti, če že "imamo" XRP? Pa ne mi rečt decentralizacija, ker je veliko boljših platform.
Ali je prostora dovolj za oba produkta? Kaj ima XLM kar XRP nima?
To je zdaj res mimo izjava, ker se pogovarjamo o pump-u sedaj. Tudi jaz sem v profitu, ker sem ga kupil že boh ve kdaj, ko je bil manj vreden kot danes; enako XRP (ki sem ga manjši del nazadnje decembra prodajal pri 2,72 evra, zdaj pa je malo čez 3). Ampak zakaj bi zdaj bil pump?
- spremenil: Gregor P ()
kriptobog ::
To je zdaj res mimo izjava, ker se pogovarjamo o pump-u sedaj. Tudi jaz sem v profitu, ker sem ga kupil že boh ve kdaj, ko je bil manj vreden kot danes; enako XRP (ki sem ga manjši del nazadnje decembra prodajal pri 2,72 evra, zdaj pa je malo čez 3). Ampak zakaj bi zdaj bil pump?![]()
Saj ga ne rabiš kupit. Jaz bom pa še dodatnih 100k not porinil pa je. Še namesto tebe
kronos_10_ ::
Važno da pumpne :)
Hvala za namig. Porinil tudi sam nekaj noter.
- spremenil: kronos_10_ ()
Neon87 ::
kronos_10_ je izjavil:
Važno da pumpne :)
Tudi jaz, nekje na dobrih @0.41€, pa da vidimo :)
wajdouc ::
Že na več straneh govorijo, da bo konec meseca xlm zrasel, kar je glede na špekulacije in prihajajoči alt season dobra novica za tiste, ki pred novembrom niste nič kupovali.
Sedaj je čas za nakup xlm, ko pumpa začne vleči, bo prepozno.
To lahko rečeš potem praktično za vse ISO20022 kovance ...
globoko grlo ::
Sam verjetn ne bo prehitel xrpja, ane. Se prav ene 3x, 4x mogoce ob pogoju, da vse raste, ane.
tilio ::
globoko grlo je izjavil:
Zakaj naj bi zrastel?
Neon87 ::
Najbrž bo pri tem MC lahko XLM lažje zrasel za recimo 25% iz 0.4 na nekje 0.53, kot XRP iz 3 na 4... pač špekulacija, sploh pa če to kripto milijonarji pravijo, da je dobra poteza, jim je za zaupat.
- spremenil: Neon87 ()
kronos_10_ ::
Saj ga ne rabiš kupit. Jaz bom pa še dodatnih 100k not porinil pa je. Še namesto tebe![]()
Ali bo to za držat ali ob pumpi prodat? :) Hvala
Špricer ::
Vsi nekako pametni. Kaj vam ni jasno? Pada vi se pa šopirite o neki pumpi in xlm...noro res. Vam ni jasno da vas je Trump nategnil? Z besedami in meme kovancem
Sedaj pa še špekulanti shilajo z boizi na Twitterju in Instagramu. Ko se govori o rasti prodaj takoj. Ko pada kupuj na dnu.
Kripto ::
Pripravite se, prihajajo triljoni...masovna pumpa...smo šele na začetku bull runa. Tako pravijo na YouTubu.
Wealth is mindset!
Anney ::
Gledamo ta EKG že nek časa.
bbobst ::
Zdravo .
Na binancah sem kupil nekaj ACT jev sedaj pa vidim ,da ne morem z njimi nič početi, ker piše, da so nerazpoložljivi.
Zakaj?
Zakaj?
AMD Ryzen 7 5800X + Be quiet! DARK ROCK PRO 4, MSI MPG X570 GAMING PLUS
Palit RTX3070 Gaming Pro OC 8 Gb , Team Group T-Force Zeus 32GB Kit (2x16GB)
Team Group T-CREATE NVMe SSD, Corsair CX650M, Be quiet! Silent Base 601
bonanno ::
čeprov imam tudi sam coinse, bi rad da se vse skupaj sesuje samo da vidim razne fotrove sincke iz mansrad, ki so ratal experti za investiranje - jokat hahaha
bbobst ::
Rešeno, sem pozabil, da imam odprto naročilo na doseženo ceno.
No, super. Ker jaz sem na lagerju pripravljene že bolj črne scenarije; šele nekje bolj na koncu bi prišel še do te možnosti
Špricer ::
Kdor je pameten bo prodal BTC. Saylor vam je lepo dal svoj liquidity. Jaz sem prodal na 70000 pa sem v plusu na denarnici. Ostali forumaši pa le imaginarne cifre.
Počasi se piramida ruši. To je to boiz.
Pameten. Odlično. Kupuj ko bo na dnu. BTC do 16k scenarij je uresničljiv v kolikor pride panic sell. Tudi s strani institucij. Jaz pa saylorju ne bi zaupal v varstvo niti svojega psa. Kaj šele BTC. On je glavni pušionež dot.com balona 2000. 7 milijard v nekaj dneh...očitno je res hazarder in debil.
No, super. Ker jaz sem na lagerju pripravljene že bolj črne scenarije; šele nekje bolj na koncu bi prišel še do te možnosti![]()
deco16 ::
Imaginarne cifre mi lepo poplačujejo kredit ;) Samo neki me skoz o izvoru denarja sprašujejo ...
ferko2 ::
Hazarderji pa prosim hvala.
To je Link za vas
https://www.geckoterminal.com/category/...
Če vidiš kovanc tukaj je vlak že odpeljal.
GregiB ::
Kaj je zej s tem najlepšim, najboljšim, najbolj zaželenim meme kovancem naše najljubše prve dame? Rug Pull?
Kripto ::
Ja rug pull izmed najbolj zaželjenih ljudi. Ampak niso oni krivi ne ...
Kupovanje meme coins je kaj?
Wealth is mindset!
globoko grlo ::
Kaj japonci drkajo? Next 24h kriticnih, tko tuljo po yt, a kdo kj vec ve?
Kripto ::
Dvig obresti?
Wealth is mindset!
ferko2 ::
Jaz sem že 4% dol odkar sem xlm kupu. Tik pred začetkom beara in daljše kripto zime ... Fak.
A kdo čaka trumpcoin drugo pumpo? Zdaj je $35, ena pumpa še bo, to niti ni vprašanje -- samo kdaj? Itak je pa kovanec fcked ker ga ima team tolk da te srat prime in samo dumpajo kadar lahko.
Kripto ::
4% dol ni nič...
Wealth is mindset!
kriptobog ::
Kaj pa pricakujes? Da kupis in gre naravnost x10 gor?
tilio ::
Jaz ti svetujem, da DCA-jaš. Tako pravi Tronald Dump.
Neon87 ::
Kaj pa pricakujes? Da kupis in gre naravnost x10 gor?![]()
Meni tudi ni prijetno ko takole pada, ravno po nakupu.. kdaj bi naj prišla dobra novica za XLM?
