kripto splošna debata
Prebranac ::
strawman je izjavil:
merlin2 je izjavil:
Partnerstva
https://www.thecryptoalert.com/post/swi...
Tole je pa tudi pogrevanje stare novice, ki je bila zavrnjena z obeh strani.
Over the course of the past year, there have been a lot of rumours flying about in regards to the potential collaboration between both Ripple and SWIFT. But in the end, this was just speculation and both companies firmly denied the rumours that there were any past discussions between them. As reported by Coindoo, the CEO of Ripple, Brad Garlinghouse, said that both companies were direct competitors in the remittance space. He says down in an interview with Bloomberg which resulted in Garlinghouse criticising SWIFT and thus ruled out any potential talks for the two firms. The CEO made is clear that Ripple is not hoping to work with SWIFT but instead, overtake it.
Ne nasedajte Ripple nategom. Trenutno po skoraj 10 letih nima niti ene uporabe, tehnološko pa zaostaja za skoraj vsakim novim projektom. Denar gre v pumpanje takih govoric kot jih objavljajo dežurni fanatiki.
Jp. P n d scena. Ko bi bil tak dober ni potrebe po promociji. Večina novic na neresnih straneh je plačanih s strani podjetij v aziji. Zato pa xrp poskuša vspostavljati neko mrežo transakcij v obskurnih državah. Enako velja za podsaharsko afriko.
Senior Dev ::
Še malo in Lambo.
PrihajaNodi ::
Senior Dev je izjavil:
Še malo in Lambo.
Lambo in penzija coin. Xrp next penzija coin?
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Fly2Sky ::
PrihajaNodi je izjavil:
Še malo in Lambo.
Prej bo KASpa matrijal za penzijo kot xrp
Binance: https://www.binance.com/?ref=16631711 (Ref.ID: 16631711)
https://www.mexc.com/register?inviteCode=1bZR5
Kripto ::
Pri bitcoinu vidimo zelo lep vzorec obnašanja, tipičen za obdobje preden gre v masivni bull run. Manjka še potrditev.
Wealth is mindset!
Prebranac ::
Kripto je izjavil:
Ni še konec 2024...potrditev tak sama bo enkrat.
Prebranac ::
Dvomim pa sicer da bo odboj na 25000. Samo poglej volumene!! Ne vem kaj se fsi izogibate volumenom. Jasno je da dotoka dinarof v kripto ni. Fsi samo hodlajo po statistiki in čekajo na prodajo. Sentiment se spreminja. Napizdenih ljudi bo malo. V 6 letih nategov, ico, onecoin, xaurum, defi in nft, play to earn je konec. Osel gre samo 4krat na led! Dopovejte si, da dokler ne bo gospodarske rasti tudi volumenov ne bo s strani institucij!
Ne pozabiti na stabilce luna, ftx...
  • spremenilo: Prebranac ()
Prebranac ::
Tudi tetheru se že več let majejo tla. Ko bo težava z likvidnostjo gre fse v kurac.
PrihajaNodi ::
Imam 100 eurov viska. Kaj naj kupim?
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Senior Dev ::
Nekaj za piknik. Danes bo lepo vreme. Za 100€ bi moral dobiti dovolj robe za 5 ljudi, če kupiješ pametno. Nepozabno bo!
Kripto mesi ::
Štrik za sebe in warkrafta. Se ostalo bo.
Senior Dev ::
Zate pa en zeleni Lambo, da zapreš gobec vsem, ki ne verjamejo v tvoje strategije investiranja.
PrihajaNodi ::
Vrgel 50 eur v cardano 50 v icp kar bo pa bo
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Kripto ::
Karkoli bi kupil od BTC, ETH, XRP, ADA, MATIC...vse ti lahko naredi 5-10x. Načeloma nimaš kaj falit. Za pumpe 50x-1000x pa je treba ob pravem trenutku gemblerski pristop metanja v kovance, ki se jih bodo izmislili.
Wealth is mindset!
enemon ::
Kripto je izjavil:
Pust Nodija, spet trola.
PrihajaNodi ::
Zakaj trolam? Ker mecem stotake not? Nimamo vsi po 6 miljonov na racunu
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Prebranac ::
Ne razumem kaj je moje trolanje? Da vas opozorim na realne kazalce. Fsi ste najprej bluzili z ico. Potem nepremičnine onecoin. Xaurum vezan na zlato. Nftji, play to earn, defi menjalnice.... nobene uporabne vrednosti. Samo napizdevanje retaila.
Ponci shema piramide.
enemon ::
A niso v Romuniji ful visoke plače pa to? Pol bi lahko mal več noter vrgu.
PrihajaNodi ::
Fse je relativno
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
enemon ::
Ko omenjaš prednosti življenja v Romuniji, ponavadi ni tako. :D Warkraft je tudi eden izmed tvojih vzdevkov? Kje je aquafriend, on je detektor za dvojne accounte.
globoko grlo ::
Da ni Nodi v španoviji z Andrew Tatom al kaj je že un? To bi pojasnilo Nodijeve vložke v kripto :)
strawman ::
XVG, baje so en mesec pred tem da jim končno rata iz zraka črpati elektriko in z njo preko kripto kovancev polniti telefone.
Dokaj bedno v cryptu zadnje cajte mojih 10k caka na aplikacijo bota ki dela donose 5 do 20 postov pa kar ni kandidatov
globoko grlo ::
evo, next big thing oz 6 njih
PrihajaNodi ::
Dobr da sem pred tole pumpu kupu. Xvg naj bi pa izdal wraith v 2.0
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
perci ::
Pred leti so govorili, da bo od 100 kripto projektov 1 uporaben. Sedaj vidimo, da so bili zelo optimistični.
kriptobog ::
Mato989 je izjavil:
Na trgu mas toliko botov da te srat prime. Stetiraj pa najdi nekaj. Ce mislis cakat, bos prej svojega spisal.
Prebranac je izjavil:
Se malo pa bo konec z usdt
  • spremenilo: kriptobog ()
PrihajaNodi ::
perci je izjavil:
Xrp?
Dej nej ze butne do 2 triljona... fak no k da je problem blackrocku ruknt notr triljon al pa dva
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
kriptobog je izjavil:
Mato989 je izjavil:
Pionex sem nekaj cajta testiral je blo ok z 500eur mogoc bi moral probat z 10k samo tisto mi je delalo na mesec 1% max
Kripto ::
Na preizkušnji so živci...ali bo pretreslo ?
Wealth is mindset!
residual ::
Boti zajebavajo bote ;)
PrihajaNodi ::
dokupil za 50 usd xrp. Kar bo pa bo. Če bo še mal padlo pa spet kupim.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
merlin2 ::
Tolk si pljuval po XRP pa si ga DOKUPIL :))8-)
Sem vedu :))
Tajska222018 ::
31k likvidnost dosežena,likvidnost 29k tudi....BTC se je ustavil natanko na podpori EMA50(D ),izguba te podpore pomeni obisk 27k
Prebranac ::
10 - 12 k here we go. Takrat pa all in
Karen ::
@Warkraft: nisi pravilno razumel Rossija; napisal je 27k, ne 10-12k :D
deco16 ::
Celih 500€ :)
Buy low, sell high. Kar pač kupovanje XRP zdej ni lih.
Tajska222018 ::
Čakal boš do drugega leta ,ugotovil da se 10-12k ne bo zgodila.......kupil BTC drugo leto.BTC pa računam nekako februarja izgubi dominanco in takrat se denar preusmeri v ALTe----in so bolj donosni kot BTC
Tajska222018 je izjavil:
Takrat se sele zacne alt seson
no sicer pa kot zeliš,samo dobro ti želim
Tajska222018 ::
ne pozabit ,da v istem dreku plavamo,zato si med seboj pomagajte
Kripto mesi ::
Citiranje pa ni ravno tvoja močna stran :))
Tajska222018 ::
Glede na to,da hodlaš ti bo popolnoma useeno,ko ga boš prodajal po 6-7USD če si ga kupil po 0,3 0,4 0,5 0,6 0,70
Je pa fino počakat na reakcijo bTC ja,če se le-ta odloči za dump,potegne vse alte dol s seboj in te kovanci,ki so najbolje pumpali ,ko gre BTC dol tudi najbolj dumpnejo
Za alte,meme in ostalo, velja se faza akumulacije
Prebranac ::
Prebranac ::
PrihajaNodi ::
Zakaj pada? So kakdne slabe novice?
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Senior Dev ::
Ti si vložil 40€ v kripto. Druge velike novice nisem zasledil zadnje dni.
Kripto ::
Bitcoin se mora premakniti v rang 70-110k USD potem se bo začela alt season in bitcoin bo počasi izgubljal dominanco. Dokler se bitcoin ne premakne v 70-110k USD močno dvomim v alt season. Ja bodo kakšne izjeme, ampak dvomim v alt season.
Wealth is mindset!
Senior Dev ::
Zdaj je jasno. DOGE bo zamenjal USD - uradno valuto ZDA.
PrihajaNodi ::
Ti si en trol tu
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Kripto ::
Res je tudi, ko bitcoin raste in vmes doživlja korekcije konkretno zbija alte.
Wealth is mindset!
mr_chai ::
Kmalu bomo lahko BTC kupovali po 6k in kruha stradali.
1297 / 1679
