jernejl in ostali: Kaj menite o Transnistriji, Abkhaziji in Južni Osetiji?
Transnitrija je za Ruse izgubljena. Če pride do kakšnega kaosa v Ruski federaciji, znajo Gruzijci vojasko udariti. Torej, le ce se bo ponudila dobra priloznost.
Ukraine Signals Major Weapons Request for Long-Term Offensive Against Russia
WASHINGTON--Ukraine has signaled that it will make major new requests for weapons from the U.S. and its allies, including a long-range missile system Washington has declined to provide, as Kyiv presses a successful offensive that has reclaimed thousands of square miles from Russian forces.
A document shared with U.S. lawmakers and viewed by The Wall Street Journal lists dozens of types of armaments the Kyiv government says it will need to press its offensive into 2023.
Ukraine's list of requirements for "offensive operations" includes 29 types of weapon systems and ammunition. Among them are tanks, drones, artillery systems; more Harpoon antiship missiles; and 2,000 missiles for the High Mobility Artillery Rocket System, or Himars, which the U.S. began providing earlier this year.
https://www.wsj.com/articles/ukraine-si...?
Unikum do zdaj: država, ki je bila napadena, zahteva od drugih držav orožje (to ti da malo misliti kaj se tu od zadaj plete).
kopriwa ::
Ali povabiš drugo državo da brani tvoj teritorij (Sirija-Rusija), ali bolj racionalno, prosiš za orožje zavezniških držav. Če s tem nacistični okupator dobi po pi*ki, je že prav tako.
Ja s čim pa naj se branijo pred steklimi Rusi, s kamni in lesenimi palicami?
Ne razumeš kaj sem hotel napisati.
Povdarek na "zahteva".
Ostali smo kupili!
Ostali smo kupili!
Si pomislil morda, da so po pol leta vojne broke as fuck?
Trenutno ni boljse investicije za Evropo, kot v orozje za Ukrajino. Prej nabijejo ruse, prej bodo izplacane dividende. Ukrajina ima 40 milijonski trg in vec plina kot ga bo Evropa kadarkoli potrebovala.
hbgqzR ::
Ostali smo kupili!
Mislim, da je tvoja zaskrbljenost za zgodovinsko rentabilnost orožarske industrije povsem odveč, zahteva ne izključuje direktnega ali indirektnega plačila. Vse jasno?
sirotka ::
FTad ::
Comandante je izjavil:
Ostali smo kupili!
V primeru, da dobijo Krim nazaj
Ostali smo kupili!
Tudi oni kupijo. Te pomoči niso zastonj. Samo plačevali bodo 100 let itd.
Pozabil sem katera država je trenuto ravno odplačala neko pomoč iz ww2.
FlyingBee ::
Vse skupaj pomeni še močnejšo USA in Kitajsko. Nič dobrega za EU.
New Sphincter Kvartet:
Bostjan_321 ::
Putin - še sladkih 16 let na oblasti?
Težko da še 16 let, še manj pa bodo to sladka. Trenutno mu Ukrajinci dozirajo velike kaplje pelina.
yayo ::
Zanimivo kako se je CNN obrnil od kadar ima novega lastnika. Prej sama liberal propaganda sedaj pa "ne si mislit, da gre Ukrajincem brez problemov".
Hmmm, "zanimivo":
https://mobile.twitter.com/saintjavelin...
Bostjan_321 ::
Hmmm, "zanimivo":
Pa so baje samo prišli rešit bratski narod. Sedaj pa že pozivi k množičnim pbojem ?
To ste verjetno že videli:
Ukrajinske specialne, (NATO-trenirane???) enote v zaledju ruske fronte. Zanimivo, baje govorijo surzyk, mešanico ukrajinščine in ruščine:
En zanimiv komentar: "That was an awesome video, I'm an old infantryman from the 101st airborne and I could recognize the way that operation was conducted,it had a very (non eastern Europe feel) to it ;) "
- spremenilo: Malidelničar ()
Bostjan_321 je izjavil:
Hmmm, "zanimivo":
Pa teh kill em all trolov imajo za izvoz, ne vem čemu se čudite ob takih objavah. Še pri nas jim imaš ogromno. Eni bi v jame metali desničarje, eni levičarje, drugi čefurje.. ni da ni. Tovrstni spletni troli so brez vrednosti za debato. Če naberejo par 100000 fantov, ki so za mizerno plačo pripravljeni možgane in noge pustiti na UKR zemlji, potem ni vrag, da imaš še več online herojev. Je pa žalostno, ko pomisliš iz kakih razmer in družin je ves ta kanonfuter ruski.
Fak, od kje Rusom takšno sovraštvo do bratskega naroda? Resda it takes two to tango, ampak očitno so Ukrajinci ene parkrat prevečkrat med plesom pohodili te bratske Ukrajince, al kaj? Kaj res te Ruse tako vodi v sovraštvo do bratskega naroda. Če bi jaz imel tako bratsko žlahto, bi bežal čez atlantik.
Bostjan_321 ::
Jaz poznam ljudi v Sloveniji, ki še niso videli ne Rusa in ne Ukrajinca v živo.
Ampak sedaj v tem momentu zagrizeno podpirajo Ruse in ploskajo ter dobesedno navijajo ko rusi bombardirajo Ukrajinske ljudi.
Vsa indoktrinacija je pa prišla iz RT in raznih "neovisnih ter resničnih" virov.
Prvi iranski dron je kaput.
https://twitter.com/Liveuamap/status/15...
Debris of Iranian Shahed-136 drone #M214, rebranded as Geran-2 were found in Kupyansk district Timeline:
- U.S. had intelligence
- Russia denied
- Iran denied
- Intelligence was right
koyotee ::
Če moraš kupovati robo od irana in severne koreje pol ves da si v k....
Rear DVD collector!
JTD power!
JTD power!
Biti kaput je cilj drona.
https://www.militaryfactory.com/aircraf...
Shahed-136 is a modern "swarming" drone developed by Iranian industry. At its core, it is a loitering munition designed to neutralized ground targets at range. With multiple instances being launched from an awaiting launcher rack (in stacks of five on down), the aircraft is intended to bypass aerial defenses and overwhelm ground targets, the systems being consumed in the attack run. The drone was revealed through released footage during December of 2021.
Nekatere novice krožijo po Twitterju o predaji vsaj poasmeznih enot na Hersonski fronti, ampak je prezgodaj za kakršnekoli zaključke.
V Khersonu so praktično vse boja sposobne enote, ki jih ruska vojska še premore. Kar tako se ne bodo predali, čeprav če imajo vedno hujše težave z oskrbo in jih počasi pacajo se znajo kljub temu vdati. Kherson bo ruski Dunkerque. Igrali bodo Francoze, mornarice pa tako nimajo več.
Konec oktrobra se mi zdi realen scenarij, odvisno tudi od vremena in od tega koliko helikopterjev bodo ukrajinci poklatili ter kaj se bo dogajalo drugje.
Če se v Khersonu preda kar je ostalo od VDV in ostalih elitnih enot, Rusija nima več vojske. Ima milico z vseh vetrov, praktično brez urjenja in vodstva.
Pretiravate. Rusija ima še kar nekaj kanonfutra. Tudi mornarico imajo še kar obilno.
koyotee ::
Kaj bojo pluli po rekah?
Rear DVD collector!
JTD power!
JTD power!
Ima, samo ne v Črnem morju. Bospor pa zaprt, ker so za Turke v vojni.
https://foreignpolicy.com/2022/03/01/tu...
On Monday, Turkish Foreign Minister Mevlut Cavusoglu closed the Bosporus and Dardanelles Straits to Russian warships, exercising Ankara’s right under Article 19 of the 1936 Montreux Convention.
- spremenilo: Pac-Man ()
FlyingBee ::
Vemo kako končajo okupatorji in njihovi podporniki, samo ne vemo koliko časa bo treba, da se konča. Glede na 4 leta hr,srb,bih vojne, bo še dolgo.
Kaj bojo pluli po rekah?![]()
V Črnem morju imajo še kapacitete. S Kalibr raketami.
Vir: https://www.navyrecognition.com/index.p...
Bostjan_321 ::
Voditelj Čečenije in Putinov zaveznik Ramzan Kadirov je na Telegramu sporočil, da so borci enote Ahmat za ukrajinske sile pripravili "zanimivo presenečenje", poroča ruska agencija TASS.
"Naši borci so za ukrajinske sile pripravili zanimivo presenečenje, ki bo kmalu znano. Ne bom še razkril podrobnosti," je dejal Kadirov.
Čečenski voditelj je poudaril, da posebna vojaška operacija uspešno poteka na območju odgovornosti čečenskih sil, zahvaljujoč "pogumu in junaštvu čečenskih borcev ter izboljšanemu sodelovanju s skupnimi silami".
Dejal je še, da ima za napotitev v Ukrajino pripravljenih deset tisoč borcev, in dodal, da umik ruskih vojakov iz delov regije Harkov "rešuje življenja, kar je dobro".
Skrijte ovce in koze
Nikogar ne zapustimo, Rusija je tu za vedno, so rekli.
https://twitter.com/BBCWillVernon/statu...
Blyatskrieg.
Moscow confirms Russian teachers in Ukr's Kharkiv Region have been arrested by advancing Ukr forces. The teachers had been reportedly sent by Moscow to teach a Rus curriculum in schools in occupied Ukr territory. When Rus forces retreated, it seems the teachers were left behind.
Blyatskrieg.
Skrijte ovce in koze![]()
A se pripravlja ofenziva čečenskih tik tok posnetkov? Oh no.
Wrop ::
Blyatskrieg.
Pa še prepovedano je. Kurijo ukrajinske knjige ter ukinjajo ukrajinski učni program in uvajajo ruskega. 12 let zapora jim ne uide.
Zanimivo, da družbeno kritični delavci še vedno podpirajo naziste, čeprav se vedno hudujejo nad prisilnim poitalijančevanjem in ponemčevanjem Slovencev.
jest10 ::
sigzig ::
Vecino dela opravijo DPR in LPR milice, ruske vojske niti ni tolko na terenu kot si ljudje zelijo.
Malo si bos s temi informacijami.
https://twitter.com/HickPhilistine/stat...
Graph of the 7 day rolling average of total equipment losses from @oryxspioenkop data. Back up to Battle of Kyiv levels, but only for Russia.
Te izgube so sicer najbrz pretezno zavzetje opreme in ne unicenje? Kar je sam se dodatni fiasko za Ruse :)
- spremenil: Lonsarg ()
Zanimivo, da ni nikjer videov mrtvih Rusov.
Še v 1. svetovni vojni so posneli več filmčkov kot pa zdaj v ukrajini...
Bostjan_321 ::
ja, vse je laž. vojne ni, to nam samo židi prodajajo neke računalniško generirane podobe vojne. AI pa geforci pa take fore
kopriwa ::
BTW. Ukrajinci se hvalijo da so osvobodili full ozemlja, celih 2000 km2.
Ampak Rusi kontrolirajo 120.000 km2 ukrajinskega ozemlja, torej gre za drobiž...
mojsterleo ::
pangro ::
Ostali smo kupili!
Tako je ameri naj stopijo na plin no sej lahko pa da ukrajinci že orožje imajo pa samo glumijo tako kot so za južno ofenzivo potem pa surprise surprise.
RedDrake ::
Ti si pa mal' uzadi, ejga.
2kkm2 je bila trditev tam nekje 7./8. 9. To kar so rusi sedaj "zapustili" je 8kkm2+.
Pa še v Khersonu so območja, ki niso bila šteta.
Ni daleč od 10% vseh zasedenih RU območij.
S tem da če gledaš meje iz 24.2. potem je še _MNOGO_ slabše za RU.
Face it, odločenega ljudstva _NE_ moreš premagati in zasesti, že več kot 100 let ne. Dokaz je vse od WW2, preko Vietnama (v vseh inkarnacijah poskusa zasedbe - FRA, USA, CN), Afganistana, bližnjega vzhoda in še marsikje.
Tudi RU ne more okupirati UA ozemelj.
Morda lahko obdrži Krim. Morda. Vse drugo je doomed to fail in je zgolj vprašanje kdaj se bo zgodila Олуя 2.0
FlyingBee ::
Tako je, škoda edino, da bo tudi po koncu vojne čez nekaj let spet kakšen problem, ker se ne sprijaznijo z delitvijo ozemlja.
