mikhaair je izjavil:
Mislite, da je ta novi Madžar bistveno drugačen? Motite se, še vedno desničar, pidoben Orbanu, razlika je, da ni on zakopan z rokami v marmeladi.
Predvsem ni zakopan v dreku ruske zadnjice, kot nekateri tukaj.
Vidim, da so ti argumenti močna stran, čestitke....
Kaže da vam je hudo dolgčas v tem peskovniku!
mikhaair ::
Hvala za čestitke. Včasih bi moral stegnit glavo ven tudi ti.
Začni pri sebi.
  • spremenilo: fikus_ ()
Windlass ::
Pa nee no, so nas že zapazili.:)) Faking stevanovič.
https://x.com/nexta_tv/status/204392208...
⚡️Is NATO cracking? Slovenia is talking about leaving the alliance
The country’s new parliamentary speaker, Zoran Stevanović, said he plans to organize a referendum on leaving NATO.
He believes Slovenia should pursue an independent policy and avoid being drawn into foreign conflicts.
Stevanović also said he intends to travel to Moscow, while insisting his position is not “pro-Russian,” but focused on Slovenia’s interests.
No decision on a referendum has been made yet, and any actual exit from NATO would be a long process.
Earlier, Trump did not rule out that the United States could leave NATO.
Windlass je izjavil:
Takle mamo ko na čelo države volimo kriminalce...
jernejl ::
Stevanović also said he intends to travel to Moscow, while insisting his position is not "pro-Russian," but focused on Slovenia's interests.
Gre po nova navodila in po kovček z denarjem, za poplačilo širjenja ruske propagande.
Windlass ::
jernejl je izjavil:
https://x.com/resni_ca/status/176719076...
Stevanovičev šnelkurs kremeljskih propagandnih linij in to še ne 2 leti nazaj. Matr, mamo mi res negativno selekcijo na visokih političnih položajih.
Edino ne razumem zakaj bi on kot predsednik DZ hodil v Moskvo, a ni to nekako domena zunanjega ministra, če že? To je potem čisto njegova osebna... potreba (nimam boljšega izraza). :))
Goran10 ::
Jp Rusi že širijo govorice da prihaja referendum o nato paktu v Sloveniji. Retardi na fb že ponosno delijo. Češ glejte kaj nam naši mediji prikrivajo ruski pa seveda dobrosrčno razkrivajo resnico. Stevo je pa itak ruski agent. Upam da ga bo Janša imel na povodcu in da nam bo naredil minimalno škode.
https://www.facebook.com/share/p/1DS4jc...
jernejl je izjavil:
Ruski agent je. Verjetno podprt z njihovim denarjem. Takoj ko je bila možnost se je zavihtel na položaj. Upam da ga bo Janša krotil.
jernejl je izjavil:
Je pa Stevo slab nadomestek za Orbana.
  • spremenilo: Goran10 ()
Cela država talec majhne stranke ion njenih volivcev. Nekaj podobnega gledamo na češkem,..
Goran10 ::
Mah stevo s petimi sedeži ne bo dosegel nič posebenega
Stane2 ::
https://x.com/Gerashchenko_en/status/20...
Russian Z-blogger Yegor Kholmogorov believes that Russian authorities are under a demonic assault and are possessed.
This is the only explanation he was able to find for their "irrational behavior", which, he says, "can no longer be described in rational terms."
"All this frenzy of bans, aggression, the complete lack of any sense of proportion or feedback loops.
What we are dealing with is a large-scale demonic assault on the minds of politicians who hold conservative and, to some extent, Christian views.
Demons are quite literally besieging them and pushing them toward absurd actions and mistakes.
In other words, we are witnessing a state of possession - something that even a saint cannot always withstand, let alone Trump or our officials."
Stane2 ::
what is going on here? :O
https://x.com/nexta_tv/status/204411594...
Kadyrov has been awarded an order "For Special Contribution to the Development of Russia's Cement Industry"
"It was a pleasure to receive the award," he said.
Well, sure -- it's not every day your contribution to... cement gets recognized.
Days-without-awards counter reset again.
Windlass ::
Goran10 je izjavil:
Ja lih tolk je, da bo nonstop gobcal o ˝sodelovanju˝ z Rusijo, da bo ves čas malo v etru. To ni za podcenjevat, ker je lahko kar začetek valjenja snežene kepe. Slovenski volilec je pa itak budala in bo na koncu res množično obkrožil kakšen izstop iz NATA (še toliko rajši ker bo JJ za to da ostanemo). Tudi še vsaj ena poslanka Resni.ce (Polona Frelih) je prav tako bolestno fokusirana na to kako je največji problem Slovenije to, da smo na strani Ukrajine in ne Rusije. Tako da tole ni samo Stevanovičev problem. Je zgleda dejansko velik del te stranke pro-rusizem.
Gozdar ma prav. Preveč so vse stranke zdaj odvisne od tega modela. Se že napihuje ko Jabba the Hutt povsod. Slabo smo volili. Pa v bistvu mamo slab volilni sistem, ker vedno prihaja do tega izsiljevanja s strani malih strank.
  • spremenilo: Windlass ()
luli ::
Popravljen je svetovni rekord v sloku v daljino.
https://x.com/i/status/2044079393073455...
wajdouc ::
luli je izjavil:
V igri.
Windlass ::
https://www.rtvslo.si/slovenija/cestitk...
Govno. A se samo js ne spomnim, da bi ruska duma čestitala Klakočarci?:))
Tule na podkastu od Požarja kar dobro predebatirajo Stevanovičevo rusko degeneracijo. Se začne pri 30m in 30s, pa kar nekaj časa razpravljajo. Je kar zanimivo.
jernejl je izjavil:
Od nekod mora financirat sebe in svojo stranko ... S pranjem avtov komaj pokriješ doktorat na FF.
Goran10 ::
Goran10 je izjavil:
Stevči se bo za Rusijo definitvno bolj potrudil kot za svoje volilce, obljube in Slovenijo ampak na njegovo žalost ga zdaj nihče ne jemlje resno ker je pač več kot očitni klovn.
WhiteAngel je izjavil:
jernejl je izjavil:
Ni lepšega kot Rusi ko mečejo denar v prazno.:))
Windlass ::
Dobro, samo kako bo on zdaj nekaj na lastno pest v imenu Slovenije hodil v Moskvo mimo zunanjega ministrstva in neke trajne državne zunanje politike?
Ker je uradno le predsednik DZ, eden najpomembnejših funkcionarjev v državi, poleg predsednice države in predsednika vlade itd. - zato pa bi morale biti stranke, ki so to omogočile, na naslednjih volitvah močno kaznovane (od levih in desnih)!
  • spremenil: Gregor P ()
Windlass ::
Gregor P je izjavil:
ja okej, ma vseeno ne more kar nekaj po svoje vlečt. Tudi Musarca ne more iti v Vietnam in tam na lastno pest govorit nekaj kar je v nasprotju s tem kar je izglasovano v pri nas v državnem zboru.
Dejansko lahko. Nobeden ji tega ne more preprečiti (saj ne da bo NPM to naredila). Razen volivcev na ponovnih volitvah. Tu se pogovarjamo o ljudeh brez kakršnikoli vrednot, vesti, katerim je popolnoma vseeno za vse.
Windlass ::
Mislim razumem da teoretično lahko, ne bo se na njo vrgel varnostnik in ji to preprečil v imenu varovanja naše zunanje politike.
Prej ali kasneje imaš probleme doma potem. Upam da se je nadebudna prihodnja vlada ustrezno zavarovala pri tem ˝paktu s hudičem˝ oz. da ima nek zasilni izhod, kako ga odstraniti, če bo problematičen.
Jaz upam le, da Sova dejansko opravlja svoje delo.
Windlass ::
Sovi (oz. vsaj vrhu le-te) jaz trenutno ne zaupam več. Zaradi vloge, ki jo je kot kaže igral pri volitvah deluje vse komprimitirano. Hočemo ali nočemo, je (suspektno) posredoval v prid rusko-srbske naveze (Jankovič-Golob).
Pomeni, da si Sovi kdaj zaupal? Jaz ji nisem nikoli.
Windlass ::
Good point. Ne, zaupati je slab izraz, tako kot pri politikih. Bolj gre za to, da se je razblinila iluzija nad-strankarskega delovanja (kolikor je to sploh mogoče glede na to da direktorja imenuje aktualna politika). To je mogoče bolj korektno rečt :))
Stane2 ::
https://x.com/JayinKyiv/status/20443085...
More treasonous talk at the Moscow Economic Forum, with Russians starting to admit that the problem is Putin.
Stane2 ::
https://x.com/Prune602/status/204438758...
Russia: "Putin: Calendar and weather factors are the reasons for the decline in GDP"
PS: Ukrajinske rakete preveč dežujejo.
shmandi ::
Razni forumski telebajski še kar trdijo, da se rusija v Ukrajini bori proti ZDA...
Podpredsednik ZDA JD Vance: Ponosen sem, ker ne pomagamo več Ukrajini
  • spremenil: shmandi ()
Kebo ::
A to da zazna premike "bivših" Mosadovih agentov po državi, ja to res ni v pristojnosti Sove.
Med tem desetletje in več ruske propagande... očitno ni težava.
Windlass ::
Kebo je izjavil:
Seveda ni problematično, da zaznava tuje agente v državi. To je zaželeno.
Problematično je:
- da s tajnimi informacijami SOVE operirajo ˝nevladniki˝ za diskreditacijo političnega nasprotnika tistega, ki je nastavil direktorja SOVE
- Nadzorovanje opozicije oz.˝gnezdo˝ nasproti sedeža opozicijske stranke - to je zloraba obveščevalne službe
Stane2 ::
https://x.com/NatalkaKyiv/status/204458...
"I'm concerned that we may truly already be in a recession -- and not just for two months, but for about a year already."
-- Russian economist Andrei Kobiakov
https://x.com/NatalkaKyiv/status/204461...
How to say Putin needs to go without saying it directly
"You can't keep the same people with the same approach for 25 years. People need to be changed!"
-- Russian scientist Robert Nigmatulin
enavlaka ::
Kebo je izjavil:
Problematično je:
Če pridobijo nevladniki te informacije pač niso tajne a ne. Količina gnoja, ki ga pozvroča določena stranka v sloveniji je pač tako velika, da smrdi daleč naokoli.
Obveščevalna služba pa nadzoruje lahko vse. Ne vem kje ti vidiš zlorabo. Če imamo v državi tuje akterje morajo biti na štriku, pa čeprav so v političnih strankah
Sicer so te informacije ušle verjetno iz lastnih vrst **S-a, ko so si pošiljali posnetke naokoli med sabo.
  • spremenilo: enavlaka ()
Saj res, to je ta pajac, ki se je slikal pri Trumpu;((
Ne vem, kaj sem si mislil; tale kerlc je prej član Resnice kot pa, da bo raziskoval ruske rabote po Sloveniji:'(
Windlass ::
enavlaka je izjavil:
To si pa lepo krožno utemeljil. Če te žena vara in jo odkriješ potem te pač ne vara več ker zdaj veš ali kako? :))
SOVA sme izvajati nadzor nad posameznikom (tudi slovenskim državljanom), če obstaja utemeljen sum, da je oseba povezana z dejavnostmi, ki ogrožajo:
- nacionalno varnost
- ustavno ureditev
- terorizem ali ekstremizem
- vohunjenje za tuje države
- organizirani kriminal z varnostnimi posledicami
A misliš da je naključje, da so v vseh izjavah za javnost kot pokvarjen radio ponavljali da gre konkretno za grožnjo nacionalni varnosti? Šlo se je pa v resnici za grožnjo gospodarskemu kriminalu in korupciji. Moja teorija: Nekako so morali legitimirati zakaj nadzorujejo opozicijsko stranko in rabili so alibi zakaj sploh vejo da je bil tam nek izraelec.
Ampak dobro, off topic, gremo nazaj na Ukrajino.
SOVI se jebe. Plače so, vprašanj ni veliko, metrike neke uspšenosti in učinkovitosti ni, pol zadev je pa skritih za kao nekimi 'secret' leveli.
Nimaš boljšega. Noben te ne drma, nič ne rabiš dati od sebe, tuje agente in nevarnosti, ti itak tuje varnostne službe dostavijo na mizo, ostali del pa opravijo novinarji.
Ali pa če bi jih razpustili.
Windlass ::
Poti v Moskvo. Skupina proruskih desničarskih poslancev EP je junija lani po izjavi predsednice Nataše Pirc Musar po pogovorih s predsednico EK, da Ursula von der Leyen dela na vnovični vzpostavitvi odnosov z Moskvo, uradno povprašalo, kakšni so res načrti Bruslja. K začetku direktnih pogovorov z Rusijo je pozivala tudi predsednica Slovenije.
Zunanjepolitična predstavnica EU Kaja Kallas je jasno odgovorila: "Odkar je Rusija začela svojo agresivno vojno proti Ukrajini, je diplomatsko sodelovanje EU z Rusijo omejeno na minimum. Prednostna naloga vsakega stika z Rusijo je poziv, naj preneha s svojo nezakonito agresijo in kršitvijo ustanovne listine OZN ter spoštuje neodvisnost, suverenost in ozemeljsko celovitost Ukrajine.
https://x.com/PeterZerjavicEU/status/20...
Lezejo na plano ko gliste po dežju. Mogoče morajo avtorji telih modrih pozivov k pogovarjanju vprašat kaj so se uspeli razni evropski diplomati zmenit od 2014 do 2022. In kaj je bil izkupiček.
Ukrajinci sedaj letijo daleč za fronto:
Donetsk, from a bird's-eye view 1 AK NGU "Azov"...
No less than 65 km from the LBS.
It seems like this is just the beginning of something bigger...
https://x.com/zloy_odessit/status/20447...
Če jim uspe pregnati Ruse, bo to eden največjih zgodovinskih dogodkov sodobnega časa in bomo slavili tako kot Madžari, ki so se znebili Putinovega avtokrata (ki pa je seveda še vedno nevaren).
OutOfTheBox ::
Če jim uspe
Kadar jim uspe.
Stane2 ::
https://x.com/StratcomCentre/status/204...
Ukrainians hacked yesterday's secret meeting of the Russian Ministry of Industry and Trade on drone production in which Russians cited problems in obtaining even basic components, all now being reliant on China. Russians laugh that they now have to even import copper wire and plastic.
https://x.com/JayinKyiv/status/20453898...
To raucous applause in Moscow, Russian academician Nigmatulin cites that as Russia now ranks 51st out of 53 developed nations on economic parameters, that it's time to oust the leadership responsible for the catastrophe.
  • spremenilo: Stane2 ()
phantom ::
Preston Stewart je imel pogovor o Ukrajini, Madžarskih volitvah in širitvi EU z našo komisarko. Na koncu ga Marta povabi še na izlet v Ukrajino.
:wq
Stane2 ::
https://x.com/NOELreports/status/204545...
Ukraine's SBU has struck three Russian warships in occupied Crimea, including the landing ships Yamal and Azov, and another vessel of unspecified type. The operation has also hit a Grachonok-class patrol boat, radar systems, communications infrastructure, and fuel storage facilities
Stane2 ::
https://x.com/JayinKyiv/status/20454563...
Russian military bloggers enter a world of sh*t, citing Ukraine's incredible abilities in striking FIVE high value Russian infrastructure targets in a single night, all at substantial distances - from the Gulf of Finland and Samara to Crimea.
JohnyQ_ ::
Ko vidim Rusijo goreti, stisnem lajk!
enavlaka ::
Lepe rafinerije lepo gorijo
Goran10 ::
Se pa ruska medijska narativa počasi spreminja ni več tiste udarnosti in grajenja občutka neizogibne ruske zmage sploj potem ko so se zda umaknile. Počasi realnost pronica skozi rusko propagando in prve razpoke so že vidne. Seveda realnost je da je Rusija postala ena velika luknja v katero se bo očitno pogreznil celoten režim samo propagandisti hitijo realnosti nasproti.
o včerajšnjem množičnem morilcu
https://x.com/4E_JL0BEDJL0/status/20457...
https://twitter-thread.com/t/2045758514...
Strelec iz Kijeva je dober primer težav, ki jih Rusi ponavadi prinesejo s seboj. Rojen v Moskvi, z močnimi vezmi z Rusijo. Živel je v Bahmutu in čakal na rusko vojsko, vendar ni ostal v Bahmutu, ko je ta prispela. Namesto tega se je preselil v Kijev, da bi jo dočakal tam.
Sovraštvo do Ukrajine, Judov in svoje “mokre sanje” o etničnem čiščenju je širil po družbenih omrežjih, ki so mu bila na voljo. Na koncu, nezadovoljen z napredovanjem ruske vojske, se je odločil, da bo te osovražene “khokhole” pobil kar sam.
Res je, da je zadnji del nekoliko redek, tudi za njemu podobne.
Vendar pa je splošna težnja – živeti v neki državi, ne da bi se kdaj naučil jezika, ter tiho (ali pa tudi ne tako tiho) sovražiti državo, ki te gosti, in njene prebivalce – dobro dokumentiran vzorec ruskega vedenja. Vidite, on je iz Moskve, kjer “živijo ljudje”.
In on se ne bo učil vašega kmetavzarskega jezika, samo zato, da bi ustregel nekim “domorodcem”. Kakršnikoli problemi, ki jih ima Rus, se po njegovem ne bi nikoli zgodili, če bi živel v Rusiji – vendar on noče v Rusijo, hoče, da Rusija pride k njemu. In ko pride, pobegne še dlje.
Ali se to vedno konča tako? Ne ravno. Rus ni nujno množični morilec. Vendar pa bo Rus v svoj novi dom prinesel toliko Rusije, kot jo lahko. Pritoževanja o “veliki ruski kulturi™”, razmišljanja v slogu “ni vse tako črno-belo”, morda malo prisluškovanja.
Nekaj zgodb o “veliki nerazumljeni Rusiji” za vsakogar, ki je pripravljen poslušati. Nekaj “to je rusofobija in diskriminacija!” vsakič, ko se kdo zoperstavi ruskemu informacijskemu vojskovanju. Cinizem, ki se izdaja za modrost, in vzvišenost, ki se izdaja za strokovnost.
Voljna ranljivosti v obrambi države, dokler obstaja Rusija, ki jo lahko izkoristi.
1341 / 1461
