Windlass ::
ABUSE ON THE FRONTLINE: Stripped, electrocuted and forced to fight each other to the death on camera: New evidence shows how Putin's commanders are torturing their own men
Ne bom lepil članka oziroma besedila ampak zapisal le eno stvar in sicer bodite srečni da živite v Evropi oziroma Zahodu. Jaz ne razumem kako lahko kdorkoli podpira kaj takšnega. Daleč od tega da bi bil Zahod popoln oziroma da bi bilo vse v redu ampak takšnih svinjarij pa v Evropi ne boš videl, da bi se takole spravili nad svoje državljane.
Da takšne stvari počnejo svojih ljudem potem se lahko vprašamo kaj počnejo vojnim ujetnikom na drugi strani. Grozno.
Uh, ja to se že kar nekaj časa dogaja. Če nočeš it juriširat, prirejajo neke take fight-club scene. Do smrti seveda.
Tole so že več kot leto nazaj opozarjali. Tipične ruske sadistične scene.
https://www.reddit.com/r/UkraineConflic...
Stane2 ::
https://x.com/EuromaidanPress/status/20...
Russia's own classified aviation report reads like a catalogue of a military fleet falling apart under the strain of four years of war.
Nine engine failures in just three weeks, all with the same warning -- "metal shavings in oil" or "low oil pressure" -- across Su-34 fighter-bombers, Su-30SM2 fighters, and Il-76 military cargo aircraft at bases spread across Russia. One Su-30SM2 triggered the same alarm twice in five days, on the same engine, and landed on one engine at Millerovo both times.
A FAB-500 glide bomb fell off an Su-34 on takeoff and landed 300 m ahead of the runway.
A military Mi-8 returned to Dzhankoi in occupied Crimea with a hole the size of a sheet of paper punched through its tail boom, likely caused by friendly air defenses.
The document covers just 21 days and 24 incidents. But the patterns it shows are exactly what analysts predicted would happen after Western sanctions cut Russia's military aviation off from certified spare parts and engine overhaul capacity in 2022.
bpr123 ::
Kaj pa je sedaj s Pokrovskom? Dons sm poslušal ene resni.ca volilce kako je Rusija že zavzela pokrovsk in v kratkem pade pavlohrad.
Bici ::
windigo ::
Po vzporednih volitvah je Stevanovič kingmaker. Kar pomeni, da se mi je tole šloganje bolj ali manj slučajno posrečilo. Počakajmo sicer uradne izide, ampak "veselje" se začenja. Golob bo težko spustil notranje ministrstvo, ampak brez Stevanoviča nima večine.
Zanimivo bo videti, kako bo Stevanovičev proklamirani suverenizem vplival na zunanjo politiko RS.
Na Stevanoviča sem postal pozoren jeseni 21. Kar naenkrat so se lokalni polkriminalci odločili, da postanejo aktivni državljani in gredo vsi protestirat proti vladi. Malo sem sumil, da so jih v začetku povlekla razna srbska omrežja, ampak doseg je šel še precej širše. Zoprnij je bilo že prej dosti, cepili smo se lahko že prej in razen da je pogoj PCT bolj zabolel po dopustih, kakšne boljše razlage nisem imel.
Stevanovič ni človek idej, ne žene ga kakšna vizija v kaj bi spremenil svet. Prej bi rekel, da niti ne zna razložit tistega občutka "dost mam", ki ga požene v akcijo upor. Je energičen in je trmast. Ne bi se pustil hitro ustrahovat in zlahka prepričat. In prišel bo v parlament.
V parlament bo prišel na račun predvsem "anti-janša" pola. Kar pomeni, da ga bo precej verjetno potrebno pritegniti v kakšno koalicijo, da bo ta lahko vsaj približno udobna. In za to mu bo treba kaj ponuditi, pa ne vemo, na kaj pali (zgleda ni pedofil, morda tudi ni grozno pohlepen, niti pohoten in potem imamo problem). V skrajnem slučajo bo treba ponuditi tudi kakšno politično pozicijo, ki je sicer ne bi bilo tako oportuno zagovarjat. In ker je covid že pometen pod preprogo in iz cepljenja nima smisla delati politične zgodbe, bi blahko bila takšna politična pozicija bolj prijateljski odnos do Rusije.
V zgodovini Slovenije še nismo šli proti večini v EU (kot gre naprimer kdaj Orban). Tako da bi znal nastati političen problem, vlada in koalicija razpeta med notranje (Stevanovič) in zunanje (UvdL) pritiske. To ni nekaj, kar mi znamo hendlat.
Zato je za čas po volitvah potrebno pripraviti teren, da do tako neugodne situacije ne pride. In to bi še najboljše naredili z boljšo kontrolo narativa. Problem je, da namreč, da je zgleda kar nekaj ljudi, ki ima do Rusov in Rusije podoben odnos kot Stevanovič. No, teh se ne sme slišati, zato je treba ukiniti komentarje na MMC (Vasev in Sajoviceva nimata resnega vpliva na javno mnenje), ampak to ni zadosti, treba je naslikat še ustrezno črno belo kuliso, boj dobrih fantov proti slabim. In tu ni prostora za sivine, nianse in odtenke. Ali je črno, ali pa belo.
Dokler se prvič ne opere. Niti ni treba na 90.
Stevanoviča podpira srbska (~=proruska) enklava v Sloveniji, tako da je tole zelo slabo, da brez njega nobena stran ne more sestavit vlade. Do sedaj je bila slovenska drža izrazito proukrajinska ne glede na pol. To se z Resni.co zna spremeniti.
Nasa drza je bil proukrajinska, ampak smo ukrajini sploh kaj pomagali? Vojasko prakticno nic. Kaj veliko Stevanovic ne more spremeniti. Se pa strinjam, da je verjetno precejsen del njegovih volivcev po rodu Srbov. Ampak ne mores dobiti 60k glasov izkljucno na tak nacin.
- spremenil: kow ()
Nismo špilal Orbana in blokiral evropske pomoči...
Vse pomembne zadeve odloca vlada, tak da tut ce dobi zunanje ministrstvo bo preglasovan znotraj koalicije/vlade kar se tice kakih EU-level odlocitev. Ampak bodo pa trenja in skandali ;) Ce se hocejo skandalom izognit mu ne smejo dat zunanje ministrstvo.
- spremenil: Lonsarg ()
WhiteAngel je izjavil:
To ne zahteva ravno velike energije in stroskov.
Kakorkoli, na fronti je zanimivo. Zdi se, da so Ukrajinci presenetili Ruse z novo taktiko in jim prekrizali nacrtovano pomladno ofenzivo.
- spremenil: kow ()
Men sam ni jasno, kako to da se ruski kanonfutr (heh, dronfutr) ne upre in začne masirat svojih nadrejenih ...
Saj se zgodi. Samo je hkrati samomor. Moras verjeti v nebesa, da bos storil kaj takega ali pa doziveti ornk mentalni zlom. Mene bolj preseneca, da se vec ljudi ne preda ukrajincem. Verjetno je glavni problem, da te potem zamenjajo za ruske ujetnike. In potem najebes.
- spremenil: kow ()
shmandi ::
Stane2 ::
https://x.com/revishvilig/status/203613...
General Andriy Biletskyi, Commander of Ukraine's 3rd Army Corps:
If current trends continue, by the end of the year units that actively integrate ground robotic systems could reduce the number of infantry required on the front line by up to 30%. 1/10
phantom ::
Ravno obratno - če bo vlada hotela, da obstane, ga bo morala upoštevat.
Hehe, to bo še "zabavno", Stevanovič hoče zunanje ministrstvo.
https://www.rtvslo.si/slovenija/parlame...
:wq
:wq
phantom ::
Lahko pa se pridružiš enemu tistih dveh ruskih bataljonov, ki se borita na strani Ukrajine, baje kar precejšen del le-teh predstavljajo ruski vojaki, ki so se predali. Samo moraš pazit, da te potem spet Rusi nazaj ne zajamejo
:wq
:wq
POLITICO: Russia's 'meat assaults' in Ukraine cost it over 6,000 troops in four days, Kyiv says
Moscow has increased its attacks to take advantage of the better weather, President Zelenskyy says.
KYIV -- The Russian army sustained over 6,000 casualties in the last four days as it attempted a renewed offensive that was beaten back by the Ukrainian military.
"The enemy tried to break through the defensive formations of our troops in several strategic directions at once ... In total, the enemy conducted 619 assault actions during these four days," Ukrainian Army Commander Gen. Oleksandr Syrskyi said in a statement on Monday, describing the Russian operations as "a colossal pressure."
Syrskyi said the Russian command threw tens of thousands of soldiers into the "meat assaults."
While Ukrainian open source analysts at the Deep State live map project reported the Kremlin's army managed to advance in several small villages, it came at a catastrophic cost.
"Over four days of intensive assault operations, the enemy lost more than 6,090 soldiers killed and wounded," Syrskyi said, adding that Kyiv largely managed to repel the offensive.
The number of Russians killed or wounded was also reported Monday by the Ukrainian army command. The Russian ministry of defense reported targeting Ukrainian troops in more than 147 fighting districts in the Kharkiv, Dnipro, Zaporizhzhia and Donetsk regions over the past few days, but did not reveal the number of Ukrainian or Russian losses, or any significant advances.
Ukrainian President Volodymyr Zelenskyy said that Russian troops have noticeably become more active, taking advantage of the better weather, and that there have been more attacks.
"But this also means more Russian losses. In this week alone, more than 8,000 have been killed and seriously wounded. They also had mechanized assaults. Our drones are working well, and the positions of our army are strong," Zelenskyy said in an evening statement to the nation on Sunday.
The Institute for the Study of War think tank confirmed that so far, the Ukrainian military is forcing Russian forces to choose between defending against Ukrainian counterattacks and allocating manpower and equipment for offensive operations elsewhere on the front line.
"Russia's redeployments to southern Ukraine in response to Ukrainian counterattacks are likely disrupting the Russian military command's plans for the Spring-Summer 2026 offensive against the (Donetsk) Fortress Belt," ISW said in its latest war assessment, referring to Ukraine's fortified cities in the east of the country.
"Russian forces have previously failed to conduct simultaneous offensives in different sectors of the front, and it is unlikely that they will be able to make significant efforts to advance in the Fortress Belt area while contending with Ukraine's recent successes in the Hulyaipole and Oleksandrivka directions," it added.
https://www.politico.eu/article/russian...
Absolutno noro če ne kar bolano. To je skoraj 50,000 mrtvih v enem mesecu. Kdaj se bo ustavila ta norija?
- spremenilo: Chalky ()
nitka o ukrajinski gradnji jarkov na fronti
https://x.com/clement_molin/status/2036...
https://threadreaderapp.com/thread/2036...
Od začetka leta je Ukrajina 🇺🇦 izkopala več kot 1250 km obrambnih struktur v zaledju fronte.
"Mreža območij poboja" okoli nove linije Donbas se hitro širi. Tukaj je tisto, kar morate vedeti, in podrobna geografska analiza:
🧵NIT🧵1/20 ⬇️ To je majhno mesto Šahtarsk v Dnipropetrovski regiji. Eno linijo lahko vidite 5 km vzhodno od mesta, drugo pa 1 km vzhodno, ki je obroč, ki gre naokoli in ga ščiti na vseh bokih, kar mu bo omogočilo, da postane močna točka.
Na jugu si lahko najprej ogledate nove utrdbe, zgrajene letos, v rdeči barvi. Ukrajinski protinapadi v bližini Pokrovska so jim omogočili reorganizacijo obrambe Pokrovska in Novomikolaivke, ki sta zdaj utrjeni trdnjavi. ...
Ko Rusija ne bo več imela Putina na vrhu ali pa Putinu ne bo ostalo nič od Rusije. Saj zdaj bodo blokirali internete po zgledu Severne Koreje. Bo spet nekaj časa zdržalo.
Pol Rusija na področju interneta blokira nezaželjene strani tako kot EU...
Ma ni variante.
Taka klanja so bila v WW1, ko so kar brezglavo jurišali proti strojnicam.
Ne na eni, kot drugi strani, najbrž ni toliko mrtvih kot se poroča. Pač vsaka stran laže... O tem se že na veliko govori po internetu...
Zelensky pa pač hoče dajati vtis, da zmaguje. Mora prepričati EU naciste, da mu dajo več denarja. Zlati sekreti niso poceni...
- spremenilo: bm1973 ()
JohnyQ_ ::
Ma ni variante.
WW1 so bile strojnice, danes pa so droni. In rusi jurišajo peš, na mopedih in v civilnih kombijih na utrjene UA pozicije. Droni pa jih masakirajo.
Glede ostalega pa. Model ti si bolan v glavo.
Ma ni variante.
Za putota je cel internet nezaželjena stran lol, kaj ima to veze z blokado RT in ostalih propagandnih jajc in trolov plačanih za širjenje laži?
Kako bi bil vesel, da bi tebi blokirali večino spleta, za 'tvoje dobro'. Le kje bi potem zagovarjal, da je to pravično in dobro zate hahahah klovn.
Primerjaš jabolka in hruške. Severna Koreja ima whitelistane dovoljene strani. EU ima blacklistane določene strani.
A ni to poseg v svobodo govora?
Aja, ni če to "naši" naredijo...
nejcek74 ::
Propagando ruskega vojaške kompleksa, ki je ugrabil rusko državo je pametno čim bolj otežiti. Podobno bi morali vlagati energijo v omejevanje propagande ameriških tech-brojev, ki odkrito poskušajo uničit demokratične države. Če je vojna, je vojna za vse
shmandi ::
Še Rusi se čedalje bolj zavedajo, kako nesmiselne in zločinske so putlerjeve imperialistične težnje... le pri nas še vedno vztrajajo putleroljubci.
https://militarnyi.com/en/news/russian-...
Stane2 ::
https://x.com/Archer83Able/status/20364...
Ukraine's HUR MO released footage of the first documented destruction of the Russian K340P mobile launcher from the 3K55 Bastion coastal defense missile system since the beginning of the Russia-Ukraine war.
The column of Bastion launchers was caught in the open by Ukrainian OWA-UAVs while heading to a firing position in the area of the settlement of Furmanovka in the Crimea.
At least one Bastion launcher got destroyed while another got damaged as a result of the attack.
The Bastion complex is a primary launch platform for P-800 Onyx cruise missiles, and according to the Ukrainian intelligence, it was also modified to allow it to fire modern 3M22 Tsirkon hypersonic cruise missiles.
strawman ::
Ruska mil-blogger scena postaja precej pesimistična.
Fighterbomber:
Fighterbomber:
We have 15% of Donbas left to liberate, and once that is done, Donbas will be liberated.
In my opinion, we have three main ways to achieve this.
The first is to continue the creeping offensive with varying success, disregarding losses, which will be, to put it mildly, very high. Judging by today's slowed pace, this would take at least five years. It could be somewhat accelerated by committing everything we have left in terms of combat equipment and aviation, and if done properly and competently, we could free those 15% with similarly high personnel losses, plus additional losses in equipment. After that, we would shift into a deep defensive posture, accumulating resources.
The second option would have been to switch to defense yesterday, dig in, and focus on destroying enemy personnel and other targets until either they run out or we run out of personnel and weapons. This option is not time-limited and could approach infinity. At the same time, judging by current trends, the enemy is increasing strikes on our rear areas, expanding both the number and the range of attacks. And if time tends toward infinity, then personnel losses will be either the same or even greater than in the first option.
The third option is a variation of the first two, involving the use of nuclear weapons and other weapons of mass destruction. Here, the risks and our losses are almost impossible to predict, but it must be understood that each new day of the war brings closer the moment when such weapons could appear on the enemy's side. And it is not certain that they would hesitate to use them.
It must be understood that all three options may end not as we would like, regardless of the cost.
In light of reports about strategic initiative and newly "liberated" small villages, while the front is effectively stalled, I do not understand at what point the inevitable will be acknowledged and we will shift from a mode of creeping, small-unit stagnation to a mode focused on maximum preservation of our servicemen and civilians while inflicting continuous damage on the enemy until they are forced to come to the negotiating table. Negotiations should already proceed based on the actual line of contact, and the fate of these 15% should be decided not by military means but through diplomacy.
It should be understood that the situation of the enemy is much worse than ours, but they have enough resilience and resources to continue fighting for at least a couple more years even in their current state, and with increased support in manpower and weapons, the timeline extends to many years.
Naturally, with each day of war we are losing more than Ukraine. In essence, Ukraine no longer exists. Total external control, external financing, a destroyed industry and agriculture, population decline, youth fleeing, elimination of constitutional rights and freedoms, and no prospects for any normal future.
And we still have all of that, at least for now. Therefore, each day costs us more.
Perhaps we or the enemy have some kind of clever plan, a military genius, or a wunderwaffe up our sleeve that will soon be revealed and radically change the situation on the battlefield. But since no one has produced it in four years, there is reason to doubt that such changes will occur.
Naturally, this is my subjective view based on the current situation and the information available to me.
How things will be tomorrow, and how they "really" are, I do not know. Maybe everything will be much better, or maybe much... different.
Bellator ::
Po ST sodeč, je padel že pred kakim letom.
strawman ::
shmandi ::
UA vojna res že dolgo traja. :/
Saj bo kmalu kot ww2.
Neverjetno kako hitro je minilo od 2022
Včeraj so RU poslali v vesolje nekaj satelitov podobnim Starlinku:
https://www.independent.co.uk/news/worl...
https://www.reuters.com/business/media-...
Kako bo šlo naprej, je vprašanje. Npr Starlink, Musk je začel govoriti okrog 2014, 2019 so začeli pošiljati satelite gor, tako pravi Wiki.
Starlink @ Wikipedia
- spremenilo: fikus_ ()
bpr123 ::
Me res zanima ali bo kaj iz tega, ali pa je to še ena armata
Sam se bolj nagibam k slednjim. Molzenje proračuna za dvomljive rezultate.
Bici ::
Očitno rusov zmanjkuje. Le zakaj?
Moscow, Russia, has recently become home to nearly 70,000 Indian migrants, and tens of thousands of Sri Lankans are on the way to take the vacated places of the martyred volunteers of the special military operation. Their sacrifice was not in vain -- shanti, shanti. Blessed be Lord Vishnu.
The Indian guys like to climb onto a bus roof to get a free ride because that's how it's done back home. A bunch of burly police officers showed up and tried to pull the foreign boys down, but they refused. Can they survive our brutlasky land and its poker face residents of an exceptionally unique mindset. I don't know but I hope they do.
- spremenil: Bici ()
Stane2 ::
WTF
One Of Russia's Newest Warships Damaged and Listing Heavily After Drone Strike: Project 23550
Project 23550 patrol ship @ Wikipedia
- spremenilo: Stane2 ()
Windlass ::
WTF
Top, če je res
A še kdo zaznava v informacijskem prostoru neko spremembo v zadnjijh tednih glede stanja Putinovega režima in to kljub temu, da mu je Trump podaril denar od nafte? En kup je nekih analitikov in ˝analitikov˝, ki govorijo o tem da je Putin izginil, pa da so se mu uprli, da je nezadovoljstvo ogromno, pa o ugašanju mobilnega interneta, bančnem sektorju, o tem da oligarhi nosijo iz države kar se še da... iz fronte konec koncev tudi nadpovprečno dobre novice za Ukrajince...
Mate občutek, da se je nekaj vendarle obrnilo?
- spremenilo: Windlass ()
To se govori že zadnjih 10 let...
Plus, napadli so civilno ladjo... Temu Zahod pravi terorizem...
Daniel ::
Mobilni internet se občasno ugaša oz. bolj verjetno whitelista v nekaterih predelih moskve, ne vseh. Urejam komunikacije nekomu, ki je službeno tam, in pravi, da občasno zmanjka. Hišni net sicer deluje a brez vpn deluje samo dovoljena propaganda.
floyd1 ::
The ships are equipped with a portable anti-aircraft missile system, an artillery mount, a radar station for monitoring both air and surface situations, and a hydrometeorological station. They will also be capable of permanently basing a shipborne helicopter.
Malo nenavadna oprema za civilno ladjo, a ne?
Glede na današnje kraje civilnih ladij s strani zahodnih vojsk, niti ne...
Stane2 ::
Katera civilna ladja ima tole:
Armament
1 × 76.2 mm (3 in) AK-176MA naval gun[8]
2 or 4 × 12.7 mm Kord machine guns
2 × 30 mm AK-630M CIWS ("Ermak" type)
8 × 3M-54 Kalibr missiles ("Arktika" type)
drogeraš.. vedno slabš ti je
