AtaŠtumf ::
Bauc je izjavil:
AtaŠtumf je izjavil:
Saj so že prej rekli, da tisto, kar je bilo obljubljeno, bodo še poslali.
Brez skrbi. Ko bodo dobili korejske in ameriške tanke in havbice bodo poslali še prestale leoparde in havbice poljske proizvodnje.
Poland will produce over 800 South Korean K2 tanks as part of an order for the Polish army, the country’s defense minister announced Thursday
Poland has more than 240 Leopard tanks, a total of 137 Leopard 2A4 tanks, 105 Leopard 2A5 tanks, and fewer than 10 Leopard 2PL tanks in service.
Da, in kdaj bodo dobili teh 800 korejskih tankov, predvidoma dobijo prve enkrat po 2025, da dobijo vseh 800 bomo konkretno ze 2030+.
sirotka ::
Do takrat se bodo rusi že sami taktično umaknili nazaj v svoje meje.
Peter Zeihan je ob komentarju vojne med Armenijo in Azerbajdžanom (ki bi lahko imela hude posledice) že omenil, da je naslednja domina v vrsti, ki je posledica unravelinga ruskega vpliva v Srednji Aziji ..... Čečenija.
Ko Kadirova pobere bo tam še zelo vroče.
Junija so jih imeli 28
K2 Black Panther @ Wikipedia
According to the agreement, 180 K2s will be supplied from South Korea from 2022, and 820 K2PLs will be produced in Poland from 2026. A total of 1,000 tanks will be delivered to Polish Land Forces.[112][113][114][115] On 26 August 2022 the executive agreement was signed to procure K2. A total of 180 K2s will be delivered to the 16th Mechanised Division from 2022 to 2025.[133][134][135]
16th Mechanised Division – A total of 180 K2s. Received 28 K2s as of 16 June 2023.[146]
Bauc je izjavil:
Poljaki bodo dobili še 250 Abramsov. Vojna bo pa na žalost trajala vsaj še par let tako, da je časa več kot dovolj. Azerbajdžanci so morali čakati par desetletji, da so dobili svojo zemljo nazaj. Hrvati pa par let.
  • spremenil: Bauc ()
CoolBits ::
The war is over. Russia has won. There is no Ukrainian offensive anymore, but the White House and the American media have to keep the lie going
https://www.thegatewaypundit.com/2023/0...
A se da dobiti kakšne tehnične statistike o teh korejskih K2 in K2PL-jih?
V čem so boljši/slabši od Leopardov in Abramsov?
Ali jih je treba uporabljati po drugačni vojaški taktiki in v drugačnih formacijah?
CoolBits je izjavil:
Očitno ima za vir tipa iz umobolnice. Piše pa za tipe, ki so za v umobolnico:))
“After weeks of high casualties and little progress, along with horrific losses to tanks and armored vehicles,” the source said, major elements of the Ukrainian army, without declaring so, virtually canceled the offensive,” Hersh reports. “The two villages that the Ukrainian army recently claimed as captured “are so tiny that they could fit between two Burma-Shave signs,” the source said.
There are two features of the K2 which I find very interesting, and have no real counterparts in other tank designs.
The first is the dramatic lowering of the turret. The turret is designed in such a way that the turret top is higher over the gun, while the rest of the top is considerably lower. This reduces the protected volume and makes the K2 considerably lighter than other Generation 3 or 3.5 tanks.
The other thing which sets the K2 apart is the ammunition used. Korea completed the development of a form of “smart” round first created in the United States in the 1980’s called “TERM” (Tank Extended Range Munition). The Korean version is called K-STAM (Korean Smart Top Attack Round), which has a range of 8km and is designed to activate a sensor to seek out enemy tanks and fire an EFP charge through the roof, which is usually one of the less armoured parts of a tank. This is different from a through tube missile like LAHAT or 9K118 Sheksna in that it is an artillery projectile, not a rocket or missile, so the handling and rate of fire is no different than that of an APDS-FS round.
Nikec3 ::
Vem, da je BS članek, ko preberem to:
There has been a ”secret disinformation operation“ by the CIA and British intelligence aimed at discrediting Putin
Po tem res ni potrebe, ker se Putin čisto super diskreditira sam.
@WarpedOne o Elonu Musku:
CoolBits ::
To da si ti in večina zahoda nasedel dezinformacijam pa ni mogoče ne? :D
Samo holywoodske filme pogledaš pa ti je takoj jasno programiranje, povsod je rus "bad guy" in amerikanc "good guy" drugega ne vidiš.
Ja ja, Rusija napreduje, so na RTV povedali! Komunisti se sploh ne zavedajo kaj jih čaka, bolj kot leta 90. S Koreja je pot?
Američan je bil bad guy v Vietnamu zdaj je pa bad guy Rus v Ukrajini. Dovolj preprosto zate?
martincek1 ::
Biden je ravnokar napovedal da v Ukrajino pošilja ATACMS
https://twitter.com/YWNReporter/status/...
https://twitter.com/WarMonitors/status/...
https://twitter.com/Faytuks/status/1705...
Cluster munition verzijo.
https://twitter.com/nexta_tv/status/170...
Photo of the day. A local resident holds a piece of paper with the inscription "Crimea is Ukraine!" in front of a burning building of the Russian Black Sea Fleet in occupied Sevastopol.
Bauc: wow hvala za info.
Ob tem podatku 'dramatic lowering of the turret.' sem se spomnil na podoben dizajnerski cilj, ki so ga imeli Rusi za svoje tanke zadnje sovjetske generacije, ko so zdizajnirali izjemno nizek tank (nižji od Zahodnih) in to dosegli tako da so vso municijo dali pod topničarja. In za tiste čase so bili to izjemno sloki, nizki sovjetski tanki, z prednostjo na bojišču zaradi nižje silhuete, verjetno podoben preboj kot pri K2. No potem pa so prišli Javelini in NLAW-i in je šla vsa ta pšrednost v franže. Korejci so verjetno želeli doseči nekaj podobnega - sklepam da z več uspeha kot Sovjeti/Rusi.
dronyx ::
Bauc je izjavil:
Še par let? Kaj potem bodo rusi na Moskviče montirali topove, v boj pa pošiljali kmete in ženske iz zakavkazja? :))
A lahko kdo pojasni kaj je fora ruskih 'Scooby doo' vanov?
Kje imajo Kamaz in Ural tovornjake?
blackbfm ::
to je moglo na krimu danes fejst počit da uletavate s takimi članki:))
vsaj dva Storm Shadowa sta bila
Footage of a Ukrainian Storm Shadow/Scalp ALCM hitting the Russian Black Sea Fleet headquarters.
Se pravi Angleži so otvorili sezono lova s STORM raketami na Krimu, zdaj bodo še US poslali ATACMS. Dolgo so rabli ampak bolje pozno kot nikoli pravijo.
CoolBits ::
Zelensky asks satanist spirit cooker, Marina Abramovic to be Ambassador for Ukraine and help rebuild schools.
My Goodness... I can see it now... blood splattered walls and goat head emblems.
https://www.telegraph.co.uk/world-news/...
Lonsarg je izjavil:
In to sredi belega dneva, tako da lahko vsi vidijo, kako so Rusi uspešni pri sestreljevanju teh raket.
https://twitter.com/Azovsouth/status/17...
Captured denazifier-anti-fascist from the #Zaporizhzhia direction
This orc served in the russian illegal armed group "sudoplatov battalion". He surrendered voluntarily
https://twitter.com/HighMarsed/status/1...
I found some evidence that Russia may be running low on replacment barrels for the 2S5 Giatsint-S. They have removed a lot of systems from three spots at the 94th Arsenal in Omsk and almost all of the remainig units have their barrels removed:
  • spremenilo: Lesoto ()
dronyx je izjavil:
Bauc je izjavil:
Kot vedno je ruski plan, da sovražnika utopijo v ruski krvi aka prej bo sovražniku zmanjkalo municije kot nam mobilizirane horde. Pravzaprav žalostno.
nejcek74 ::
Pomenljivo, da si tako neizobražen, da ti ob natolcevanju "Marina Abramović = satanist" ne zazvoni zvonec za blušit propagando. Anyway, tvoji viri so vreča govna.
  • spremenil: nejcek74 ()
Nekaj se priča, da je bil ubit poveljnik Črnomorske flote Admiral Victor Sokolov.
Če je bil takrat v svoji pisarni v tej zgradbi, za zagotovo ni več - eden izmed SS je zadel ravno njegovo pisarno na sredini stavbe.
https://twitter.com/GloOouD/status/1705...
sir_mha ::
Tukaj si ga pa pihnil, saj toliko bi lahko pogledal, da je Marina oz Yuge doma, in da jo kakšen tukaj mogoče še pozna.
Je pa to dobra ilustracija metode putinistov.
CoolBits ::
Kaj ima veze kje je doma? A nihče ne pozna njegovih del?
a boš kaj pokomentrial tole svinjarijo, ki si jo prilimal? A si se kaj naučil iz tega?
https://slo-tech.com/forum/t767997/p801...
sir_mha ::
Lesoto je izjavil:
Škoda. Njegove "kvalitete" so bili v veliko pomoč Ukrajini :)
še en posnetek
Footage of the Ukrainian cruise missile (Storm Shadow?) right before impact which destroyed Russia's Black Sea Fleet HQ in occupied Crimea.
sir_mha je izjavil:
Saj dejansko je bolje, da vsi ti ruski generali in admirali ostanejo na svojih mestih. Stupid is stupid does.
https://twitter.com/DimonchikIR/status/...
Even Crimean collaborators appreciated the accuracy of Storm Shadow
The Sevastopol "governor" admitted that civilians near the headquarters were not injured and even the windows in the surrounding houses were intact.
Here, Rusnya, this is a high-precision weapon that flew where it was needed and killed whoever it was needed, and not like what you have. Plus/minus two blocks.
Ne moremo ti pomagati, če ne dojemaš provokativnega umetniškega performansa. Rajši se drži satanistov, reptilov in ostalih teorij zarot :D
dronyx ::
Lesoto je izjavil:
Storm Shadow manevrirne rakete se mi zdi da bodo tudi velik prodajni hit. Kot general si to vsekakor želiš imeti v svojem arzenalu in to v čim večjih količinah. Škoda, da ZDA ne poskušajo pokazati, kaj zmorejo Tomahawki. Vojna v Ukrajini je do sedaj med drugim tudi največja demonstracija sodobnega orožja na svetu. V bistvu velik orožarski sejem z živo demonstracijo. Zvok, ko leti Storm Shadow proti cilju pa...holy fuck. Ko to slišiš veš, da se nekomu slabo piše, če so le sprogramirali prave koordinate tarče.
  • spremenil: dronyx ()
Storm Shadow je 20 let staro orožje in niti ne tako vsemogočen.
Taurus je še precej boljši
https://twitter.com/pati_marins64/statu...
The Taurus is a significantly more advanced and modern missile, capable of posing a substantial challenge to Russia's air defenses.
One notable feature is its advanced noise immunity,
primarily due to the open architecture of the additional optoelectronic module of the IBN (Image Based Navigation) correlation system.
In contrast, the guidance systems of the Storm Shadow and SCALP-EG cruise missiles rely solely on infrared seekers to target the thermal signatures of objects in the terminal stage of their flight trajectories.
Another significant aspect is the inclusion of the Taurus HPM (High Power Microwave) modification within the range of tactical missiles equipped with Taurus modular equipment. The HPM variant is equipped with a powerful microwave electromagnetic pulse generator designed to disable the electronic components of multifunctional radars, anti-aircraft missile systems, tactical communication and relaying radio relay stations, electronic warfare, and electronic intelligence systems within a radius of several hundred meters or even several kilometers.
etc etc
dronyx ::
No, Storm Shadow se je do sedaj na bojišču kot kaže izkazal. Rusi jih prav veliko niso sestrelili, tarče pa zadane praktično na meter natančno.
Ukrajini bi lahko dobili kakšne stare, poceni rakete, da rusi aktivirajo protiletalsko obrambo, potem pa jim to uničijo z HARM raketami. Saj rusi ne vedo, kaj leti proti njim. Po moje sedaj bolje razumejo, kako globoko so zabredli v močvirje. Par dni, pa parada v Kijevu. Ja, res...:))
Manevrirna raketa sploh ne rabi kakšnega sodobnega elektronskega načina za motenje radarjev. Povsem dovolj je očitno že, da leti čim nižje in sledi terenu, let pa mora biti programiran tako, da čim bolj izkorišča okolico in teren, nad katerim leti do cilja. To je za protiletalsko obrambo po moje skoraj nerešljiv problem. Morda je zadnja faza leta, ko se mora manevrirna raketa dvignit in usmerit proti cilju, še najbolj problematična, da jo ne sestrelijo. Ampak časovno okno so pa sekunde, tako da težka...
dronyx ::
Za Storm Shadow bi bil morda obramba kakšen c-ram, kot ga imajo nameščenega na ladjah za obrambo proti raketam. Ampak to bi moral imeti montirano blizu tarče. In tega rusi nimajo.
borisk ::
še za ladjo rabiš 2-3 CIWS, da imaš pokrito, poleg tega tega ne moreš laufat v mestu, kje na letališču še, ne pa sredi sevastopola
sir_mha ::
Budanov počasi ratuje večja zvezda kot Zelenski. Samo se seveda zaveda hierarhija, njegovi odgovori so vedno uvidevni.
Dober intervju.
https://www.thedrive.com/the-war-zone/e...
dronyx ::
Samo ti rusi so pa res idioti. Še vedno se hvalijo ob vsakem uspešnem ukrajinskem napadu, koliko raket so uspešni sestrelili. Ampak ne povedo pa, kaj točno pa so sestrelili? Ukrajina kakor vem pošlje najprej nekaj vab, ki jih rusi "uspešno sestrelijo", nakar pridejo pa na vrsto Shadow Storm rakete, ki pa cilje očitno zelo natančno zadenejo.
Mene pa prav čudi kje so kake navedbe Ruske propagadne da bi kake vojaške cilje v Ukrajini zadeli izven fronte. Tudi če ni nič zadeto bi pričakoval vsaj kake fejk navedbe, kaj so tako bogi da res sam še civilno infrastrukturo upajo ciljat z long-range raketami? Al jim je zmanjkalo denarja za bolj resno propaganda in raje pišejo samo še o "naci/terorist/..." budalaščinah ter o "dobri ruski obrambi"?
sir_mha ::
Zanimivo ...
Azerbaijan built a border post in Lachin to inspect all trucks, as the russian "peacekeepers" were smuggling all this ammo into Karabakh for a new war.
The lack of food in Karabakh was the result of Armenians refusing to allow the inspection of trucks.
https://x.com/noclador/status/170528036...
Imam občutek, da ruska proaganda vedno bolj prodaja zgodbo o "zmagi" na trenutnih pozicijah, kar verjetno pomeni, da nimajo resursov za kako večjo ofenzivo.
dronyx ::
Lesoto je izjavil:
Tule lep posnetek, kako zadane raketa tarčo. Po moje je kar precej žrtev, saj dvomim, da je bila zgradba ob napadu prazna.
Sedaj lahko vsak višji poveljnik ruske vojske, ki se nahaja v dometu teh raket računa na to, da nekega dne se več ne zbudi. Mogoče najbolje, da spijo kar v bunkerjih, globoko pod zemljo. :D
yayo ::
nejcek74 je izjavil:
yup, na nivoju srbskih tabloidov za pastirje. Najbolj zabavno pa, da gre za čisto Beograđanko.
Fungi88 ::
Ojej.
Pa bodo spet rusofilske sanje padle v vodo.
Slow motion najbolj dramatičnega posnetka te vojne. Ne pozabit, da gre za najbolj branjen ruski objekt na Krimu. Še bolj kot pa krimski most.
Slowed down and zoomed-in footage of the Ukrainian Storm Shadow/SCALP ALCM slamming into (and through) the roof of the Russian Black Sea Fleet headquarters.
Fungi88 ::
Razlog za napad na Krim je bilo pomorsko oporišče, ki je sedež črnomorske flote.
Sedeža očitno ni več, flote pa tudi vsak mesec manj.
Torej ni več razloga da Rusi vstajajo tam.
Kaj jim preprečuje, da ne izstrelijo ducat ali dva raket na krimski most?
Nikec3 ::
1. Putin je izvedel invazijo na Ukrajino.
2. Tega ne podpiram.
Katerim dezinformacijam sem tukaj nasedel?
545 / 1529
