tsql kolona iz vrednosti druge kolone
korenje3 ::
Ali je možno narediti, da vrednost iz ene kolone uporabi v drugi koloni?
Recimo iz kolone "Property Name" bi rad imel 2 dodatni koloni "Naziv" in "Ident" kamor bi dalo rezultate, ki so trenutno v "Property Value".
Trenutni sql ukaz je pa tak:
WITH [FilteredSource] AS (
-- partition: 0 ms
SELECT
	[Documents].[DocumentID] AS [DocumentIDP],
	[Documents].[Filename] AS [Datoteka],
	[Documents].[Link] AS [Link],
	[Documents].[Deleted] AS [Deleted],
	[Documents].[LatestRevisionNo] AS [Revizija],
	[Projects].[ProjectID] AS [ProjectID],
	[Projects].[Deleted] AS [DeletedProj],
	[Projects].[Path] AS [DirektorijAggr],
	[Users].[FullName] AS [CheckOut By],
	[DocType].[TypeName] AS [TypeName],
	[VariableValue].[ValueText] AS [Property Value],
	[ObjectType].[ObjectTypeID] AS [ObjectTypeID],
	[ObjectType].[Description] AS [Description],
	[Variable].[IsDeleted] AS [IsDeleted],
	[Variable].[VariableName] AS [Property Name],
	[FileExtension].[Extension] AS [Extension],
	[DocumentConfiguration].[ConfigurationID] AS [ConfigurationID],
	[DocumentConfiguration].[ConfigurationName] AS [Konfiguracija],
	[Revisions].[FlushedDate] AS [Checked-In],
	ROW_NUMBER() OVER (PARTITION BY [DocumentConfiguration].[ConfigurationID], [Variable].[VariableID], [Documents].[DocumentID] ORDER BY [Revisions].[FlushedDate] DESC) AS [Partition_Konf-Prop]
-- select: 0 ms
FROM 	[DocumentsInProjects]
	FULL JOIN [Documents] ON [DocumentsInProjects].[DocumentID] = [Documents].[DocumentID]
	FULL JOIN [Projects] ON [DocumentsInProjects].[ProjectID] = [Projects].[ProjectID]
	FULL JOIN [VariableValue] ON [Documents].[DocumentID] = [VariableValue].[DocumentID]
	FULL JOIN [Variable] ON [VariableValue].[VariableID] = [Variable].[VariableID]
	FULL JOIN [Revisions] ON [Documents].[DocumentID] = [Revisions].[DocumentID]
	FULL JOIN [Users] ON [Documents].[UserID] = [Users].[UserID]
	FULL JOIN [DocType] ON [Documents].[DocTypeID] = [DocType].[DocTypeID]
	FULL JOIN [FileExtension] ON [Documents].[ExtensionID] = [FileExtension].[ExtensionID]
	FULL JOIN [ObjectType] ON [Documents].[ObjectTypeID] = [ObjectType].[ObjectTypeID]
	FULL JOIN [DocumentConfiguration] ON [VariableValue].[ConfigurationID] = [DocumentConfiguration].[ConfigurationID]
-- join: 0 ms
WHERE	([Documents].[Filename] LIKE CAST('%ngi%' AS NVARCHAR(5)))
AND	([Documents].[Link] = CAST('0' AS BIT))
AND	([Documents].[Deleted] = CAST('0' AS BIT))
AND	([Projects].[Deleted] = CAST('0' AS BIT))
AND	([DocType].[TypeName] NOT LIKE CAST('Toolbox' AS NVARCHAR(128)))
AND	([ObjectType].[Description] LIKE CAST('Normal Document' AS NVARCHAR(255)))
AND	([Variable].[IsDeleted] = CAST('0' AS BIT)
OR	 [Variable].[IsDeleted] IS NULL)
AND	([Variable].[VariableName] LIKE CAST('%ident%' AS NVARCHAR(7))
OR	 [Variable].[VariableName] LIKE CAST('%naziv%' AS NVARCHAR(7)))
-- filter: 0 ms
-- recursion: 0 ms
SELECT TOP 2000
	CONCAT('C:\EPDM', [FilteredSource].[DirektorijAggr]) AS [Direktorij],
	[FilteredSource].[Datoteka] AS [Datoteka],
	CONCAT('conisio://EPDM/open?projectid=', [FilteredSource].[ProjectID], '&documentid=', [FilteredSource].[DocumentIDP], '&objecttype=', [FilteredSource].[ObjectTypeID]) AS [Open],
	[FilteredSource].[Extension] AS [Extension],
	[FilteredSource].[Revizija] AS [Revizija],
	[FilteredSource].[Konfiguracija] AS [Konfiguracija],
	[FilteredSource].[Property Name] AS [Property Name],
	[FilteredSource].[Property Value] AS [Property Value],
	[FilteredSource].[CheckOut By] AS [CheckOut By],
	[FilteredSource].[Checked-In] AS [Checked-In],
	[FilteredSource].[DocumentIDP] AS [DocumentIDP],
	[FilteredSource].[ConfigurationID] AS [ConfigurationID]
-- selectouter: 0 ms
FROM 	[FilteredSource]
-- join: 0 ms
WHERE 	[FilteredSource].[Partition_Konf-Prop] <= 1
GROUP BY
	[FilteredSource].[Datoteka],
	[FilteredSource].[Link],
	[FilteredSource].[Deleted],
	[FilteredSource].[Revizija],
	[FilteredSource].[DeletedProj],
	[FilteredSource].[DirektorijAggr],
	[FilteredSource].[CheckOut By],
	[FilteredSource].[TypeName],
	[FilteredSource].[Property Value],
	[FilteredSource].[ObjectTypeID],
	[FilteredSource].[Description],
	[FilteredSource].[IsDeleted],
	[FilteredSource].[Property Name],
	[FilteredSource].[Extension],
	[FilteredSource].[ConfigurationID],
	[FilteredSource].[Konfiguracija],
-- groupby: 16 ms
HAVING	 (CONCAT('C:\EPDM', [FilteredSource].[DirektorijAggr]) NOT LIKE CAST('%staro%' AS TEXT))
-- having: 16 ms
ORDER BY
	[FilteredSource].[Konfiguracija] ASC,
	CASE
	WHEN [FilteredSource].[Property Name] LIKE 'Ident' THEN 1
	WHEN [FilteredSource].[Property Name] LIKE 'St. risbe' THEN 2
	WHEN [FilteredSource].[Property Name] LIKE 'Author' THEN 3
	WHEN [FilteredSource].[Property Name] LIKE 'Konstruiral' THEN 4
	WHEN [FilteredSource].[Property Name] LIKE 'Drawn By' THEN 5
	ELSE 6 END ASC,
-- orderby: 16 ms
  • spremenil: korenje3 ()
smetko ::
Poglej si funkcijo iif()
Primer:
iif([Variable].[VariableName]='ident',[VariableValue].[ValueText],null) as ident
No comment
korenje3 ::
Ja sam se mi zdi da bi to izpisovalo samo 1 vrednost v 1 vrsti. Mene pa zanima kako obe vrednosti izpisat v 1 vrsti.
Najprej moras seveda vedit po kateri lastnosti bi zdruzeval vrstice, ugibam da po "konfiguracija".
Nato pa nic komplicirat amlak cisto preprosto en self join naredis z pogojem kjer ima "leva" tabela vrednost Naziv, "desna" pa Ident.
  • spremenil: Lonsarg ()
korenje3 ::
to pomeni da moram v eni tabeli iskat samo po ident, po drugi pa samo naziv?
Torej bi lahko dupliciral
WITH [FilteredSource] AS ()
kjer bi v eni imel filter
v drugi pa
To pomeni tudi 2x daljšo izvedbo iskanja?
hm dejansko bi bila taka izvedba dokaj preprosta saj se mi ukazna vrstica generira po segmentih...
Ja to bi bil brute force način.
Performančni način pa je da greš čimbolj na izvor tam kjer se duplikacija zgodi. Če sem prav nahitro pogledal tvoj query se to pri tebi zgodi pri tabeli VariableValue, če ga nisem polomil bi že tu lahko razbil join da enkrat vrne eno lastnost drugi drugo na ta način:
INNER JOIN [VariableValue] AS identValue ON [Documents].[DocumentID] = identValue.[DocumentID]
INNER JOIN [Variable] AS ident ON identValue.[VariableID] = ident.[VariableID] AND ident.VariableName = 'Ident'
INNER JOIN [VariableValue] AS nazivValue ON [Documents].[DocumentID] = nazivValue.[DocumentID] AND
INNER JOIN [Variable] AS naziv ON nazivValue.[VariableID] = naziv.[VariableID] AND naziv.VariableName = 'Naziv'
Uporabil sem aliase kot se spodobi, v selectu lahko dobiš preko teh dveh aliasov potem obe lastnosti. Ker sem uporabil inner join ti ne bo vrnilo vrstic kjer te dve lastnosti manjkata, tisto bi potem moral še malenkost drugače če bi tudi take rabil.
TSQL rekurzivno
Oddelek: Programiranje
111344 (1083) hamez66
[SQL] Filtriranje
71388 (1143) korenje3
SQL vprašanje
81467 (1066) MrStein
[Java]Problem z vektorjem
92001 (1870) KernelPanic
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187271 (7130) ManDriver
