Pandemija COVID-19
Pandemija COVID-19
CoolBits ::
V Italiji ugotovili, da je od 500 pa nekaj dnevno, samo okrog 12 mrtvih zaradi cov2 in brez drugih patologij...
Ni malo ampak vseeno.
https://www.lastampa.it/cronaca/2020/03...
dj cotto ::
To nekateri v Sloveniji, pa tudi drugje na svetu, ugotavljamo že nekaj časa.
showsover ::
Machete je izjavil:
(skull)
Hahah, imam tudi sam se eno taksno bandano, pa mladini sem tudi razdelil...
Samo so kitajske, torej nezanesljive kot njihovi testerji in informacije o obolevnosti.
Womp womp. Množične prireditve so šit.
https://uk.reuters.com/article/us-healt...
From the stage of an evangelical superchurch, the leader of the gospel choir kicked off an evening of prayer and preaching: “We’re going to celebrate the Lord! Are you feeling the joy tonight?”
The prayer meeting kicked off the biggest cluster of COVID-19 in France - one of northern Europe’s hardest-hit countries - to date, local government said. Around 2,500 confirmed cases have been linked to it. Worshippers at the church have unwittingly taken the disease caused by the virus home to the West African state of Burkina Faso, to the Mediterranean island of Corsica, to Guyana in Latin America, to Switzerland, to a French nuclear power plant, and into the workshops of one of Europe’s biggest automakers.
Weeks later, Germany partially closed its border with France, suspending a free-movement pact that has been in place for the past 25 years. The church cluster was a key factor, two people familiar with the German decision told Reuters. Church officials told Reuters that 17 members of the congregation have since died of complications linked to the disease.
boolsheat ::
"Solo lo 0,8 per cento dei morti non ha gia patologie"
Se pravi 0,8% smrtnost?
To zelo sovpada k trenutni smrtnosti v Nemčiji kjer je trenutno pri 0,86% in potrjuje to, kar sem dejal, da Nemci drugače štejejo...
Če je gripa pri smrtnosti na 0,1% smo potem realno pri nekje 8x večji smrtnosti pri covid-19.
Tam kjer pa bolezen zabije žebelj v krsto pa je očitno res nekje 20 do 40 krat večje pri covid-19.
Massacra ::
A imamo kakšen podatek, kje so ti novi okuženi za zadnji uraden podatek (29.3.2020 ob 24.00)?
Vice ::
boolsheat je izjavil:
Narobe ker jemlješ ven iz koncepta. Samo 0.8% ljudi, ki so umrli je bilo 100% zdravih.
dj cotto ::
Seveda to velja le ob predpostavki, da za smrtnost pri gripi vzamemo dolgoletno povprečje, ki je 0,1. Ker pa pravimo, da gre pri korona virusu za eksces, je treba za primerjavo vzeti tudi pri gripi ekscesen primer. Eksces je npr. zima 2016/17 v Italiji. 24.981 mrtvih zaradi gripe, 5.526.216 obolelih. Smrtnost 0,45%. In to številko sem že večkrat navedel. Če pa se vzame 43.366 umrlih zaradi gripe in gripi podobnih bolezni, pa je smrtnost 0,78%.
lexios ::
Imajo te zascitne maske kak standard, glede na to, da niti uvozene iz Kitajske menda sploh niso zanesljive?
Torej, je dovolj, da si zavezes cunjo cez usta?
Dovolj je, če razkužiš usta in obiščeš savno:
"Tako kot je treba vsak dan spiti med 40 in 50 mililitrov vodke, je za boj proti virusu dobro tudi dvakrat ali trikrat na teden obiskati savno," je dejal Lukašenko.
Horas ::
spen en omenja savno. savna je v bistvu pravi raj za bacile, bakterije...
energetik ::
Horas je izjavil:
Ne, ni. Beri študije, kaj naredi toplota in vlaga virusu. V turški savni crkne takoj.
PrihajaNodi ::
lexios je izjavil:
Ocitno nekaj delajo prav, ce nimajo nic mrtvih:
https://en.m.wikipedia.org/wiki/2020_co...
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
louser ::
showsover je izjavil:
Da zadovoljiš potrebe ukrepov, ja. Stroka ne trdi niti da so, niti da niso učinkovite.
Vrmo pa katere točno ob pravilni uporabi so učinkovite. In teh nam ne morejo dobaviti.
lexios ::
Horas je izjavil:
"Jaz ne vidim nobenega virusa tu v dvorani. Ali ga vi vidite?"
https://www.24ur.com/novice/tujina/belo...
PrihajaNodi je izjavil:
lexios je izjavil:
Npr., da so ukrepe uvedli pravočasno?
To date (23.3), over 21,000 tests for COVID-19 have been performed in Belarus. The testing started on 23 January. Belarus is among the top ten countries in terms of the number of tests performed.
About 1,100 were first-level contacts of the COVID-19 patients are now isolated, 8,800 people are confirmed as second-level contacts.
  • spremenil: lexios ()
Conini ::
dj cotto je izjavil:
To počasi že cel svet ugotavlja.
Potem pa še dodaj x5 ali x10 večjo okuženost od ugotovljene, pa smo na 0.08%, torej 8 od 10.000.
Horas je izjavil:
Lahko je za bakterije, za viruse zagotovo ne.
  • spremenilo: Conini ()
itak37 ::
Pezdicek je izjavil:
A je že kaj več znanega, če lahko oseba brez znakov okužbe, okuži druge ljudi?
Se pravi brez kašlja in vročine?
Pa kako je najlažje ločit razliko med navadnim prehladom in korono?
Ja, kužen si lahko že par dni pred prvimi simptomi, vendar dosti manj kot bolnik z izrazitimi simptomi.
Tudi okuženi brez simptomov so lahko kužni, spet manj kot bolniki z izrazitimi simptomi.
Pogosti simptomi pri covid19, po katerem ga lahko ločimo od prehladov so konjuktivitis (rdeče oči) in izguba vonja in okusa.
GenZNPC ::
Ojla, sem malo pozabil spremljati sceno odkar sem v karanteni, delam druge stvari.
Kaksno je stanje v evropi? Se siritev upocasnjuje?
Kaksno je stanje v USA? Se siritev pospesuje ali upocasnjuje? Se je panika ze razsirila ali se se stopnjuje?
Lahko nekdo na kratko in jedrnato malo opise kaj se dogaja?
skibidi
lexios ::
To bo ja. Testerji resijo vse, niti izolacija ni potrebna. Prav tako so vse meje odprte.
Damn, kaksen nizek iq je pri naketerih. Kot komentarji na 24 ur.
Ne bluzi. Belorsija testira od januarja dalje, vse pozitivno potrjene okužbe so samoizolirali - počeli so natanko to kar počne Japonska, Singapur in Južna Koreja, a brez zapiranja šol in gospodarstva...
Spet bo komentar brisan, ampak vseeno. Če bi celotna Europa začela s testiranjem migracij (npr. leti iz Kitajske ali drugih delov sveta, kjer se je korona kriza že začela) že januarja, bi bila situacija sedaj drugačna! To je zaj... Šarceva vlada oz. cel svet! Ampak ko se je v začetku leta govorilo o zapiranju letalskih povezav s Kitajsko so ljudje protestirali... Če bi takrat uvedli karantene in testiranja bi "Mato-ti" že takrat kričali o omejevanju svobode in diskriminaciji... Namesto da bi se EU zgledovala po Belorusiji, se je v paniki, ko je bilo že prepozno, pričelo pritiskat na ministrstva in navijati za ukrepe v Wuhanu.
Massacra ::
A lahko tisti, ki je tukaj naložil video v zvezi z mikrodelci v zraku - kako se širijo po prostoru in koliko časa ostanejo - ta video še enkrat naloži? (ga ne najdem niti v svojih zaznambah).
Mislim, da je bila japonska "študija" in uporabljena neka "super kamera"!
PrihajaNodi ::
Lexios s kaksnimi testerji ko pa vsi vemo, da so testerji nezanesljivi. Kot drugo, ne bit nor da je bila Belorusija z vsemi testi bolj pripravljena kot Nemcija. Lol
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
Horas ::
GenZNPC je izjavil:
v ameriki je katastrofa. njih bo šele prizadelo. taka velenacija so pa, se niso prej zrajtali za določene ukrepe!
lexios ::
@Nodi Očitno so "zaprli" meje pred vsemi ostalimi:
Lukashenko stated that everyone who came from abroad was tested, saying: "Two to three people a day have been tested positive for the coronavirus. These people are quarantined for 1.5-2 weeks."
Ali pa prirejajo statistiko in v tem primeru to, da nekaj počnejo bolje ne drži. Vemo pa, da če bi celotna Europa začela s testiranjem migracij (oz. več pozornosti namenila migracijam v EU iz Azije, namesto, da se je zgolj ukinilo promet za poštne pošiljke s Kitajsko) že januarja, bi bila situacija sedaj drugačna! V začetku februarja si v Italijo iz Azije potoval še brez problema...
As of March 27, 2020, the number of confirmed cases of the coronavirus (COVID-19) in Belarus reached 94, while 32 people were cured from the infection. Approximately 24 thousand individuals were tested for the infection in the country since the end of January 2020.
https://www.statista.com/statistics/110...
MINSK, 23 March (BelTA) - More than 21,000 COVID-19 tests have been carried out in Belarus, BelTA learned from the press service of the Belarusian Healthcare Ministry.
"So far, Belarus has performed more than 21,000 COVID-19 tests. The testing began on 23 January. It should be mentioned that Belarus is among the top ten countries in terms of the number of tests performed.
https://eng.belta.by/society/view/over-...
Kdaj se je začelo testirat v EU? ;)
boolsheat ::
Vice je izjavil:
Točno o tem govorim... Ne vem česa nisi razumel?
drvo ::
Massacra je izjavil:
Po pomoti predlagal izbris.
GupeM ::
Horas je izjavil:
GenZNPC je izjavil:
Mogoče, po drugi strani pa če primerjaš njih in celotno EU, smo tukaj na slabšem. Večji prirast dnevno, več skupno okuženih... Res, da imamo tudi precej več prebivalcev, ampak vseeno. Zaenkrat smo kar tam-tam se mi zdi, oz smo mi celo na slabšem. Je pa res, da je v US v nekaj dneh šlo zelo na slabo.
Conini ::
8 od 26 jih je bilo iz Šmarij včeraj.
87 -> 95
V domovih za starejše po vsej Sloveniji je po doslej znanih podatkih z novim koronavirusom okuženih 109 oskrbovancev in 24 zaposlenih, so pojasnili na ministrstvu za delo. Predvsem v teh domovih se soočajo s premalo kadra in premalo zaščitne opreme, opozarjajo v Skupnosti socialnih zavodov Slovenije in združenju Srebrna nit. (STA)
SG_101 ::
Berem tale odlog o omejitvi gibanja pa mi ni cisto jasen. Ali lahko grem v drugo obcino na svojo parcelo, ker tam gradim hiso?
Badwolff ::
Vice je izjavil:
Če bi še za gripo pogledal koliko ljudi, ki umrejo, je čisto zdravih, bi ti procent tudi lepo padel.
Med biti ne čisto zdrav (recimo hipertenzija, po možnosti urejena z eno tableto dnevno, astma ipd) in tik pred smrtjo, tako da itak ne šteje, ker si že skor na uni strani, je kar veliko manevrskega prostora.
Pri nas so zaenkrat vsi na desni strani, stari in bolni. Ampak na respiratorju jih je pa kar nekaj takih, ki niso bili sploh še blizu tega.
Sicer pa stanje v Italiji jasno kaže na to, da gre le za mal hujšo gripo /s.
Zadnjič je poročal en ameriški dohter, da baje je preživetje na respiratorju s Covid19 15% worldwide. Seattle je bil po njegovem noro uspešen s 30%. Upajmo, da je pod 50. letom kaj bližje 50%.
energetik ::
Conini je izjavil:
87 -> 95
Vse oskrbovance so pa okužili nedeljski sprehajalci in motoristi!!111!!
  • spremenilo: energetik ()
Slopek ::
energetik je izjavil:
Conini je izjavil:
87 -> 95
Lažnivec!
Conini ::
abyssus ::
Mogoče se bomo zgledovali po Avstriji:
Austria: From Wednesday on, wearing masks in grocery stores is mandatory, and they should be worn everywhere where people come together. The masks are provided by the government and will be distributed at the entrance of supermarkets from Wednesday. No entrance without mask.
https://apps.derstandard.at/privacywall...
Conini je izjavil:
87 -> 95
Ter kolesarji pajkičarji na specialkah.
Conini je izjavil:
ehehe, ŠTER
Vodja konzularne službe dal gospodu na dopustu kratek nasvet: ''PEJT V KU*AC!''
Je fin kot gnojne vile.
Resno, tako se ne obnaša.
Keep Calm and Carry On pravijo Angleži.
  • spremenilo: sbawe64 ()
Vice ::
Vice je izjavil:
Ne ti govoriš o nečem drugem Se pravi 0,8% smrtnost?. Kaj ni jasno iz celotnega članka ki ga citiraš? Smrtnost v ITA je 10%. Od teh 10% jih je bilo 0.8% popolnoma zdravih. A je zato smrtnost samo 0.8%?
lexios ::
Conini je izjavil:
ehehe, ŠTER
Tak nasvet bi mu lahko dal jst, pa ne samo njemu, tudi gospodom v vladi in še kje, ampak za vodjo konzularne službe, ki to izjavi med službenim časom, se pa to ne spodobi! Te ljudi za takšne nasvete ne plačujemo. Po epidemiji bo potrebno na ulico, da se mal zredči JS!
https://www.worldometers.info/coronavir...
"Italija new cases +4,050"
Število okuženih je začelo padati v Italiji. Zgleda da gredo Italijani na bolje. Će bo še jutr šlo dol, pol se verjetno tole počas končuje.
  • spremenilo: Telbanc ()
lexios ::
@cvalsr
Nekaj malega debate je blo... Skoraj nič! Večinoma se tule "ugotavlja" ali je smrtnost 0.1% ali 10% ali kar 35x višja od gripe in če znamo šteti ter goni o ukrepih, ki omejujejo svobodo kolesarjem in rekreativcem... /s
V dveh mesecih bodo 'potalali' 3 milijarde oziroma eno tretjino državnega proračuna, dodatno potalali poleg običajnega financiranja! Od kod bodo vzeli?
Če ne bo častila Merklova: 1/4 proračuna je masa plač za birokracijo, predlagam, da se vzame tam, 1/12 pa naj častijo banke... Ali obratno, kot želite. Govora je blo o zamrzovanju kreditov, obresti pa lepo tečejo!
Badwolff ::
Glede nemškega štetja umrlih za Covid19 sem pa nekje tole zasledil. Nimam pa vira...
http://imgur.com/a/x6w0qOz
gusto ::
Badwolff je izjavil:
Ja saj pri nas je isti drek. Na veliko napišejo "Tretja žrtev koronavirusa v SLO", potem pa na majhno podnaslov, da je imela oseba n pridruženih kroničnih bolezni.
Have you tried turning it off and on again?
Badwolff ::
Tle je marsikdo govoril, da Nemci tega ne delajo tako.
Ampak človek, ki umre za zaradi respiratornih težav in je okužen s korono, je pač za v statistiko. Ne glede na pridružene bolezni.
Telbanc je izjavil:
Ja, so ze dosegli peak. Se vedno pa je novih okuzenih vec kot ozdravljenih (4k > 1,6k) . Se kaksen teden dni bo potrebno pocakati, da bo zdravstvu lazje.
harvey ::
O maskah na dolgo in široko, kaj, kako in predvsem o tem da koristijo tule v spodjem zapisu
https://medium.com/@Cancerwarrior/covid...
harvey ::
Conini je izjavil:
Virus preživi na površini od 24ur do 30 dni, nihče ne ve natančno.
30 dni? vir?
Vsak odkrit dedni material na površini še ni 'delujoč' infektiven virus. To je bilo recimo v primeru Diamond Princes, ko so po 17 dneh vzeli brise po ladji, da so videli kako bodo vse skupaj spucali, so v brisih pač dokazali virusno RNA ne pa kompletnega virusa in sledje so!potem mediji objavili z mastni naslovi po 17 dneh še virusi na ladji. Detajlno poročilo o tem kaj in kako so odkrili je na ameriški spletni strani CDC.
thetech ::
Telbanc je izjavil:
Ja, so ze dosegli peak..
Niso..
bozicje ::
Po podatkih italijanskega nacionalnega zdravstvenega instituta je povprecna starost umrlih bolnikov s korono 78 let.
90% je bilo starejsih od 70 let. 80% jih je imelo dve ali vec drugih kronicnih bolezni. Mlajsih od 50 let je bilo 1,5%. Zdravih oseb je bilo manj kot 1%.
Iz porocil pogostokrat ni razvidno ali je oseba umrla zaradi korone ali pa zaradi pred obstojece druge kronicne bolezni.
Dve umrli osebi sta bili mlajsi od 40 let. (obe 39 let) Ampak obe osebi sta imeli kronicno bolezen. Ena izmed oseb raka in druga oseba diabetes z dodatnimi zdravstvenimi komplikacijami. V obeh primerih ni razvidno, ali sta osebi umrli zaradi predhodnih kronicnih bolezni ali zaradi korone ali oboje.
https://www.epicentro.iss.it/coronaviru...
  • spremenilo: bozicje ()
kunigunda ::
itak37 je izjavil:
Tole na splosno nikoli nisem dobro razumel pri infekcijah. Po logiki si kuzen, cim imas v sebi virus, seveda na mestih kjer je prenosljivost (usta,nos,izlocki ipd), in je virus
aktiven (pri bakterijah verjetno dokler antibiotik svoje ne naredi). Seveda se simptomi pojavijo sele, ko se virus razpase, in je zato tudi vec virusa v prenosni poti.
In ko nimas simptomov vec, se stevilo prisotnosti aktivnega virusa mocno zmanjsa in si se kuzen, (oz. zgine in nisi vec kuzen).
Je mozno torej v teoriji se okuziti od nekoga, ki se je ravnokar okuzil (pa je stevilo virusnih celic se zelo zanemarljivo) ?
J.McLane ::
To je vse vprašanje verjetnosti in statistike, možno je marsikaj verjetno pa ne prav zelo.
PgSurfer ::
Belorusija je dočakala skok okuženih iz 94 na 152 (+58).
bozicje ::
V spaniji trije mlajsi od 65 let umrli. Trije od tisoc. Tudi to je vprasljivo, glede na to da porocajo o testerjih , ki prikazejo fejk pozitivno okuzbo.
https://www.20minutos.es/noticia/419388...
GupeM ::
To je tako ali tako vsr vprašljivo. Pišejo recimo, da umre n mlajših od 50 let. Ja, ampak vseh n je imelo vsaj še eno kronično bolezen.
Druga stvar, n oseb je umrlo, čeprav niso imeli nobenih drugih bolezni. Koliko so bili pa stari? 85? 95? 100?
157 / 355
