PC za kloniranje diskov
gabola ::
Zdravo!
Sestavljam PC, ki je optimiziran tudi za kloniranje diskov.
Ponavadi:
HDD 3.5" ali 2.5" na SSD 2.5" - SATA3
M.2 SSD SATA na M.2 NVME SSD
M.2 NVME SSD na M.2 NVME SSD
Plan je uporabljati 2x PCIE expansion cards for 1x M.2 SATA & M.2 PCIe x4.
Pomembno je, da ima PC integrirano grafiko. Če malo gledamo na budget, sem imel v mislih Ryzen 5 3400g + ROG Strix B450-F Gaming.
Problem je sledeči:
Expansion Slots:
AMD Ryzen™ 2nd Generation/ Ryzen™ 1st Generation Processors
2 x PCIe 3.0/2.0 x16 (x16 or x8/x4)
AMD Ryzen™ with Radeon™ Vega Graphics Processor
1 x PCIe 3.0/2.0 x16 (x8 mode)
AMD B450 chipset
1 x PCIe 2.0 x16 (max at x4 mode) *1
3 x PCIe 2.0 x1
Storage:
AMD Ryzen™ with Radeon™ Vega Graphics Processor : *2
1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)*3
2 x SATA 6Gb/s port(s)
AMD B450 chipset :
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
Intel sestava:
Intel i5 9600k + Z390 AORUS PRO WIFI (rev. 1.0)
Expansion Slots:
1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot operates at up to x8 mode.
1 x PCI Express x16 slot, running at x4 (PCIEX4)
3 x PCI Express x1 slots
(All of the PCI Express slots conform to PCI Express 3.0 standard.)
1 x M.2 Socket 1 connector for an Intel® CNVi wireless module (CNVI)
Storage Interface:
Chipset:
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe x4/x2 SSD support) (M2A)
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280 SATA and PCIe x4/x2 SSD support) (M2M)
6 x SATA 6Gb/s connectors
Support for RAID 0, RAID 1, RAID 5, and RAID 10
* Refer to "1-8 Internal Connectors," for the installation notices for the M.2 and SATA connectors.
Intel® Optane™ Memory Ready
Pri Gigabyte specifikaciji ni nič omenjeno, da ob uporabi integrirane grafike ( UHD 630 ) izgubiš PCie bandwidth / exp. slots, kot je primer pri Ryzen APU procesorjih. Je temu res tako?
Trenutno rabim le dva slota, hitrost Pcie 3.0 x4, bi bilo pa fino imeti dva slota PCIE 3.0 (x8), ko bodo v prihodnosti na voljo pcie 4.0 expansion cards.
Sicer bo še trajalo verjetno nekaj časa, preden bodo proizvajalci na veliko začeli vgrajevati v prenosnike PCI-e 4.0 m.2 ssd-je.
Hvala za morebitni odgovor!
lp. L
Katero 4K UHD grafično nadgradnja PC
91465 (1287) D-PaX
Matična plošča in M.2 ssd kompatibilnost
364649 (2868) FiLiPiNKO
M.2 diski
132004 (1644) WizzardOfOZ
V kateri slot na matični plošči vstavim R9 290?
102559 (2423) Ribič
Ne spozam se na grafične kartice. Prosim pomoč.
192875 (2424) DeeJay
