InspIRCd-3.3.0 - Delujoč config za ssl/tls?
HotBurek ::
Pozdravljeni.
Zanima me, če je komu že uspelo postavit InspIRCd-3.3.0 z configom, ki omogoča enkripcijo?
Certifikati so "pravilni", ker če jih uporabim v Nginx, delajo.
Konfiguracijo berem od tu:
https://docs.inspircd.org/3/modules/ssl...
Tole je delna trenutna konfiguracija inspircd.conf:
# add module
<module name="ssl_gnutls">
# fix binding
#<bind address="127.0.0.1" port="6667" type="clients">
<bind address="1.2.3.4" port="6667" type="clients">
<bind address="1.2.3.4" port="6697" type="clients" ssl="gnutls">
# add for gnutls
<sslprofile name="clients"
            provider="gnutls"
            cafile="/var/certificates/letsencrypt-full-chain.pem"
            certfile="/var/certificates/irc.some-site.cum.pem"
            crlfile=""
            dhfile="/etc/inspircd/dhparam.pem"
            hash="sha256"
            keyfile="/var/certificates/irc.some-site.cum.key"
            mindhbits="1024"
            outrecsize="1024"
            priority="NORMAL"
            requestclientcert="no"
            strictpriority="no">
# add logging
<log method="file"
     type="*"
     level="rawio"
     target="/var/log/inspircd/inspircd.log"
     flush="1">
V log fajlu ni neke detajlne razlage, zakaj ne dela:
Wed Sep 25 2019 11:30:57 SOCKET: Error on FD 8 - 'Connection closed'
Wed Sep 25 2019 11:30:57 USERS: QuitUser: 507AAAABH=507AAAABH 'Connection closed'
Wed Sep 25 2019 11:30:57 USEROUTPUT: C[507AAAABH] O ERROR :Closing link: (507AAAABH@some-dns-pointer...) [Connection closed]
Wed Sep 25 2019 11:30:57 SOCKET: DoWrite on errored or closed socket
Wed Sep 25 2019 11:30:57 SOCKET: Remove file descriptor: 8
Če poženem:
openssl s_client -connect irc.some-server.cum:6697
Dobim:
CONNECTED(00000003)
140530471437440:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../ssl/record/ssl3_record.c:332:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 5 bytes and written 304 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Prav tako v log fajlu ni error-jev, da kakega fajla ne more prebrati (prej sem to imel, pa sem popravil v apparmor). V syslog-u tudi nič ni.
Connection na port 6667 dela normalno.
root@debian:/# iptraf-ng
Please resize your window
Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )
Oddelek: Programiranje
1344387348 (127351) Macketina
Zanimiv ...hm... problem
Oddelek: Programska oprema
283408 (2903) poweroff
[Python] HTTPS na desktopu dela, na Arduinu ne
91948 (1561) N4g4c3N
Preverjanje veljavnosti certifikata na usmerjevalniku
Oddelek: Omrežja in internet
83633 (3302) xardas
[Ubuntu server] mail poslan iz serverja zazna kot vsiljeno pošto (strani: 1 2 )
7910968 (9938) shorvat
