Ohišje za računalnik
techuser ::
Izkušnje z ohišji inter-tech? Cenovno so zelo poceni, se splača kle šparat?
načeloma nebo panike, samo kvaliteten napajalc daj
acookook ::
Imam eno vprašanje na kerega še vedno ne najdem odgovora (ja mam ocd)pred časom sem postal na forum od msija odgovora pa še ni. Where to connect (probably the case LED on/off button) cable. MSI MAG Vampiric 011C case? By building this PC only one cable has remained unconnected. There is button by the front panel IO which fully works(HDD LED, ON status led, Power on, Reset, mic, headphones and all 3 USB ports work ), but just this one button doesn't . I don't know exactly where to connect it. Both manual and a video on youtube do not specify where should I connect it. I'd like to send and image, but because they are not allowed: It's a small white connector with a black and grey wire. There is no beeper and the are only 4 fans inside (2 on the GPU, 1 on the back of chassis and 1 CPU cooler)
SpaceX reusable rockets (nova tema)
296375 (5555) BigWhale
temp data logger
323727 (3147) maticm
Matrox Orbital LCD
91742 (1574) hmale
Submersed Cooling
113322 (2998) Tomi
Zvok z vecih cd-romov?
Oddelek: Zvok in slika
142564 (2335) Justy
