Kje na Microsoftovi spletni strani najti prenos za windows 10 Enterprise
Par dni nazaj sem si kupil licenčen ključ za Windows 10 Enterprise LTSC 2019, zdaj pa ne vem, kje bi ta windows dol prenesel. Iz raznih torrentov in ostalega, so po navadi Windowsi malo prirejeni ali pa so še kakšni neželeni dodatki notri.
Vem, da se iz uradne Microsoftove spletne strani da prenesti windows 10 Pro in Home, če se ne motim, za enterprise pa ne najdem.
Zdaj so imeli kar nekaj akcij za zelo poceni nakup Windowsov.
Zraven tega me še zanima, kakšna je razlika med Enterprise LTSC in Enterprise LTSB
OvCa77 ::
Lahko naložiš navaden pro in ga aktiviraš s tem ključem. Bo avtomatsko naredilo upgrade na enterprise.
Laptop: Probook 440 G3 | i5-6200U | 12GB DDR3L | SSD Plus 240GB
Desktop: Ryzen 1600X | Gigabyte AX370 K3 | 8GB DDR4 | MX100 256GB
Alexius Heristalski ::
Volume Licensing Service Center je mesto za prenose izdelkov Enterprise.
https://www.microsoft.com/licensing/ser...
LTSC in LTSB je isto, samo drugo ime:
https://docs.microsoft.com/en-us/window...
Naming changes
As part of the alignment with Windows 10 and Office 365 ProPlus, we are adopting common terminology to make it as easy as possible to understand the servicing process. Going forward, these are the new terms we will be using:
Semi-Annual Channel - We will be referring to Current Branch (CB) as "Semi-Annual Channel (Targeted)", while Current Branch for Business (CBB) will simply be referred to as "Semi-Annual Channel".
Long-Term Servicing Channel - The Long-Term Servicing Branch (LTSB) will be referred to as Long-Term Servicing Channel (LTSC).
Microsoft se ne šali: novi procesorji resnično terjajo nov Windows (strani: 1 2 3 )
11351784 (46192) AndrejO
Prva nadgradnja Windows 10 je tu (strani: 1 2 3 4 )
15875578 (66517) Lonsarg
Zadnja verzija Windows nared (strani: 1 2 3 4 5 )
221119010 (107665) MrStein
Windows 10 ukinja torek za popravke, krepi zaščito
1515456 (13134) M.B.
