Forum » Operacijski sistemi » Qualys SSL test | config, F sites
HotBurek ::
Pozdravljeni.
Zanima me, če uporabljate Qualys SSL za testiranje postavitve https strežnika, kakšen config uporabljate, ter kakšne F rated strani ste že našli.
4x 100% config za nginx 1.15.8:
Rezultat:
https://www.ssllabs.com/ssltest/analyze...
server {
listen 127.0.0.1:443 http2 ssl;
server_name example.com;
server_tokens off;
add_header Strict-Transport-Security 'max-age=31536000; includeSubDomains; preload' always;
add_header X-Frame-Options SAMEORIGIN;
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
root /var/www/html/example.com/;
ssl_certificate /var/certificates/example.com.pem;
ssl_certificate_key /var/certificates/example.com.key;
ssl_protocols TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers 'AES256+EECDH:AES256+EDH:!aNULL';
ssl_session_cache shared:TLS:2m;
ssl_buffer_size 4k;
ssl_stapling on;
ssl_stapling_verify on;
resolver 193.2.1.72 193.2.1.66 valid=300s;
resolver_timeout 5s;
ssl_ecdh_curve secp384r1;
ssl_dhparam /etc/nginx/dhparam.pem;
location / {
try_files $uri /index.html =404;
access_log /var/log/nginx/example.com/access-https.log;
error_log /var/log/nginx/example.com/error-https.log;
Rezultat:
root@debian:/# iptraf-ng
Please resize your window
| » | Javascript DOM based XSS vulnerabilityOddelek: Programiranje | 4457 (3879) | MrStein |
| » | Firefox mi ne dovoli dostopa do NLB KlikOddelek: Informacijska varnost | 10016 (7319) | Twixz |
| » | Nginx ne pošlje vseh HTTP headerjevOddelek: Izdelava spletišč | 1628 (1495) | BaRtMaN |
| » | Slo tech nepodprt protokolOddelek: Pomoč in nasveti | 1638 (1555) | gapoking |
| » | UKC Ljubljana kot nova slovenska potemkinova vas za blagor narodaOddelek: Novice / Varnost | 11787 (8975) | Saul Goodman |
