Forum » Strojna oprema » NVIDIA Ampere (2020)
Bwaze6 ::
JayzTwoCents na twitterju:
I've now had the following GPU owners express they have had shut downs and failures with New World...
RX590
6800
6800XT
6900XT
3080Ti
3090
So once again, the issue definitely is with SOMETHING in the way the game New World is rendering. This ISNT a 3090'exclusive issue! PERIOD!!
Skyman ::
Drugace pa Mindfactory ima gigabyte 3080 VISION OC 1159€..pocasi pocasi padajo tudi 3080.AORUS GeForce RTX 3080 Master 10G 1240€
Bwaze6 ::
Še za 200 EUR padejo cene 3080, pa bojo v Nemčiji take kot decembra in v začetku januarja v slovenskih trgovinah, ko jih ni hotel noben gamer kupit.
3060Ti mora past na 500€. To bodo best-buy kartice.
Bwaze, imaš tedenski podatek MF prodaje med AMD in Nvidio? Bi bilo zanimivo videt sveže cifre, ker že lep čas nisi prilepel tedenskega poročila. ;)
FlyingBee ::
Minimalc 770 eur, zdaj pa prava računalniška številka 1024 eur. Liter bencina sem s prvim avtom 80c plačeval, zdaj pa 130c pa vmes manj pa tudi še več.
New Sphincter Kvartet:
Zgolj 330 prodanih Radeonov v preteklem tednu, kar je absolutni negativni rekord v 2021? Te prodajne številke izgledajo tako, kot bi AMD in Nvidia načrtno omejila proizvodnjo z namenom, da ne bi padle cene. Teorija zarote!
- spremenil: DarwiN ()
FlyingBee ::
NV in AMD verjetno raje več prodata, od teh visokih cen imajo največ posredniki.
Verjetno manjka üe kak monitoring chip....
Users on the official New World forum have reported the same issue: GeForce RTX 3090 GPUs completely frying, even after just a short time playing the beta. Gladd, a Twitch streamer with over 438,000 followers, tweeted that his card had suffered the same fate.
In JTC
Beware! This game could brick your GPU! WARNING!
In JTC
Kupci so prav tako začeli špekulirat na približevanje MSRP cenam v nekaj mecesih.
Skyman ::
Zgleda da gre napako v dizajnu pri evgi?
https://wccftech.com/evga-geforce-rtx-3...
As I was able to find out, it is not an area of the voltage converter that is affected by the failure, but the "Fan Control IC", i.e. the chip for the actual fan control, which is said to be completely burnt out in the worst case. We do remember that EVGA is also working with various additional temperature sensors on the board to better adjust the cooling, based on my research at the time. This is also evidenced by submissions from the aggrieved parties who reported extreme fan whine.
-- Igor Wallossek, Igor's Lab
Asus 3090 sem žele pred kratkim zasledil drobiš pod 2000. Prej vseskozi 2000+
Še za 200 EUR padejo cene 3080, pa bojo v Nemčiji take kot decembra in v začetku januarja v slovenskih trgovinah, ko jih ni hotel noben gamer kupit.![]()
Žalostno a resnično: izkazalo se je, da gamerji nimajo kupne moči.
So pa zelo glasni.
AMD se vseskozi pogaja, da povečujejo proizvodnjo.
- spremenilo: FireSnake ()
Tudi v naših trgovinah gre na bolje, za common sense gre pohvaliti npr. Funtech:
https://www.funtech.si/si/vsi-oddelki/k...
Gainward RTX 3070 TI PHOENIX za 916,44EUR. Ups. Medtem, ko sem tipkal, so ceno popravili v 940,20EUR.
Pri Enaa so 3070Ti tam okoli 1250EUR.
- spremenil: Jarno ()
In 8 gb vrama, niste resni.
Bwaze6 ::
So pa zelo glasni.
Hm, kje pa je zdaj kupna moč kriptošpekulantov?
Zaradi gamerjev sploh imamo industrijo 3D pospešenih grafičnih kartic. Kriptaši so le občasne pijavke, ki nekaj mesecev sicer kupijo vse, a trg bo moral potem dve leti (če bo tako kot ob zadnjem padcu) trpeti "kupno moč gamerjev"...
- spremenilo: Bwaze6 ()
inzenir1337 ::
Kaj naj ti povem. Kupi še kakšnih 50 kartic non-LHR dokler so. Pa srečno in uspešno!
Horas ::
kar bomba cena STRIX 3080 OC 1249€
https://www.arlt.com/Gaming/Gaming-Hard...
a se zajebavaš? predraga če že ne kar 450€!!!
Skyman ::
Seveda da je vse predrago,samo glede na cene zadnih nekaj mesecev si za 1200EUR dobil samo giga**** je to kar dobra kartica za ta denar,in glede na to kaj "folk" prodaja povsod na portalih za ta denar rajse to vzamem.Je pa seveda res da ta kartica bi morala biti max 900EUR,dvomim pa da je predraga za 450EUR,glede na to da ko je prisla 30 serija vn je bila cena 950EUR na casekingu(jo je kolega cakal in še ni docakal ker je sla potem samo cena gor in gor)
Je pa še vedno cenejsa kot na uradnem webshop asus nemskemu..
- spremenil: Skyman ()
LHR verzija. Zato pa je zaloga.
So "običajne" še sploh kje na zalogi?
Nope.. Stornirajo naročilo, podobno kot Mediamarkt/Saturn in po novem očitno tudi Alternate.
inzenir1337 ::
Danes testiral zverino Gigabyte GeForce RTX 3090 AORUS Xtreme. Navita pije 475W. Nenormalno. Glede na to da je cena 2k bi skoraj morala biti z vodnim, ker stvar se greje tko like uibr.
Se mi zdi da je za rajo še vseeno najboljša kartica RTX 3060 Ti za pecto šecto evričev. Undervoltana ti pije max 180W in je hladna ko špricer.
FlyingBee ::
Photo or it didnt happen.
Amdforce ::
inzenir1337 je izjavil:
Kaj pa vem, moja aoruska sicer 3080 je hladna k spricer, ena najboljših 3080k so far...
Horas ::
tega inženirja modra riba ne bi brisala mene bo pa spet za brezveze
aouruske sploh pa xtreme se ne rpegrevajo so dokaj hladne! tk da ne trolaj
inzenir1337 ::
Kdaj si jo pa ti testiral? Mogoče imava različne variante in potem ni čudno da sva prišla do različnih rezultatov. Ampak mislim da je za Xtreme samo ena Rev., Master pa ima Rev. 1.0 in Rev. 2.0. Popravi me če se motim?
Bwaze6 ::
Ogromno na izkušnjo vpliva že ohišje računalnika oz. nastavitev ventov, in pa sama temperatura sobe.
Če ohišje ni dovolj prevetreno, bo 400+W zelo hitro naredilo učinek tople grede.
Prav tako imaš problem, če je v sobi že 30 stopinj, ti pa pričakuješ, da bo grafična idlala pod to temperaturo, ob obremenitvi pa le kakih 20 stopinj toplejša... Ne bo šlo.
Eni imajo pač nerealistična pričakovanja. Tudi vodno hlajenje pri takšni porabi ne dela čudežev. Konec koncev je PC s high end grafično in močnim procesorjem ob polni obremenitvi na koncu pač 500 - 700 W radiator.
FlyingBee ::
Ja, za manjša ohišja je 250w grafična vrh glave, se pa z xl ohišjem in 3 venti lahko naredi precej boljšo izkušnjo tudi pri 350w grafični. Seveda je treba po testu napisat še temperaturo sobe, zaprto, odprto ohišje in kako prevetreno. Recimo, da je 144hz optimalna izkušnja tudi za 3090 ali 6900xt in tak cap fpsjev lahko naredi razliko v porabi. V Doom Eternal je velika razlika v porabi grafične, če je sync vklopljen.
- spremenil: FlyingBee ()
Amdforce ::
Imam exteme in master.....obe v rudniku na 103 mh/s
- spremenilo: Amdforce ()
inzenir1337 ::
V rudniku je vsaka kartica hladna. 100% fan in -502MHz core, znižana voltaža, 80db hrupa. To ti bo dalo hladno karto ne glede na to na koliko imaš navito memorijo.
Kar je, seveda, še en idiotizem!
Še en dokaz, da novejših nVidia kartic niti na polici nisi videl.
Noro.
Se ve zdaj bolj natančno kaj je vzrok?
Zakaj do tega pride je jasno: menu je bil prav tako renderiran in slime na sekundo so letele v nebo in temu primerno obremenile grafično kartico.
Bwaze6 ::
Ampak načeloma imajo grafične kartice ogromno samopreverjanja, in se v bistvu ob previsoki obremenitvi downclockajo. Zato tudi overclockanje ni več tako straight forward, višaj frekvenco, dokler ne najdeš maksimalne stabilne, tudi spomin ima error correction in ga lahko spraviš v previsoke frekvence, ko zaradi popravljanja napak dela počasneje kot na privzeti - ampak kartica je pa običajno stabilna, in je daleč od tega, da bi se okvarila. Poleg tega imajo kartice zdaj dobro termalno kontrolo (s previsoko temperaturo se downclockajo, ali ob res kritični zaustavijo), omejeno moč delovanja (zato tudi izjemno omejen obseg overclockanja)...
Težko si v bistvu sploh predstavljam, kako bi z overclockanjem in poganjanjem česa res brutalnega - npr. Furmarka zdaj kartico uničil. Kako da uspe nekemu meniju uničiti kartico na stock nastavitvah, mi je pa dokaj uganka.
Vmes je bilo zaslediti ravno to, kar omenjaš: premalo "tipal".
Zato je imeti hitro grafično, ki pa pije 350W tako-tako.
Ko se nek denar obrne bom jaz za svojo kupil vodno hlajenje (za zdaj sem jo samo modificiral s hladilnimi rebri).
inzenir1337 ::
Jaz bi na tvojem mestu punci kupil kar EKWB hlajenje. 3090 ti bo hvaležna in ko je brhka krasotica hvaležna je pripravljena zate storiti vse. Dala ti bo lepe FPSje in čudovit render. Toliko iz inženirskega stališča. Zdaj pa še eno splošno vprašanje: Ali je to recall vseh 3090 kartic zaradi tega dogodka ali je to samo za EVGA FTW3 kartice ali je to samo za že brickane kartice?
Noro.
Kot kaže RTX 3090 ni edina kartica, ki ima probleme z igro New World.
RX590
6800
6800XT
6900XT
3080Ti
3090
https://www.tomshardware.com/news/evga-...
Wrop ::
FlyingBee ::
Zato pa bodo dobili vsi reklamacijsko zamenjavo. Grafična, ki med igro crkne v garancijskem roku, je upravičeno zamenjana.
Skyman ::
MSI RTX 3080 GAMING Z TRIO 10G LHR 1150€...stacuna pa tud ena cunga lunga :P
https://www.dodax.de/de-de/elektronik-c...
inzenir1337 ::
Zanimivo. LHR kartice niso nič kaj dosti cenejše od non-LHR. Novembra si RTX 3080 dobil za 899€, za božič za 999€. Nekriplane.
