Forum » Kriptovalute in blockchain » Spekuliranje cen kriptovalut in ICOjev part 2
Jacksmav ::
Živjo...hm..sam še nisem dobil nič dunov...pa imam na k1...še kdo ni dobil...al bi moral kam prestavit....
- spremenilo: Jacksmav ()
neverlucky ::
Ce si imel na tezos denarnici, potem bi moral dobit.
Vnesi naslov isti kot ga imaš za Tezos Wallet:
https://dunscan.io/
Če Dunetov nimaš, potem jih ne boš dobil.
https://dunscan.io/
Jacksmav ::
neverlucky je izjavil:
https://dunscan.io/
če vnesem v dun scan tz1 kjer nimam nič xtz imam vse na kt1...prazna denarnica mi pa dunu pokaže kao stanje...v denarnici pa nič...moraš kreirat za dune novo denarnico....se tudi duni delegirajo...
Torej imamo kak guide kako pridobit te tokene?
Vazelin ::
Naj en napiše lol.
Dune scan mi napiše sladko stanje ampak sedaj je treba nardit denarjico
Dune se drži 5 let
Dune se drži 5 let
- spremenilo: Vazelin ()
Mah, Dune bom prodal instant... kar bom pač dobil zanj, razen če bo vredno oz. je manj kot 200€...
Senior Dev ::
Kdo gre jutri v penzijo od prodaje kriptožetonov in kdo še vedno hodi na šiht? Roke gor.
neverlucky ::
Ja za dune tokene bo posebi denarnica iz katere boste to dol potegnli. Itak bo pa še nekaj mesecev, preden bo to prišlo na prve exchange.
PrihajaNodi ::
1. Generate a fresh address (and private key) on Dune Network (for instance using Dune wallet);
2. Go to Dunscan.io and paste the dn1 obtained from step 1 in the search bar, then hit Go;
3. click on the TZ symbol in "Account Details" and copy the displayed tz address;
4. Log in to your Tezbox wallet and restore your Tezos account using the credentials of your original address (provide the mnemomics, or the private key, or connect your ledger, depending on your situation);
5. In your Tezbox account, go to settings (top right) and change the address of the RPC node to https://mainnet-node.dunscan.io. Once this change is made, Tezbox will show you a balance XXX XTZ on the main page, but they are actually $DUNs coins;
6. In your Tezbox account, transfer your coins to the tz address you copied at step 3 (Tezbox doesn't understand dn addresses). Start by sending a small amount (eg. 1 UNIT) from Tezbox wallet to Dune wallet. Then, send back a small amount (eg. 0.5 DUN) from Dune wallet to Tezbox. If everything works as expected, you can transfer the rest of your coins from Tezbox to Dune wallet (ie. to the tz address you copied at step 3).
Once all these steps are done, you will have your XTZ and $DUN coins on two different addresses with two different private keys. You can now use Dune wallet without sharing your Tezos credentials.
Don't forget to restore the settings of your Tezbox wallet at the end! Go back to Tezbox settings (top right) and put the original RPC node address: to https://mainnet.tezrpc.me.
Dune lahko že sedaj daš stejkat.
Vazelin jih imaš preko 5k?
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
PrihajaNodi ::
Pa saj si naredil lep buy back, če me spomin ne vara.
Vidim, da je kare veliko bejkerjov na dune omrežju.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
- spremenilo: PrihajaNodi ()
Vazelin ::
Upam da bo lansiranje Dunota sovpadalo z novim bull runom.
tonis ::
Vazelin ::
PrihajaNodi je izjavil:
Vazelin poglej volume Nebla...
Ja :/
A ma kraken kake težave? En kolega je včeraj withdrawal nelaj eur in še vedno ni prošlo na račun?
PrihajaNodi ::
Kaj pa ce bi njih vprasal? Mislim a je folk res tolk nesposoben. Preko ibana bodo isledil, samo si vzamejo 5 delovnih dni preden zacnejo raziskovat. Javi naslednji teden, ce ne bo nic.
In pol tak folk po 100k in vec vn vlece. Sej ne da bi poskusil prej povlect dol 5, 10 eur, da preveri ce deluje.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
PrihajaNodi ::
Btw Tezos v Izraelu:) kjer so zidje notr je vedno ok:)
Monacon je ok za trejdat.
Nodi: shill me next x10 coin!
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Vazelin ::
na konc bo res ostal samo še btc in tezus. aja pa dune
PrihajaNodi ::
Karte se bodo pomesale pri vrhu. Tam dol pri p&d coinih je pa itak vseeno.
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
PrihajaNodi ::
Mja no. Viberate pa se kar hara tam, pa se lep volume ma. Musiccoin ja...
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Vazelin ::
ej nodi se spomnim ko je bil music coin 60mio cap-a.
se spomnim da smo ga kupovali natanko na vrhuncu :D
PrihajaNodi ::
Sem tudi zcl omenjal. Casi so se spremenili. Norega vrtiljaka je konec.
Zamenjalo se je v pametnejse in varnejse nalozbe. Pa itak si skor z vsakim kovancem delal profit.
Aja Arthur B (Tezos) in Vitalik sta imela skupaj konferenco:)
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Vazelin ::
- predlagal izbris: amacar ()
PersonaRuda ::
https://www.theblockcrypto.com/post/397...
Kamikaze tvoj monero gre v smeti.
1% celotnega prometa je bilo dnevno na tej borzi in sedaj naj bi zaradi delistanja šel v smeti
Prej bo ta borza šla v smeti kot pa Monero.
- spremenil: PersonaRuda ()
PrihajaNodi ::
10% gre gor tu pa hladni ko spricer, to je za danes kot 200%. Kripto ni vec to kar je bil:)
Pa saj ne da moras banki placat za lezarnino:)
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Vazelin ::
Zanimivo kako je tema umrla. Medtem ko je prebrodila viharno leto 2018 je letošnji fake mini bull popolno razdejal lokalno sceno.
Perci že 2 tedna ni pobrisal enega posta
Vazelin ::
NODI: si že videl nov reklamni pano za EuroJackpot? Nekaj najboljšega ever. Dobitnik jezdi samoroga
Skoraj sem se zaletil tako sem lolnil.
PrihajaNodi ::
Si predstavljas da kripl pride na 5?
Ti pa deep balls v Tezosu...
#OstaniDoma
#StaiAcasa
#SpikajmoSEvsi
#StaiAcasa
#SpikajmoSEvsi
Zanimivo kako je tema umrla.Ti pa Nodi si vsekakor zaslužita nagrado za zasluge na tem področju.
Ti pa za celoten preostal forum z izjemo morda tehnicnih vprasanj..
neverlucky ::
Tema je zamrla tudi zaradi tega, ker se je vecina kripto debat prestavila v privatne teme. Te so se kako zivahne. Zadnje dni, ko dozivljamo novo alt sezono je se posebej pestro.
Zamrla je pa tudi zaradi tega, ker vsak, ki pove malo bolj alternativno mnenje in ima alternativna znanja, je tu takoj napaden in zatrjen ze v kali.
Ko se bo miselnost v temi malo spremenila, bo pa tudi tukaj kaj drugace.
Tema je zamrla ker je perci dopuscal pure trollanje neuravnovesenih osebkov od 4knativa naprej... Simpl. Po tistem trolanju je vsaka debata bila nekoristna
hamez66 ::
Sej na začetku je bil 4knative še kar duhovit.
Glede signalov, ki sem jih omenjal pred približno 10 dnevi... Včeraj je en "prijel", saj je bila napoved, da če cena pride na 10361, da bo padla na 9792. Sam sem vstopil pri 10310 (signal sem prebral šele po tistem, ko je cena bitcoina že dosegla 10361, ampak če bi ga takoj prebral, bi imel možnost vstopiti pri tisti ceni - tako sem bil pa nekaj ur prepozen) in potem tudi izstopil pri 10110, tako da kar se mene tiče, je to zdaj tretjič od treh poskusov, da sem imel pozitiven trejd, ampak da bo signal dejansko pravilen, bi morala cena v naslednjih 3 dneh pasti na 9792. V preteklosti naj bi se podoben vzorec ponovil 6 od 6x.
Lahko bi sicer že včeraj napisal komentar (in pravzaprav sem ga, ampak ko sem pritisnil tipko "pošlji", me je odlogiralo in potem nisem ponavljal), ampak mam malo slabo vest, ker sem toliko časa težil sloteharju oz aquafriendu glede teh signalov, zdaj jih pa sam promoviram.
V glavnem, včeraj je meni signal pomagal, sem pa trejd "predčasno" zaprl. Signal je pravilno nakazal na short pri 10361, ali bo pravilno zadel tudi dno, oz. ali bo bitcoin dosegel 9792, bomo pa še videli. Jaz ne bom zdaj samo gledal, kaj se bo dogajalo in ne bom vstopil v novo pozicijo. Poleg tega je tale dvig cen alt coinov precej bullish in nekako ne vidim dviga cen altov kot nekaj, kar bi negativno vplivalo na ceno bitcoina.
zlabra ::
hamez66 ::
Tm en tip, k mu sledim na twitterju, je napisal, da bo dno takrat, ko bo že vsak kloven govoril o shortanju coinov...
Žal ga nisem poslušal. :)
perci ::
Tile signali so isto kot oni za kladionice hamez.... 7x bo mel prav pol bo pa pihnil 2 ali 3x po vrsti in na koncu bos komaj kaj na boljsem
Ali po domace taki signali se dolgorocno nikoli ne izidejo kratkorocno so pa gembl... Razen ce vlagas po 50k na trade in sluzis 100take najmanj od tega...
Jacksmav ::
a je komu ratal prenest dune na svojo denarnico...je zdaj live...https://medium.com/@dune_network/projec...
men na na tezos walletu ne sprejme naslova od dune denarnice... so pa isledljivi na dunscan.io...in naj bi se nahajali v denarnico od xtz..na tz1...nisem pa probal kot je nodi nekaj prilepil....
je kdo poskusil po tem receptu prenest dune na svojo denarnico...
Jaz bom se malo pocakal... Da potem v miru prenesem ko bo ziher delalo
Jacksmav ::
meni jih pokaže ko v tezbox spremenim rpc node na dune...ko pa dam send pa copy paste od dunescan tz1..pa pravi, da ne morem sam sebi pošiljat...svašta...
Jacksmav ::
ekola dela...odpreš si novo denarnico dune https://wallet.dune.network/
greš na https://dunscan.io/ vneseš svoj dune naslov in ko se ti odpre klikneš desno pod dune številko znak tezos in se ti generira xtz naslov
Odpreš si tezbox wallet greš na prvi account tz1 greš desno pod nastavitve levi gumb od ključa in spremeniš rpn na https://mainnet-node.dunscan.io
Greš pod send in vneseš naslov kt1 iz dunscana pošlješ 5 kom in spremeniš na medium cost...počakaš par trenutkov in ekola...je že v denarnici...drugič pa sem moral nastavit na low cost da je poslalo...na koncu nazaj spremeniš v tezboxu rpn na https://mainnet.tezrpc.me
to je to...hehe
to je to...hehe
