Forum » Omrežja in internet » whois od Sysinternals
CyberPunk ::
Je kdo kje zasledil, zakaj whois od Sysinternals izvede več zaporednih oz. ponovljenih queryjev (posledično včasih blokira dostop, too many queries ipd.)? To se dogaja v verziji 1.20 in še eni prej - pred tem je bilo normalno, en query in konec.
Čudno se mi zdi, da ne bi tega popravili, ker traja že nekaj časa.
CyberPunk ::
Server. Npr. poizvedba po domeni najprej zalaufa Connecting to NET.whois-servers.net, sledi Connecting to whois.internet.bs, ki ga naredi 5x zapored (z rezultati), nakar server seveda v 6 poskusu izpise:
Ne vem, zakaj bi sploh moral delati zaporedne queryje po tem, ko ze v prvem (oz. drugem) pridobi vse informacije.
Ce npr. pogledam domeno 24ur.com, ponovitev ni, medtem ko se za slo-tech.com, sploh ne neha (Connecting to WHOIS.ENOM.COM... ponavlja v nedogled, dokler rocno ne prekines):
Connecting to whois.internet.bs... We are unable to process your request at this time. The whois informationis unav ailable for domain for one of the following reasons: (1) Too many simulataneous connections from your host; (2) The domain you requested is not with this Registrar; (3) You have exceeded your query limit; (4) Your IP address has been restricted; (5) Whois data is not available for this domain - check back in 48 hours when ou r server is updated; (6) Access has been restricted to ensure operational stability; (7) A system error has occurred; (8) The time limit for your request has expired; (9) The IP address provided is not valid or the host specified by the IP address does not exist; (10) There is an error in what you have inputed or requested; (11) An unknown error has occurred; (12) The domain is not currently registered; (13) The domain you requested contains invalid characters; (14) The domain you requested is too long; (15) The domain you requested begins or ends with a dash; (16) The domain you requested is a third or fourth level domain; (17) You did not specify a domain name. Connecting to to process your request at this time. The whois informationis unav ailable for domain for one of the following reasons:... The requested name is valid, but no data of the requested type was found.
whois slo-tech.com
Whois v1.20 - Domain information lookup
Copyright (C) 2005-2017 Mark Russinovich
Sysinternals - www.sysinternals.com
Connecting to COM.whois-servers.net...
WHOIS Server: whois.enom.com
Registrar URL: http://www.enom.com
Updated Date: 2017-03-03T17:31:30Z
Creation Date: 2000-04-21T09:24:03Z
Registry Expiry Date: 2023-04-21T09:24:03Z
Registrar: eNom, Inc.
Registrar IANA ID: 48
Registrar Abuse Contact Email:
Registrar Abuse Contact Phone:
Domain Status: clientTransferProhibited https://icann.org/epp#clientTransferProhibited
Name Server: NS-1035.AWSDNS-01.ORG
Name Server: NS-1831.AWSDNS-36.CO.UK
Name Server: NS-393.AWSDNS-49.COM
Name Server: NS-754.AWSDNS-30.NET
Name Server: NS.DATACENTER.SI
Name Server: NS.SLO-TECH.COM
Name Server: NS1.TRIERA.NET
Name Server: NS2.AMIS.NET
Name Server: NS2.DATACENTER.SI
Name Server: NS3.AMIS.NET
DNSSEC: unsigned
URL of the ICANN Whois Inaccuracy Complaint Form: https://www.icann.org/wicf/
>>> Last update of whois database: 2018-10-29T11:07:08Z <<<
For more information on Whois status codes, please visit https://icann.org/epp
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar. Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability. VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
reserves the right to modify these terms at any time.
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
Connecting to whois.enom.com...
WHOIS Server: WHOIS.ENOM.COM
Registrar URL: WWW.ENOM.COM
Updated Date: 2014-05-03T09:16:04.00Z
Creation Date: 2000-04-21T09:24:03.00Z
Registrar Registration Expiration Date: 2023-04-21T09:24:00.00Z
Registrar: ENOM, INC.
Domain Status: registrar-lock* https://www.icann.org/epp#registrar-lock*
Registrant Name: REDACTED FOR PRIVACY
Registrant Organization: REDACTED FOR PRIVACY
Registrant Street: REDACTED FOR PRIVACY
Registrant Street:
Registrant City: REDACTED FOR PRIVACY
Registrant State/Province: REDACTED FOR PRIVACY
Registrant Postal Code: REDACTED FOR PRIVACY
Registrant Country: REDACTED FOR PRIVACY
Registrant Phone: REDACTED FOR PRIVACY
Registrant Phone Ext:
Registrant Fax: REDACTED FOR PRIVACY
Registrant Email: REDACTED FOR PRIVACY
Admin Name: REDACTED FOR PRIVACY
Admin Organization: REDACTED FOR PRIVACY
Admin Street: REDACTED FOR PRIVACY
Admin Street:
Admin City: REDACTED FOR PRIVACY
Admin State/Province: REDACTED FOR PRIVACY
Admin Postal Code: REDACTED FOR PRIVACY
Admin Country: REDACTED FOR PRIVACY
Admin Phone: REDACTED FOR PRIVACY
Admin Phone Ext:
Admin Fax: REDACTED FOR PRIVACY
Admin Email: REDACTED FOR PRIVACY
Tech Name: REDACTED FOR PRIVACY
Tech Organization: REDACTED FOR PRIVACY
Tech Street: REDACTED FOR PRIVACY
Tech Street:
Tech City: REDACTED FOR PRIVACY
Tech State/Province: REDACTED FOR PRIVACY
Tech Postal Code: REDACTED FOR PRIVACY
Tech Country: REDACTED FOR PRIVACY
Tech Phone: REDACTED FOR PRIVACY
Tech Phone Ext:
Tech Fax: REDACTED FOR PRIVACY
Tech Email: REDACTED FOR PRIVACY
DNSSEC: UNSIGNED
Registrar Abuse Contact Email: ABUSE@ENOM.COM
Registrar Abuse Contact Phone: +1.4259744689
URL of the ICANN WHOIS Data Problem Reporting System: HTTP://WDPRS.INTERNIC.NET/
>>> Last update of WHOIS database: 2014-05-03T09:16:04.00Z <<<
The data in this whois database is provided to you for information
purposes only, that is, to assist you in obtaining information about or
related to a domain name registration record. We make this information
available "as is," and do not guarantee its accuracy. By submitting a
whois query, you agree that you will use this data only for lawful
purposes and that, under no circumstances will you use this data to: (1)
enable high volume, automated, electronic processes that stress or load
this whois database system providing you this information; or (2) allow,
enable, or otherwise support the transmission of mass unsolicited,
commercial advertising or solicitations via direct mail, electronic
mail, or by telephone. The compilation, repackaging, dissemination or
other use of this data is expressly prohibited without prior written
consent from us.
We reserve the right to modify these terms at any time. By submitting
this query, you agree to abide by these terms.
Version 6.3 4/3/2002 Vredno ogleda ...
| » | kako-shujsati.net kontaktOddelek: Loža | 4564 (3779) | Phantomeye |
| » | KuponlandiaOddelek: Loža | 15965 (9807) | MadMen |
| » | agej hadžiselimovićOddelek: Loža | 6159 (2819) | Yohan del Sud |
| » | Išče se nov registrar domen .netOddelek: Novice / Omrežja / internet | 5379 (3781) | Mare2 |
| » | SIOL - zapira stacuno !? :-)Oddelek: Omrežja in internet | 4263 (3131) | FastWIND |
