Forum » Strojna oprema » Intel Core 9th-gen
Intel Core 9th-gen
gustek_si ::
gendale2018 je izjavil:
https://www.caseking.de/der8auer-core-i...
če ima kdo preveč denarja
škoda da ni 9600k 6c/12t, 9700k 8c/16t, 9900k pa 12c/24t...
A to je ok za igrice špilat? Saj če tako gledaš 930€ niti ni tako dosti - en malo dražji telefon. Za 3k si sestaviš že lep rig za igranje igric. Money well spent, time well spent, go for it!
FlyingBee ::
Ka si nor? Za igrce je 7700k max kar bi sploh kdo rabil, za 4k resolucijo pa 2600. Če hočeš absolutno najhitrejšega, veš kam se obrniti.
Ni mi jasno, ryzen 1 je že maturiral, ryzen 2 je še boljši, oba pa se cenita na vsake pol leta, pa Intel rekordne zaslužke dela, ravno na consumer segmentu (16% year-over-year increase in revenue) je tudi lepo rast prikazal.
https://www.tomshardware.com/news/intel...
That explosive growth comes against the backdrop of the first growth in the PC market it seven years, but the market only expanded by one to two percent. That makes the 16% growth even more impressive. We usually expect this type of uptick after a wave of new processors come to market, but Intel's 9th Gen processors, which it released last week, aren't included in the figures.
The Client Computing Group (CCG), the arm that produces desktop processors, experienced a particularly impressive uptick, especially considering the recent debut of AMD's second-gen Ryzen processors. That group posted a 16% year-over-year increase in revenue to $10.2B, setting yet another record
To je to kar sm že večkrat ponovil, na svetu je ogromno ljudi, ki pač ob razliki samo par 10€ ,kot je bila donedavna, vzamejo boljši produkt (Intel). Dejstvo da se pa dobro prodajajo še celo zdaj, ko so cene bistveno višje pa najbrž pomeni, da prejšnjih cen ne bomo več videli (malo se bojo najbrž spustile, bistveno pa ne). Na koncu bo še meni žal da nisem tam maja vzel 8700k, pa magari če bi z nakupom rama malo počakal potem...
Ce ponavljas laz, jo se ne spremenis v resnico. Oba tabora imata svoje prednosti in slabosti. Vsak zase pa se odloci kaj mu je bolj pomembno. Dejsto pa je, da veliko uporabniko tega tko ni sposobna narediti. Pri trenutnih cena pa moras biti ze hard core INTEL fanbojcek.
Sam domnevam ,da ima precejsnji vpliv na trenutni bottom line, nadgradnja CPUjem zaradi vseh ranljivost, ki so bile odkrite v zadnjem casu.
galu ::
AapocalypseE je izjavil:
Tukaj še je 9700K na zalogi, za malo manj kot na caseking.
https://www.computeruniverse.net/de/int...
Za ta denar ga naj kar majo.
Tako to gre.
AapocalypseE ::
Za ta denar ga naj kar majo.![]()
Pri nas sem našel pri Mimovrste za 473€, ampak ga ni na zalogi. Enaa piše dobava 5.11, tako da bo tukaj tudi nekje tam.
https://www.mimovrste.com/procesorji/in...
Ja, saj jih ne; za povprečnega uporabnika so že 6/6 CPU-ji (ali 4/8, samo teh Intel pač nima več) polna kapa, za gaming recimo (ki je pri večini ljudi najbolj zahteven task) itak že 8600k povozi vsakega Ryzena (v večini primerov pa že 8400), če ne gejmaš pa bo večinoma zadoščal že 2/4 Pentium. 9900k so pač ven dali zaradi prestiža, da se ne more reči, da AMD na mainstream platformi ima nekaj česar Intel nima. Kdor je pa zares rabil 8/16 cpu, pa ga je pri njih lahko dobil že skoraj 9 let nazaj (marec 2010!).
Toliko bullshita v enem postu pa še nisem videl.
AapocalypseE ::
Poste od tikitoki in gustek si, ne gledat sploh, kaj šele resno jemat, ker so troll posti.
AapocalypseE ::
To kaj vidim od njiju, so HC troll posti in ni nobenega forma...
Treer pa vsaj napiše kaj pametnega, ampak, ker rdečim ni všeč, če jim napišeš da ryzen ni top, pač je pol tako kot je...
Ko imas opravka z nvidioti, potem je pac debata temu primerna.
FlyingBee ::
Eh, kaj pa ima veze katera firma je na vrhu, AMD bi tudi rad bil in imel višje cene. Ryznu ne niža cen, ker ima Robin Hoodovski navdih, amapk ker ne prodaja dovolj.
gddr85 ::
prvi 8/16 si dobil že day one za cca 300 bucks (razen x verzije), celo manj od 7700k kilerja afair...čas, v katerem si imel kej takega samo pri intel hedt robi, cena pa x2
FlyingBee ::
Ja, tako pač gre, pa saj, kje pa toliko rabiš 8/16, da ti je to rešilo ne vem kakšno težavo. Verjamem, da nekaterim res je, ampak taki so se vedno znali skeširat in zakaj bi Intel poceni prodajal 8/16, če je že imel konkurenčno prednost. A AMD bi kar tako podarjal dobiček, če mu ne bi bilo treba?
gddr85 ::
vzel si, če si rabil poceni 8/16 za workstation, če si pa bil intel fan, si se pač stegnil do hedt robe, ne glede na keš
FlyingBee ::
Ja, saj so nižali cene, 1700 je že 200eur v de.
2700x tudi nižajo
2700x tudi nižajo
- spremenil: FlyingBee ()
gddr85 ::
bejž, a je že sub 200e?
sicer pa za budget workstation rabo, lepo, da cene nižajo..
- spremenil: gddr85 ()
GLede nato, da ni bistvne razlike v hitrosti je tako velika razlika v ceni nepricakovana.
AapocalypseE ::
100€ je dražji 2700/x od 1700/x
ali 2600 za 159€ ali 1600X za 139€
https://www.mindfactory.de/product_info...
mahone ::
AapocalypseE ::
Je pa res, da se Zen+ clocka višje in je tudi potem razlika med procesorji, tako da kdor misli, da med Zen in Zen+ ni neke razlike se moti.
Tudi IPC je malo višji pri Zen+ ter manjše gretje.
- spremenil: AapocalypseE ()
Treer ::
wat?![]()
Verjetno je mislil Ryzna 2600 in ne i7 2600 z ozirom da je velika večina 4k ekranov še vedno 60Hz, samo Ryzni marsikje še stabilnih 60fps ne dosežejo (minimumi vse tja do 35 v določenih naslovih). Pa čeprav so entry-level 4k displeji postali poceni, grafične, ki jih lahko izkoristijo niso in če imaš za 1080Ti ali več, imaš tudi za pošten cpu...
- spremenil: Treer ()
FlyingBee ::
Točno to, na anandtech so celo 2200g dali kot zadosten proc + čim boljša grafična, itak, čeprav ima le 8 pcie lanes, ampak tudi to ni ovira. Jaz sem dal 2600 kot sweetspot. Ker pa je fhd 144hz bolj gamerski monitor, paše zraven še kakšen Intelček. Osebno bom na 1440p 144hz vsaj 27 inch monitor šel in upam, da bo 3700x top gaming cpu, drugače bom moral razočarati večino ST in ostati na Intlu.
Predator X ::
Treer tudi ivy bride ima probleme drzat konstantnih 60fps v novejsih bfjih z amd gpujem.
Pa ne pametova kako je i5 4C se zmeraj dovolj za 60hz in kako je i5 8400 boljsa zadeva kot ryzen. r5 1600/2600 + ddr4 3200cl16 je super zadeva. Ce smo realni r5 2600 4GHz vs i7 8700 4ghz oba z 3200ddr4 bo samo ~5% razlike
eto vam 60hz
eto vam 60hz
- spremenilo: Predator X ()
AapocalypseE ::
Odvisno od igre. Meni je v Dishonored 2 padlo tudi na 45fps zaradi procesorja. Sicer samo, ko sem hodil veni pa še to v parih misijah. 4/4 pač premalo.
Battlefield 1 je delal BP, ampak nisem probal MP.
FlyingBee ::
O tem se gre, mnogi se skeširajo za procesorje, ki v večini primerov ne delajo razlik, ampak se pa izkažejo v določenih primerih. Tako je bilo in vedno bo, ne glede na trole, ki bi vedno le prišparali pri komponentah. Itak, da je treba biti racionalen, recimo z 1000eur budgeta za gaming pc in fhd monitorjem, ne greš v top klaso ne z gpu ne s cpu.
AapocalypseE ::
1000€ za gaming pc z ekranom vred je premalo, če hočeš igrat vse na max. fhd
1000€ pričakujem jaz drugo leto za procesor, matično, rame in cpu hlajenje.
Ne vzamem pa manj kot 8/16 procesorja.
klinker ::
Torej bos mogu vzet rdec tabor, ker modrega za jurja ne bos dobil, ce hoces vec kot 8GB rama in plosco, ki folga tak Intelov CPU
AapocalypseE ::
Če čakam na 7nm Ryzen, je še dobro počakat na 10nm Intel. Edini problem je, ker ne vemo kdaj to bo
FlyingBee ::
Če poenostavim, ne se zdaj na cene preveč obesit, 2x8gb rami 160eur, matična 200eur, cpu cooler closedloop 120eur je vse skupaj 480eur, do jurja še 520 eur. Proc torej tisti, ki bo hitrejši v igrah, dvomim da bo rdeči tabor.
Ker se ozira na Intelove cene matičnih.
Pa še posebej cooler. LOL.
- spremenil: D3m ()
Gr8t ::
zakaj bi dal za matčno 200EUR? kaj fali tisti za 80?
Jaz ko sem kupoval januarja 2011, sem si naredil v Excelu seznam vseh funkcij pri ene par ASUS ploščah različnega cenovnega ranga in potem primerjal. Na koncu sem vzel P8P67 PRO, 2008 pa P5Q Deluxe.
Za slednjo ne vem več vseh razlogov, vem pa da je bil glavni število faz, imela jih je kar 16, prejšnja P5Q PRO pa samo 8. Ker takrat sem bil še aktiven na XtremeSystems in sem tudi naštudiral plato in proc v nulo.
Kar rabim še danes (s tem hočem povedat da kupujte za 5-8 let vnaprej, nikoli ne veš koliko časa jo boš imel) pri P8P67 PRO je pa:
-2x SATA 6Gb/s - ravno sedaj sem kupil še drugi SSD, ker so 500GB res poceni. Ampak 2x 6Gb/s ima že navadna P8P67, pa obe imata še Marvell kontroler s še dvema priključkoma, ampak ta ni neki hiter.
-USB3 ima zadaj 2, spredaj ima pa za 2, ampak imam na ohišju samo enega. Ampak tolk so imele verjetno tudi plate za 80-100EUR.
To je pa v glavnem to, saj s to generacijo je bil največji preskok kar se tiče vodil, danes ima verjetno že vsaka plošča 2x toliko teh priključkov. PRO sem verjetno spet kupil bolj zaradi navijanja, moram pogledati doma v ta Excel.
Je pa potem še SLI, ampak to danes ni več aktualno.
- spremenilo: Gr8t ()
Fanta, nista prebrala o čem se gre.
Sem opazil, da si dal prehude cene. Ampak malo se moramo pošaliti na tvoj račun.
FlyingBee ::
Nismo mi ti.
Torej bos mogu vzet rdec tabor, ker modrega za jurja ne bos dobil, ce hoces vec kot 8GB rama in plosco, ki folga tak Intelov CPU![]()
Niti ne.
Kaj ne? A pride pocenitev?
- spremenil: D3m ()
| » | Nakup CPUja 2019 (strani: 1 2 3 )Oddelek: Kaj kupiti | 24607 (20245) | Predator X |
| » | Intel predstavil 9. generacijo Core procesorjev (strani: 1 2 )Oddelek: Novice / Procesorji | 26970 (23387) | MrStein |
