Kolesarske dirke - Giro, Tour, Vuelta+
rokp ::
Cakte, da pridejo na Vinkotov teren... :)
Yossarian ::
Gambino je izjavil:
Jaz pravim, da TdF-ja še zdaleč ni konec. Vinko se pripravlja na hud boj na alpskih dveh etapah, kjer lahko komot pridobi več kot 3. minute. Mogoče se bere utopično, a mislim, da se je oz se pripravljajo na ti dve hudi etapi v alpah!
Pa tudi zadnji kronometer je pisan za Vinkota!
Ljubi bog, kako si pa ti mimo vsekal. Imaš pa v nečem prav: Vinko se res pripravlja na hud boj, samo ne s Tadejem, ampak z Remcom.
nokken ::
Kalavala je izjavil:
s/ Vinko bo jutri in na kronotu nabil dopingiranega Pogija za 10 minut /s
Wcpapir alias Gambino
Heheh sicer mislim da je bil po pisanju nekaterih tu to plan ze za danes pa se nekako ni islo. Tisti trol na twitterju, ki je tako popularen da se ga ze po medijih citira kot vir :| je pa vceraj napisal tole:
Tomorrow you will watch a show of power as the GOAT toy with the soon-to-be ex-two-time TDF winner, it will be such a mind-bender that Vini will think back to his old job, packing fish at Glynore market
Pa po koncu etape je izgledalo da je bil precej blizu.
https://lanternerouge.com/2024/07/19/se...
Pogačar on Isola 2000 averaged 6.83 ?W/Kg for 37:44 min and 7.21 ?W/Kg normalized for sea level. Despite it being at a high altitude, Pogačar's raw ?W/Kg numbers still are incredible, and he did the second-greatest climbing performance of all time, losing only to his Stage 15 performance on Plateau de Beille.
Na Isolo 2000 je bil vzpon samo še leta 1993, Rominger je odšprintal Induraina 41 minut sta potrebovala.
Indurain's Pinarello Banesto was a 59cm frame and even in race trim, it rolled to the front of the peloton at a substantial 10.2kg.
Malo zgodovine od koles:
1994 was the last time the Tour was won a steel bike--a TIG-welded Pinarello-badged beauty ridden by Miguel Indurain.
Indurain and Bjarne Riis rode TIG-welded metal-matrix frames to victory in 1995 and 1996, respectively.
Verjetno se spomnite tega prizora ko je Riis vrgel epsko kolo za kronometer
1997
Aluminum bicycles were ridden to glory by Jan Ullrich and Marco Pantani in 1997 and 1998, respectively.
Ever since Lance Armstrong lead the Tour on a stock Trek OCLV in 1999, every winning bike has been made completely out of carbon fiber except for Oscar Pereiro's Pinarello Dogma, which had main tubes made out of an AK61 magnesium alloy and rear triangle made out of carbon fiber.
https://felixwong.com/2010/11/tour-de-f...
  • spremenilo: redtech ()
Veliki_Blek ::
https://www.24ur.com/sport/kolesarstvo/...
Šef Pogačarjeve ekipe UAE: Tadeju ne bom dovolil nastopiti na Vuelti
Škoda, da Tadeja ne bo na Vuelto. Mislim, da bi zmagal lažje kot je na Giru. Poleg tega bi se pa vpisal v zgodovino.
Twixz ::
Jah, da ga ne bi dobili potem kot Pantanija... Logično..... ;)
Veliki_Blek je izjavil:
Eh, če bo res hotel, mu bodo težko to prepovedali. En pogovor s šejkom in si bo šef ekipe takoj premislil.>:D
Samael ::
Pravijo, da tovrstni napor pusti prevelike posledice na človeku in da bi to gotovo skrajšalo njegovo kariero. Angleži imajo za to boljši izraz "running to ground" človeka, kjer prevelike zahteve delodajalca ženejo osebo na rob zmogljivosti.
Saj nam, ko gledamo Pogačarja takole, kako dominira, se nam zdi še ena tritedenska dirka takole peace-of-cake, ampak jaz čisto verjamem, da se to nabira v telesu in pušča posledice.
Glejmo Kussa, lani je odpeljal vse tri WorldToure, letos pa povsem poniknil. S tem, da Tadej kolesari še na neprimeljivo višji ravni. Pa teh primerov je še kup. Poglejmo Dumoulina, ki se je boril sam s seboj in klonil. Pa Saganove mentalne in emocionalne borbe zaradi vseh pritiskov, pričakovanj, itd..
Trojna zmaga bi bilo nekaj posebnega, ampak tu lahko samo prikimamo šefom, da ne klonijo pohlepu in znajo rečti ne... sicer pa saj najbrž tudi nihče ni dobil v istem letu Giro, Tour in Olimpijske.
Samael != Samuel
  • spremenilo: Samael ()
val46 ::
Giro, tour in olimpijske Pogija bolj malo zanima...ga pa prekleto zanima giro, tour in svetovno prvenstvo ter mavrična majica. Je to povedal že zdavnaj in letos mu je trasa v Švici pisana na kožo. Se pa seveda ne bi branil tudi olimpijske medalje, to vsekakor, ampak glede na samo traso, dvomim da mu lahko uspe. Sam spet, po drugi strani, če se nekaj odloči...sej vemo kako tekmovalen zna bit.
nokken ::
Olimpijske so v kolesarstvu precej nepomembe (se od prej ko profiji olimpijskih niso (smeli) voziti), ce ze je pravi tripple crown Giro, Tour in svetovno, tudi Vuelta zares ni v tem rangu in bi bila precej manj kot "pravi" tripple crown. To imajo do sedaj samo Merckx, Roche in van Vleuten.
val46 ::
Pa imajo v istem letu nokken? tega nism šel preverjat...
nokken ::
Yup v istem letu. Merckx 1974, Roche 1987, van Vleuten 2022.
  • spremenilo: nokken ()
Samael ::
Zdi se, da je avstrijsko-nemško moštvo zdaj prehitel kar direktor dirke po Španiji Javier Guillen, ki je na novinarski konferenci v Vitorii predstavljal 18. etapo letošnje Vuelte. Zatrdil je, da se bodo dirke udeležili Roglič, lanski zmagovalec Sepp Kuss (Visma-Lease a bike) in Mikel Landa (INEOS), medtem ko čakajo še na odločitev Juana Ayusa (UAE Emirates), poročajo številni španski mediji.
https://sportklub.n1info.si/kolesarstvo...
Samael != Samuel
nejc_nejc ::
Ali imajo predpisana max in min razmerja zobnikov ali je prosta jaga?
Če Vinko danes ne bo raztural, bo pa Pogačarja zmazal za šalo v ponedeljek...
Bo treba pocakati na naslednjo leto. Vec kot ocitno postaja dejstvo, da sta si samo en drugemu konkurenca ko sta 100% zdrava, ostali ne pridejo blizu.
Kalavala ::
Ribič ni nobena konkurenca Pogiju. Naj gre vozit še kaj drugega, ne le praktično samo tdf.
Kdo pa je? Sam sebi?
Badwolff ::
Rogla :D
nokken ::
Realno... ja izkljucno sam sebi. Vingegaard je kljub "poskodbi" bil bolje pripravljen kot lani (brez vseh poskodb in problemov), vrtel boljse cifre kot kadarkoli prej in koncal zaenkrat 5min zadaj.
no comment ::
Pogačar je pa lani na Touru vrtel boljše številke kot kadarkoli pred tem (kljub "poškodbi"). In končal 7 minut zadaj.
Oba sta v zadnjih dveh Tourih imela neoptimalne priprave. Upajmo, da drugo leto ugotovimo, da je Pogačar boljši, če sta oba na 100%.
nokken ::
S tem da je tistih 7min nabral v eni sami etapi, razlogov je pa par in noben ni "problemi pri pripravah na dirko". Tako da ni cisto enako. Ceprav je bi zaostanek se vecji, je bil 19 dni povsem konkurencen ali celo boljsi, medtem ko je bil Vingegaard letos (do danes, ker kar se mene tice se vedno ni konec dirke) razen ene etape, vedno v precej podrejenem polozaju.
buttcrack ::
vedno pa dobil je etapo vs pog :D :D :D
Ne govorijo zastonj, da daje ven frustracije zadnjih 2 let :)
Zimonem ::
Samael je izjavil:
Kup totalnih neumnosti ... Landa ni Ineos, Ayuso je v nemilosti pri uae,...
  • spremenilo: Zimonem ()
https://www.srf.ch/sport/mehr-sport/rad...
"Der Gebrauch von Kohlenmonoxid-Technik ist ein neuer Trend im Profi-Radsport - und ein grosses Thema an der Tour de France."
nokken ::
IL_DIAVOLO je izjavil:
Precej bolj verjetno je vecina vas daje ven vse frustracije, ki se jih nabrali v vasem faliranem zivljenju. ;)
In ja, zmag se ne podarja, sploh ne nekomu X katerega komaj poznas in ki je za povrh se v ekipi najvecjega tekmeca. Pro sport pac ni romantika izpred 100 let pac pa to kar se imenuje... pro. Sluzba, business, denar, ce ti ni jasno. In ce lahko zraven se malo zatolces najvecjega nasprotnika, da si zagotovis mentalno prednost za naslednje dirke/leta, je zgolj plus. Ampak psiholog Il Diavolo ze ve kako je v pri cem, ceprav bi bilo mogoce boljse ce bi vse te strasne "analize" uporabil najprej da postimas svojo glavo.
Telbanc je izjavil:
Neuer trend? :)) Ja za nekega bebavega novinarcka, ki je to odkril 3 dni nazaj. Te stvari so zunaj ze 15+ let ;)
nokken je izjavil:
Uauu, še en, ki se je rodil pameten.;(( Ti so to sigurno poznal, še preden so sploh začeli uporabljati, ne?
Po tvojem je torej tudi Hvastija en neveden bebček, ki nima pojma o kolesarstvu?
Marsikoga je presenetila novica o uporabi ogljikovega monoksida, ki naj bi ga nekateri kolesarji uporabljali, da bi izboljšali svoje dosežke, čeprav je ta za organizem izjemno nevaren. Ta tema je Hvastijo presenetila, kar razlaga z naslednjimi besedami: "Ob koncu dirke se vedno pojavljajo 'čudna' vprašanja, to velja za zadnjih 50 let, letos so potegnili ta ogljikov monoksid. Priznam, tudi sam nikoli prej še nisem slišal za to napravo. Kot sem slišal in prebral, gre za dve metodi, ena je diagnostična, torej gre za neko ugotavljanje stanja ali pa učinka treninga na višinskih pripravah in se to uporablja zgolj občasno, druga pa je ta metoda, kjer naj bi se to uporabljalo za doseganje nekih drugih učinkov. Glede na nevarnost in strupenost te druge metode, torej dolgotrajnega vdihavanja hudega strupa, vsi trdijo, da tega ne uporabljajo."
otago ::
Govorice: Remco v Bora Red Bull. Remco se je v letosnjem TdF dokazal kot dizel mašina, precej zanesljivejši od Rogliča, brez padca/izgube časa v tretjem tednu GT.. Vprasanje kaj to pomeni za Rogliča. Šansa za Giro in/ali Vuelto, pomocnik za TdF v 2025/2026?
  • spremenilo: otago ()
nokken ::
Ne bos verjel ampak ne nisem poznal preden so zaceli uporabljati, sem pa slisal za to kot sem rekel 15 ali vec let nazaj. In kot sem ze napisal prej, testirali so to vsaj 20 let nazaj in rezultati (vsaj kar se hemoglobina tice) so bili precej dobri, potem pa je stvar nekako zamrla, ker ima par drugih minusov (zniza vo2max itd.). Ali se sedaj v kolesarstvu res uporablja za kaj drugega kot za teste pa ne vem, pri drugih sportih, kjer so to uporabo testirali desetletja nazaj, pa tega se vedni ni (vec) v uporabi... vsaj ne za kaj drugega kot testiranje.
Kaj Hvastja ve ali ne ve, ne vem, ker ga nisem srecal ze vsaj 10 let, ampak ce pravi da tega v zivljenju se ni slisal, potem kot kaze vseeno prav veliko ne ve o dogajanju v sportu v zadnjih nekaj desetletjih.
GupeM ::
S Pogijem je konec. Vinge ga je vlekel v klanec, on se je samo šlepal. Na koncu ga je pa še zajebal. Namesto, da bi mu pustil zmago, ker ga je tako dobro vlekel v klanec ...
Jutri Vinge preobrne tour.
Anney ::
To je to za letos, škoda Primoža, bravo Tadej.
S kakšno lahkoto je spet vrtel pedala na koncu. In pognal takoj, ko je želel. Življenjska forma.
Zakaj je Pogi edini ki vozi v dovolj nizki brzini da vecino dirke odpelje v sedečem polozaju?
Groot ::
Zato ker je v dobri formi lažje vrteti visoke obrate, medtem ko v trenutku ko te že zmanjkuje lahko vrtiš le na moč (torej višja prestava in manj obratov).
Veliki_Blek ::
Pogačar je defenzivno vozil celo etapo in vseeno zmagal.
nokken ::
Ganon je izjavil:
Na prvi pogled je res izgledalo lahko, pa ni bilo. Poglej kje je sedel ko je zgledalo lahko in kako sedi na kolesu ko je zares lahko. Ko sedi na sprednji polovici sedeza ves da je vse prej lahko ne glede na to kaksno mimiko obraza ima.
Veliki_Blek ::
Dnanes so Rogličevi navijači spet nesrečni. Na MMC pišejo, da bi moral danes Pogačar prepustiti zmago Vingegaardu.
Samael ::
A nismo tako ali drugače vsi Rogličevi navijači? :) No razen @wcpapirja/Gambina.
Samael != Samuel
blink ::
Casovnica top 10 GC na nedeljskem kronometru Monaco-Nica:
131 18:25:00 64 SANTIAGO BUITRAGO BAHRAIN VICTORIOUS
132 18:27:00 41 GIULIO CICCONE LIDL-TREK
133 18:29:00 135 DEREK GEE ISRAEL - PREMIER TECH
134 18:31:00 3 MATTEO JORGENSON TEAM VISMA | LEASE A BIKE
135 18:33:00 31 CARLOS RODRIGUEZ INEOS GRENADIERS
136 18:35:00 18 ADAM YATES UAE TEAM EMIRATES
137 18:37:00 74 MIKEL LANDA SOUDAL QUICK-STEP
138 18:39:00 12 JOAO ALMEIDA UAE TEAM EMIRATES
139 18:41:00 71 REMCO EVENEPOEL SOUDAL QUICK-STEP
140 18:43:00 1 JONAS VINGEGAARD TEAM VISMA | LEASE A BIKE
141 18:45:00 11 TADEJ POGACAR UAE TEAM EMIRATES
  • spremenilo: blink ()
Ja no, kolkokrat je to naredu Vingo, ki se doskrat šlepa? :))
Vi res nimate pojma. Prepuščat zmago tekmecu pomeni ultimativno ponižanje tekmeca. Češ, ne moreš me premagat razen če ti pustim.
Zmage se prepušča pomočnikom ali pa komu nenevarnemu iz druge ekipe, ki ti je pomagal prit do cilja, pridobit prednost proti tekmecu. Pogačar, ki sam napade 5, 10, 30 km pred ciljem, nima komu kaj prepuščat. Nihče mu ne pomaga. Razen njegova ekipa do tam, za kar jih pa nagradi tako da zmaga - s tem dobi bonus cela ekipa.
Yossarian ::
Utk je izjavil:
Točno tako.
Veliki_Blek ::
Utk je izjavil:
Se strinjam s tem kar si napisal, ampak dopovej to Rogličevim navijačem v Sloveniji, ki sovražijo Pogačarja. Sicer pa, če bi Pogačar danes res prepustil zmago Vingegaardu, Rogličevi navijači temu ne bi ploskali, ampak bi obrnili ploščo in bi pisali, kako je Jonas deklasiral Pogačarja.
Zimonem ::
UAE je carapazu naštimal pikčasto majico, pa se je vmešaa viška z jorgensonom. Nakar je še lotto soudal probal napast vinegarja. Ne koncu so kasirali s pobegom vred vsi.
RTV komentarji pa razkrivajo veliko duševnih stisk pa ne samo pod kolesarskimi temami
Utk je izjavil:
Kaj si spet prisel po malo boosterja, da ti forum ploska?
Anney ::
Letos je Pogi odpeljal vrhunski Tour. Ne glede na Giro (tu ni blo konkurence). Upam samo, da nebo izgovorov na poškodbe tekmecev (videti ni), Jonas se je boril, prav tako Remco, vendar ne dosti, jih je deklasiral. Še enkrat škoda za Primoža, vendar to je le šport, kjer zmaga najboljši. Bravo tamauPogi. Še jutri.
blink ::
1. Kaj se pogovarjajo komentatorji na RTV forumu ni pomembno
2. Osebne frustracije in vase psihiatricne tezave ni potrebno zapisovati sem
3. Egotripastvo ne prinese nobene dodane vrednosti k debati
4. Vingegaard je enako pomemben clen kot Pogacar, brez njega bi bil Tour dolgocasen
5. Nic ni narobe ce nekdo navija za Vingegarda ali Pogacarja, sport je razvedrilo, za tekmovalce in ekipe pa biznis
6. Navijanje za enega ali drugega vam ne daje ekskluzivnih pravic za bahanje. Za zmago enega ali drugega niste naredili popolnoma nic
Hvala za pozornost, gremo nazaj na debato: Kolesarske dirke - Giro, Tour, Vuelta+
Če Pogačar letos ne bo šel na Vuelto, mu bo verjetno že čez par let hudo žal, da ni vsaj poskusil biti prvi, ki bi v istem letu dobil vse tri.
Samael ::
Ko bo vse narejeno in storjeno močno dvomim, da bo sploh razmišljal o tem. Prej smo mi tisti, ki z neke razdalje v udobju po TV opazujemo in razmišljamo o teh rečeh. Človek ni stroj... Pa toliko tega je še pred njim. Za vogalom so že olimpijske in svetovno prvenstvo.
Samael != Samuel
83 / 114
