Forum » Loža » Revolut
Revolut
JN ::
Poskusil sem registrirat Business account za d.o.o.:
Hello XXX, Sara here from Business on-boarding team looking at your application with Revolut for Business. Having carefully considered your application, we regret to inform you that we are unable to offer you an account at the present time and your application has been declined. Various factors have been taken into consideration in arriving at this decision and unfortunately, certain aspects of your application do not conform to Revolut's policies at this time. Therefore, it has been abandoned. Please accept our sincere apologies that we are unable to provide any further information. Regrettably, there is no appeals pathway available in this instance. Thank you for your interest in Revolut for Business but regrettably we are unable to assist you on this occasion.
Odgovoril sem:
That's quite unfortunate especially since I have a really good experience with your metal account and was looking forward to use your business account.
Decent thing would be to at least say WHICH aspects. But it seems decency is not part of your business plan.
Če komu rata naj prosim javi, ker me zanima, če SLO firme po defaultu zavračajo... (ker res ni v našem d.o.o. nič, kar bi lahko bilo sporno, ne po kmečki logiki, ne po njihovih objavljenih kriterijih.)
Odgovoril sem:
kokica2000 ::
Če malo špekuliram, bi rekel, da uporabljajo nekega mednarodnega ponudnika bonitetnih informacij (npr. CRIF ali Coface), ki jim bonitetne ocene včasih zelo strižejo napram domačim bonitetnim (npr. Bisnode ali Ajpes). Vsaj take so moje izkušnje.
MTm2H37rqt7B ::
Se oproščam ker ni relevantno vendar,
za s.p. sem odprl Business account. Med kreacijo imaš izbiro tipa računa Business ali Freelancer. Izbral sem biznis, v spisku izbral svoj s.p., na naslednjem koraku pa me je zavrnilo, češ da ta tip organizacije (s.p.) ni primeren za Business tip Business accounta in naj izberem Freelancer. To sem naredil in imam zdaj Business/Freelancer account.
Po pogovoru z supportom je Freelancer business account primeren za self-employed ljudi.
- spremenilo: MTm2H37rqt7B ()
jabe ::
SmeskoSnezak je izjavil:
Slisala sem od kolega, da ima vsaj en HOTovec tezavo pri registraciji novega racuna. Ve kdo kaj vec?
Smeska
Jaz na Hotu (saj misliš mobilnega operaterja?) in brez problema odprla osebni in poslovni račun pri revolutu. Težave je drugje...
Vaseer ::
Če na Revolut-u zamenjam € v $ in potem opravim spletni nakup v $, mi bo avtomatsko pobralo $ ali moram kaj označiti/nastaviti?
Npr da si v naprej zamenjam nekaj € v $, da imam za spletne nakupe za vikend, ko ima Revolut nekaj višjo tarifo.
Oz. drug primer: menjam € v HRK in za vikend dvignem HRK. Mi bo avtomatsko odštelo zamenjane HRK z računa in ne bo izvajalo konverzije € > HRK (ob predpostavki, da dvignem manj, kot pa imam HRK na računu)?
bastadu ::
Če imaš dovolj $$ potem ti bo avtomatsko porabilo $$, če imaš za cent premalo $$, ti bo plačalo celotem znesek iz €€ računa...
SmeskoSnezak ::
Smeska
Gre se za operaterja in cifre, ki se zacnejo z 069 .
@ Pusti soncu v srce... @
Killermode ::
Smeska
Če je "nova" cifra je možno, da je nekdo s to isto številko že odprl revolut račun
kokica2000 ::
@SmeskoSnezak Dobro bi bilo, če bi izvedeli kaj več, kakšne točno težave so bile pri registraciji. Potem bi lahko kaj več pomagali.
dimko_rk ::
MTm2H37rqt7B je izjavil:
.. To sem naredil in imam zdaj Business/Freelancer account.Za vse, ki imate Revolut Business: na izpiskih verjetno ni IBAN-a posiljatelja (ob prejetem nakazilu) niti prejemnika (ko sam nakazes nekomu)? Mislim, da namen nakazila na izpiskih prav tako ni naveden? Vsaj pri osebnih racunih tega nekako ni; ko sem klikal po Business demo je izgledalo enako. Vas to ne moti oz ne omejuje uporabnosti racuna za poslovne namene? Osebno se mi je to zdel no-go zaenkrat. Morda se pa motim oziroma se je vmes kaj spremenilo glede izpiskov?
jabe ::
ne ni. na izpiskih ne, lahko pa za vsako transakcijo posebej to pogledaš. Mene to ne moti, ne rabim.
SmeskoSnezak ::
kokica2000 je izjavil:
Ok, sem vprasala ce ve kolega kaj vec... in pravi da se ne dobi aktivacijski SMS s sestmestno kodo.
Smeska
ali komplet: 38669...
kokica2000 ::
Ah, sej ne gre drugače. V prvem polju izbereš državo (v večini primerov je že predizbrana 386), v drugo pa vpišeš številko (z ali brez nule, je čisto vseeno). @SmeskoSnezak, kolega naj še enkrat preveri, ali vpisuje pravilno (svojo) številko, potem pa predlagam, da kontaktira podporo v aplikaciji (klepet naj bi bil na voljo, tudi če še nisi registriran, sicer pa naj piše na feedback@revolut.com).
brez-imenko ::
Nisem nekaj zelo domač v teh virtualnih bankah tudi prebrat mi ni uspelo vsega. Mi lahko nekdo priporoča katero mobilno banko izbrati Revolut ali N26 oz. kaj tretjega. Rad bi se preselil kam drugam, ker so me pojezile še zadnje neumnosti pri zdajšnji banki. V prvi vrsti bi si želel dostop preko računalnika in ne toliko preko telefona, drugo pa čim manj stroškov z njo.
www.podarimo.si pa lep pozdrav vsem, Janez
weasel ::
Ce si zelis enostavno (brez nekih emulatorjev) dostopati preko racunalnika, Revolut avtomatsko odpade, ker nimajo aplikacije za PC (niti web app-a).
BuDi79 ::
brez-imenko je izjavil:
V prvi vrsti bi si želel dostop preko računalnika in ne toliko preko telefona, drugo pa čim manj stroškov z njo.N26 vsako transakcijo verificira prek telefona. Mislim da tudi na našem področju manj razširjene brezplačne tuje banke kot je Ferratum ne podpirajo "samo računalnika".
OvCa77 ::
Revolut spet ponuja za Slovenijo MasterCard tako fizično kot virtualno.
Laptop: Probook 440 G3 | i5-6200U | 12GB DDR3L | SSD Plus 240GB
Desktop: Ryzen 1600X | Gigabyte AX370 K3 | 8GB DDR4 | MX100 256GB
OvCa77 ::
Je smisleno na revolutu imeti obe kartici Visa in Mastercard?
Če da, zakaj?
Če potuješ po svetu je smiselno imeti obe, ker pokritost se glede na državo spreminja. Nekje na avtomatih računajo provizijo samo za Viso, za MC pa ne.
Maximus ::
BuDi79 ::
Vaseer ::
Revolut spet ponuja za Slovenijo MasterCard tako fizično kot virtualno.Da ne bo zmede - samo MasterCard, Vise ni moč izbrati.
Če že imam Revolut Viso, lahko naročim še MasterCard in uporabljam obe?
Kaj pa po preteku veljavnosti, mi menjajo obe ali samo eno?
Je menjava kartice (po poteku veljavnosti) plačljiva?
BuDi79 ::
Če že imam Revolut Viso, lahko naročim še MasterCard in uporabljam obe?Lahko, proti plačilu. Ne vem koliko je.
Kaj pa po preteku veljavnosti, mi menjajo obe ali samo eno?Sami nič ne menjajo, sam daš zahtevo ("Replace expired card" ali nekaj takega, opcija se ti pojavi 28 dni pred potekom)
Je menjava kartice (po poteku veljavnosti) plačljiva?Menjava osnovne je brezplačna, nadalnjih ne vem.
OvCa77 ::
Vsaka dodatna kartica je 6€
brez-imenko ::
Se da pri Revolutu zbirat kartice? Potem takem imam raje Viso.
BuDi79 ::
Se da pri Revolutu zbirat kartice? Potem takem imam raje Viso.V sloveniji se ne da, tako da te nihče ne vpraša kaj imaš raje.
OrkAA ::
jabe ::
Polen pa visa. Ker virtualna je lahko samo mastercard, kolikor vem. In potem imaš obe, slednja pa je komot u UK binom in dela z Google payom.
OrkAA ::
Imam virtualno viso :) In ne, kolega je pred kratkim poskusal ustvarit novo virtualno in jo povezat z google pay pa ni slo, ker ni imela UK bina.
- spremenil: OrkAA ()
jabe ::
Je treba naslov najprej spremeniti. Na enega angleškega, da ima potem angleški Bin. 3 mesece nazaj je to delalo še ko urica. Virtualne Vise ne ponudi. Lahko pa naredim še en mastercard. Imam pa fizično viso.
skyline ::
Imam fizično Revolut Viso, BIN pokaže da je UK kartica. Ampak Spotify Premium naročilo še vedno ne gre skoz.
Kje je catch? :)
Kje je catch? :)
WaterBoy ::
Pozdravljeni
30. Avgusta sem opravil dva nakupa v trgovini z revolut kartico in od akrat mi piše pri teh nakupih: ''Pending. Will be reverted if unclamed by Merchant within 7 days.''
Kaj naj bi to pomenilo.
Hvala
Hvala
andro23 ::
sem si naredil navidezno Mastercard in mi GPay še vedno ne dela...kdo ve ali bi delalo, če naročim fizično mastercard kartico?
BuDi79 ::
WaterBoy ::
Ja, saj to je problem, ne razumem kaj to pomeni :)
Torej trgovec še ni potrdil transakcije in če je ne naredi v 7 dneh potem ne bom plačal? Denarja še niso trgali.
Potem bom v prekršku, saj sem zadeve ukradel?
kokica2000 ::
Kakšnem prekršku? Zadeva je plačana, sredstva rezervirana. Trgovec ima 7 dni časa, da sredstva prenese na svoj račun. Ti si opravil svoje.
BuDi79 ::
Trgovec ima 7 dni časa.Sicer je v praksi 7 dni bullshit, čeprav je to v pravilih kartičnega poslovanja po nevemkakšni logiki "velikim" pustijo da denar vzamejo tudi pozneje (denar se ti vrne na račun po sedmih dneh - ker ga nihče ni prevzel, po tem pa ponovno izgine kakšen dan pozneje ker je trgovec transakcijo vseeno potrdil)... se je zgodilo pri Mercatorju in Petrolu.
metalc ::
PreviousUser je izjavil:
Kaj tako mečkajo s temi ETF-ji? Je res tako zahtevno to vpeljati ali kaj?
Medtem ko mečkajo, se dobro pozanimaj, za kaj pri vsej stvari sploh gre: za prave vrednostne papirje ali kakšne CFDje. Če že ne zaradi drugega zato, da boš FURSu lahko pravilno in na pravem obrazcu poročal o kapitalskih dobičkih.
stara mama ::
Že celo po dveh mesecih iz tujine so mi vzeli. Ampak noben do zdaj še ni pozabil vzet svojega denarja :)
Ekologija™ in Trajnost™
kokica2000 ::
Nikakor ne samo na navedenih BINih (Nemčija, VB), pač pa na vseh BINih vseh s strani Google-a in Revoluta podprtih držav. https://www.revolut.com/help/exploring-...
Dzhimen ::
Samo hitro vprašanje... A je potrebno Revolut račun prijavit na FURS?
Imam čisto osnovni račun. Ko grem pod moj "Račun Evro", mi tako na zavihku "Lokalna" kot na zavihku "SWIFT" navede iste podatke. In sicer
IBAN: GB13 REVO 0099 ...
BIC: REVOGB21
Ali prav razumem, da to dejansko ni moj personalizirani TRR in da mi tega ni potrebno prijavit? Sem brskal, ampak nikjer ne dobim jasne informacije...
BIC: REVOGB21
49106 ::
A sploh veš, kdaj je potrebno račun prijaviti, al nisi našel niti te informacije?
Izpustil si ključen podatek.
Slabo si brskal.
https://slo-tech.com/forum/t713835/p601...
- spremenilo: 49106 ()
» | Curve - več kartic v eni (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Loža | 133294 (7328) | buttcrack |
» | Binance VISA debetna kartica (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Kriptovalute in blockchain | 131694 (6458) | _janezvalva_ |
» | mBills v praksi (strani: 1 2 3 4 … 10 11 12 13 )Oddelek: Loža | 120414 (9719) | Karen |
» | Najugodnejša predplačniška MasterCard (strani: 1 2 3 4 5 6 )Oddelek: Loža | 109196 (37117) | Andro457 |
