[VB.net] object v dataset column
korenje3 ::
A kdo ve zakaj se ne da shranit dataset v datoteko, če je v dataset column z objektom?
Zadeva se pa obnaša tako, da prvič lahko shranim. Potem ko naredim load v dataset in ko probam ponovno shranit mi napiše to napako... V čem je fora?
    Public Sub Loaddataset(file As String)
        If IO.File.Exists(file) Then
            Dim fs As New Compression.GZipStream(New FileStream(file, FileMode.Open), Compression.CompressionMode.Decompress)
            Dim bf As BinaryFormatter = New BinaryFormatter()
            DataSet1 = CType(bf.Deserialize(fs), Data.DataSet)
            fs.Close()
        End If
    End Sub
    Public Sub Savedataset(file As String)
        If IO.File.Exists(file) = True Then
            IO.File.Delete(file)
        End If
        Dim fs As New Compression.GZipStream(New FileStream(file, FileMode.Create), Compression.CompressionMode.Compress)
        bf.Serialize(fs, DataSet1)
        fs.Close()
    End Sub
korenje3 ::
Ok našel...
očitno je potrebno še enkrat napisat tole v savedataset subrutini:
DataSet1.RemotingFormat = Data.SerializationFormat.Binary
ne vem zakaj se samodejno prestavlja na xml...
Visual Basic
Oddelek: Programiranje
314284 (3310) cekr
[C#] WebResponse vrne error 404
51329 (1290) darkolord
[visual basic 05] - kreiranje datoteke in pisanje vanjo
111907 (1703) gzibret
[VB2005PRO]Dll uporaba
111377 (1261) UltraTX
branje byte[] iz MS access-ove baze
82335 (2245) BHawk
