ROUTER TP-LINK TL-WR741ND v1.7 KOT REPEATER
AštiriL ::
ZAnima me, kako bi uporabil ROUTER TP-LINK TL-WR741ND v1.7 KOT REPEATER. Če ga kdo ima, naj napiše, če je to možno. poskusil sem neko funkcijo WDS(?) vendar, ko se povežem na svoj wifi ni internetnega dostopa, ki pa je na wifiju, ki ga hočem repeatat.
STARA METODA Z DVEMA TELEFONOMA VSAKIH 30m MI NE SEDE (-; !!!
IPCONFIG /ALL od mene, če sem povezan na wifi, ki ga hočem repeatat:
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3165
Physical Address. . . . . . . . . : 84-EF-18-04-9B-6A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::4b3:51bc:a2cf:165%11(Preferred)
IPv4 Address. . . . . . . . . . . : 172.16.9.97(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Lease Obtained. . . . . . . . . . : petek, 25. avgust 2017 13:35:39
Lease Expires . . . . . . . . . . : petek, 25. avgust 2017 13:58:40
Default Gateway . . . . . . . . . : 172.16.0.1
DHCP Server . . . . . . . . . . . : 172.16.0.1
DHCPv6 IAID . . . . . . . . . . . : 126152472
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-0F-7F-78-98-E7-F4-58-2E-90
DNS Servers . . . . . . . . . . . : 208.67.222.123
208.67.220.123
NetBIOS over Tcpip. . . . . . . . : Enabled
PS: IMAM GARGOYLE (NA ROUTERJU KI HOČEM, DA ODDAJA SPREJET WIFI). DO ROUTERJA, KI PA ODDAJA WIFI Z INTERNETOM PA NIMAM DOSTOPA /-:
  • spremenil: AštiriL ()
Dnsmasq problem
Oddelek: Omrežja in internet
131501 (1128) BlaY0
dnsmasq problem
122745 (2485) poweroff
Spor naslovov IP (strani: 1 2 )
6615544 (14320) turob2
Problem z internetom
473836 (3387) RuskiSnajper
Problem router/mordem
153216 (2903) gorenjc
