Squid 3 + rebuild SSL
HotBurek ::
Pozdravljeni.
Na strežnik sem namestil Squid proxy in trenutno deljue bp za http requeste. Zanima pa me, kako omogočit promet preko https. Ker je sam Squid že nameščen me zanima, kako se lotit "recompile with ssl support". Kako se naredi sam upgrade/recompile oz spremembe, da bi Squid delal tudi preko https?
Nekaj navodil kjer sem gledal postopke:
http://www.panticz.de/Squid-Compile-wit...
http://wiki.squid-cache.org/Features/Dy...
Pa še trenutna konfiguracija:
Squid Cache: Version 3.4.8
 linux
configure options:
'--build=x86_64-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include'
'--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var'
'--libexecdir=${prefix}/lib/squid3' '--srcdir=.' '--disable-maintainer-mode' '--disable-dependency-tracking'
'--disable-silent-rules' '--datadir=/usr/share/squid3' '--sysconfdir=/etc/squid3' '--mandir=/usr/share/man'
'--enable-inline' '--disable-arch-native' '--enable-async-io=8' '--enable-storeio=ufs,aufs,diskd,rock'
'--enable-removal-policies=lru,heap' '--enable-delay-pools' '--enable-cache-digests' '--enable-icap-client'
'--enable-follow-x-forwarded-for'
'--enable-auth-basic=DB,fake,getpwnam,LDAP,MSNT,MSNT-multi-domain,NCSA,NIS,PAM,POP3,RADIUS,SASL,SMB'
'--enable-auth-digest=file,LDAP' '--enable-auth-negotiate=kerberos,wrapper' '--enable-auth-ntlm=fake,smb_lm'
'--enable-external acl-helpers=file_userip,kerberos_ldap_group,LDAP_group,session,SQL_session,unix_group,wbinfo_group'
'--enable-url-rewrite-helpers=fake' '--enable-eui' '--enable-esi' '--enable-icmp' '--enable-zph-qos' '--enable-ecap'
'--disable-translation' '--with-swapdir=/var/spool/squid3' '--with-logdir=/var/log/squid3'
'--with-pidfile=/var/run/squid3.pid' '--with-filedescriptors=65536' '--with-large-files'
'--with-default-user=proxy' '--enable-build-info= linux' '--enable-linux-netfilter' 'build_alias=x86_64-linux-gnu'
'CFLAGS=-g -O2 -fPIE -fstack-protector-strong -Wformat -Werror=format-security -Wall'
'LDFLAGS=-fPIE -pie -Wl,-z,relro -Wl,-z,now' 'CPPFLAGS=-D_FORTIFY_SOURCE=2'
'CXXFLAGS=-g -O2 -fPIE -fstack-protector-strong -Wformat -Werror=format-security'
root@debian:/# iptraf-ng
Please resize your window
gcc + math.h + -lm problem
Oddelek: Programiranje
91312 (1228) BigWhale
Postfix Relay access denied
Oddelek: Programska oprema
62330 (2248) jype
GCC 4.0!
362925 (2169) 64202
Problemi s compilanjem v Linux Slackware 9.1
Oddelek: Operacijski sistemi
352382 (2101) Vesoljc
Hash table - C++
51603 (1479) noraguta
