AMD Epyc
AMD Epyc
3 / 12
AMD wins as Dell goes EPYC
Počasi se premika.
Dell EMC senior vice president, product management and marketing, server and infrastructure systems, Ravi Pendekanti said: “With AMD’s EPYC processor integrated into the new Dell EMC PowerEdge platforms, we can deliver the scalability and lower total cost of ownership needed to meet the demands of new emerging workloads. Customers are constantly looking for ways to drive growth and leverage new models of computing. AMD’s single-socket platform is a great example of Dell PowerEdge servers moving the industry forward to solve real customer problems. Together, we’re enabling customers to advance their data centre transformation by adding capacity for higher IO and memory-intensive applications for highly configurable, single- and dual-socket designs.”
  • spremenilo: FireSnake ()
Zanimive informacije z ISSCC 2018:
https://fuse.wikichip.org/news/1064/iss...
Zanimivo branje.
Hvala za posredovano.
Koristno branje: https://www.eejournal.com/article/fifty...
tl;dr: Moore's Law and Dennard Scaling are dead.
Počasi se premikajo stvari:
klik
Tole so trenutno javne informacije za naslednji dve leti:
Danes neuradno izvedel, da se Epyc2 zna zgoditi na novem socketu in PCIe v4 implementacijo ... zanimivo :)
Hudiča. PCIe4. Dobro za AMD.
4br4h4m ::
no ce ze pri grafikah in desktop cpu segmentu ne znajo prav konkurirat, imajo pa vsaj tale epic res odlicen cpu
klinker ::
4br4h4m je izjavil:
Hej, vsaj ne prodajajo zluknjanih 8700K peck za 400€.
Isotropic ::
pegasus je izjavil:
a je to letosnji refresh ali naslednje leto?
Evo, imam potrjeno: socket za Rome bo isti, do 64 corov, podpiral bo tako pcie v3 kot v4, pa še nekaj novega zraven ;)
Ne vem še kaj to pomeni za plate ...
Za referenco, memory encryption v epycih in ryzen projih potrebuje še nekaj iteracij, da bo 100% zanesljiv:
https://www.theregister.co.uk/2018/05/2...
tasotusire ::
klinker je izjavil:
AMD EPYC Secure Encrypted Virtualization Not So Secure: Researchers
the researchers were able to use rogue host-level administrator, or malware within a hypervisor, to bypass SEV and copy decrypted information from the guest machine's memory.
A mora biti vsaka AMD tema res posvečena izključno kritiziranja konkurence?
A ni bilo ne dolgo nazaj, ko so pljuvali po konkurenci v nasprotnem taboru?
pegasus je izjavil:
jobi delajo enako ali malce hitreje kot na haswellu
Še zanimivost, pure integer load iz genomike - single core epyc @ 2GHz dosega 97% zmogljivosti skylake @ 3GHz. Zato lahko v isti prostor in power budget spravi več kot 2x več jeder.
Koliko je pa base clock pri Epycu?
Danes sem izvedel cel kup zanimivosti... hpckp event v Barceloni je res top.
Naslednja generacija epycov bo temeljito pretresla x86 trg, na več načinov. Intel tenko piska, tekmi pa se bo pridružil še en kitajski arm igralec, ki pravtako obljublja nekaj impresivnega ter cilja primarno na vendorje komercialnega softvera. Prihodnost obeta ... :)
Kitajska domača verzija epyca se imenuje Dhyana, izdeluje pa jo Hygon. Naj se ne bi prodajala izven kitajske, a iznajdljivi kitajci vedno najdejo načine za zaobit take omejitve ;)
Ta AMDjeva poteza zna biti dolgorocno huda napaka.
Vprašanje. Trenutno jim odgovarja. Delnica bo poskočila preko 17$.
Poceni kitajska roba je tudi pasala. Posledice preselitve vecjega dela proizvodnje na Kitajsko pa bodo, brez dvoma, se bolece.
Spock83 ::
pegasus je izjavil:
Daj povej malo več.
https://semiaccurate.com/2018/08/07/int... ... Beri. Vsaj amd plat zgodbe lahko deloma potrdim, za Intel pa lahko samo upam, da res pokažejo nekaj novega v projektu A21.
Namig, kam gre amd razvoj:
https://www.phoronix.com/scan.php?page=...
XGMI is a peer-to-peer high-speed interconnect and is based on Infinity Fabric
Hudiča.
AMD je namignil, da bodo več povedali na SC18 sredi novembra. Zacahnite koledarje :)
toj še dve plači stran. :)
gendale2018 ::
glih uredu, lahko varčuješ da si ga kupiš 8-)
ja sam mali poštar, kurac mi je oštar
čuvajte se žene, bit ćete jebene
HPE switches to AMD.
Zanimivo branje.
Čeprav je vir bolj tako-tako.
Evo mal za rajcat folk:
Ne smem povedat, kaj od tega je res. Plus nekaj cvetk tu še manjka ;)
Zna pa AMD sedaj na SC18 povedati kaj več ...
Holy shit. Ali misliš, da bo AMD s tem hitreje menjal Intelov eko-sistem v enterprise segmentu?
To je njihov plan, da. Kako se bo pa enterprise segment odločil, bomo pa še videli. Verjetno odvisno od tega, koliko popusta si lahko intel privošči dajati na svoje ponudbe. Prvi poskus s popusti ni bil dovolj prepričljiv ...
Brane3 ::
Great. Zanimivo bo videt, kako dobro se obnese IF v tej varianti z 8 chipleti na osnovi, ko gredo linki skozi PCB-like substrat.
Resda v daleč bolj nadzorovanem okolju in z veliko krajšimi linki, pa vendar je potreben prehod s čipa in na čip.
V tej igri s kockicami jim verjetno ni prevelika frka zamenjat srednjo I/O kocko - čiplet, če se bodo kdaj odločili preiti na 4S sisteme...
Vse pohvale tudi za spoštovanje NDA ;)
Isotropic ::
D3m je izjavil:
a ni ravnokar na polno padla zaradi slabih quarter rezultatov?
Ok, next horizon event je sedaj mimo. Ubistvu sem pričakoval, da bodo nasuli še več soli v intlove rane, pa so se kulturno zadržali. Edino stric od craya je namignil, da je v tej Epyc Rome zgodbi še nekaj več. Me zanima, kdaj pridejo v javnost konfiguracije, ki sem jih videl poleti :)
pegasus je izjavil:
Česa niso povedali?
Ne bo povedal, ker ne sme.
Zadeva se pa res dobro razvija.
Ne spomnijam se, kdaj bi toliko novosti natrosili na eni predstavitvi.
No, glede na odziv pegasus imajo v rokavu še kaknega asa.
Dobro se je izogibal vprašanjem.
I'll just leave this here: https://globenewswire.com/news-release/...
Brane3 ::
Pozen si. Smo že pisali o tem.
Ni slabo za majhno revijo ;o)
A167
Ravno preganjam volk na Avnetu za detajle, pa se glih okrog Xilinxa (še) ne ve nič, ker se nekaj reorganizirajo.
No. bomo že zvedeli do takrat, ko val pride do Slovenije...
  • spremenilo: Brane3 ()
Brane3 ::
@Pegasus:
Nego, si kaj vidu tole na sejmu: Sugon Nebula Rack
Brus Li tole očitno dela za svoje potrebe, Tomshardware je objavil tole in počil fotko, ostalih podatkov pa ni.
Meni se pa ne da čakat na naslednji Star Trek, da lahko napišem članek o temle ;o)
V teh so že njihovi Epyci, o katerih smo pisali (Dhyana), pa nVIdia.
A očitno gre na naslednjem upgradeu not Epyc2/3/4/etc pa Vega2 not...
Gateparajoče...
V Novi Gorici imamo zastopnika za to reč. Pojdi jih vprašat, če ti kako omaro pokažejo ;)
3 / 12
Intelov direktor: nismo več niti med največjimi desetimi (strani: 1 2 )
6913466 (10281) tony1
Intel lansiral 56-jedrne Xeone in Optane DCPMM
Oddelek: Novice / Procesorji
3911776 (9420) Xserces
Pomanjkanje Intelovih procesorjev se stopnjuje (strani: 1 2 )
6628476 (24336) gendale2018
AMD dopolnil drugo generacijo procesorjev Ryzen Threadripper (strani: 1 2 )
5821968 (19804) krneki0001
Intel predstavil nove Xeone
2310452 (7274) Jst
