Luka Dončić
Luka Dončić
Samael ::
An MRI revealed J.J. Barea has a torn right Achilles tendon, according to Shams Charania of The Athletic.
The Mavs feared he tore his Achilles last night, and those fears are true with this terrible news. Barea is 34 and has dealt with a lot of lower-leg injuries, so there could be some concern he might not be able to make it back from this devastating injury. Hopefully, we'll see him back at some point next season. For the Mavs this year, it looks like Maxi Kleber and Jalen Brunson are the fantasy adds with Kleber being the hotter of the two and possessing much higher upside.
Source: Shams Charania on Twitter
Jan 12 - 2:39 PM
Nič prav dobro ne kaže...
hlače13 ::
Steve pred dvobojem proti Dallasu o našemu Luki. ZELO ZANIMIVO!
hlače13 ::
poteze proti prvakom!!
Samael ::
Nekaj hecnega :D
https://www.mavsmoneyball.com/2019/1/12...
Obstaja možnost, da bo Luka ... kapetan All Star ekipe. :))
Glasovi, ki določijo, kdo bo kapetan ekipe so glasovi navijačev, ne novinarjev in igralcev, medtem ko LeBron, ki trenutno pred Luko vodi na lestvici glasov navijačev, vsaj zaenkrat zaradi poškodbe ne igra.
  • spremenilo: Samael ()
Tilen ::
Neverjetno, kakšne je stresal Curry. Poglejte si to. :)
48 točk.
Smurf ::
Hja, sedaj so govorice, da se Rick in DSJ ne razumeta najbolje in naj bi ga zamenjali.
kixs ::
Steph je imel tako sreco, kot Harden ob istem casu, ko je od 17 metov za tri zadel le eno :lol:
  • spremenil: kixs ()
hlače13 ::
FERRARI?
drvo ::
Pa 2 meterski ded sploh paše v tak avto? Al je tisti zraven njegov.
hamez66 ::
Smurf je izjavil:
Aja? Je to razlog, da ni igral na zadnjih tekmah? Prej je imel poškodovano zapestje, vendar se je potem pozdravil..
Vazelin ::
Luka je igralec okoli katerega se gradi ekipa. Pika.:)
hamez66 ::
Na zadnji tekmi je imel Luka najslabši +/- v ekipi. Me zanima, če bi on lahko pokrival Curryja. Največ pik je Curry dosegel preko Brunsona.
http://www.espn.com/nba/boxscore?gameId...
Zanimive so te govorice glede DSJ. Komentatorji na nba tvju ga hvalijo že celo sezono za dosežke v lanski sezoni, se pa ve, da z Lukom pogosto nimata kemije. Zdej če se še krega s trenerjem, je pa to potem res slab znak in bo verjetno moral oditi. Se mi pa zdi, da bi DSJ lahko bolje pokrival Curryja, kot ga je Brunson - ker je višji in zelo hiter in močan.
  • spremenilo: hamez66 ()
Smurf ::
hamez66 je izjavil:
Smurf je izjavil:
Za tem ga je bolel hrbet, nazadnje pa je bil "bolan" :D. Najverjetneje je res kaksna povezava. Najverjetneje tudi takrat, ko je odsoliras zadnji napad (in je bil Luka presenecen) ni imel dovoljenje trenerja.
Samael ::
To je lahko dvorezno. Razumem, da želijo zamenjavo, dokler ima še neko tržno vrednost, po drugi strani pa bodo, če se Luka ali Brunson poškodujeta, še kako krvavo potrebovali PG-ja. Pri 21ih letih je, ne glede na to, kaj menijo nekateri soforumaši zgoraj, za DSJ-ja še vse odprto. Če le ne bo poškodb.
Če ne dobijo res zamenjave z neko dodatno vrednostjo za ekipo, jaz ne bi šel v to. Razen če je DSJ sam (dandanes po forumih kroži en kup teorij in mnenj) sam zahteval selitev.
Dandanes se vsem nekam mudi. Dve, tri slabše igre in ... vemo "vse". Luka in DSJ nista igrala vsega polnih pet mesecev skupaj, pa smo se že "odločili" da ne pašeta skupaj. Durant in Westbrook v OKC sta potrebovala tri leta ...
Gregor27 ::
FTad ::
Vecina prodorov, ki jih je naredil in zadel kos, je bila nad njem narejena se osebna napaka, sodniki nikoli piskali osebne.... :/
MostWanted ::
med tem harden 21 prostih!!! katastofa! in njegovih 58 točk je enakovredno kupu gnoja! met za 3 katastrofaln.
donke pa res malo jači! pa tisto zabijanje uf!
Andro457 ::
Nba žal iz leta v leto postaja bolj teater kot pa šport. Obrambo so praktično povsem izločili, zato tudi tolikšno število točk. Harden je pa eden od igralcev, ki najbolj profitira od pravil + sistem (D)Antonija. V Playoffih, ko se ponavadi igra zaostri je imel še vsako sezono probleme.
DINAMIK ::
Samael ::
Smurf je izjavil:
hamez66 je izjavil:
Smurf je izjavil:
Verjetno je ta moment tole najbolj zanesljiva novica, kar se ozadja teh govoric tiče:
https://www.mavsmoneyball.com/2019/1/17...
http://www.espn.com/nba/story/_/id/2578...
Jaz še vedno upam, da bodo zgladili in da bo ostal in igral vsaj do konca sezone.
hunter01 ::
DINAMIK je izjavil:
https://siol.net/sportal/kosarka/glasov...
https://vote.nba.com/?cid=asv18_nbadrd#/
"Samo" še 300k prednosti ima James =) Pozna se, da je poškodovan, če bi igral bi sigurno še veliko več glasov dobil.
bambam20 ::
hamez66 je izjavil:
Kakšni so ti dosežki? Edino, kar mu je v lanski sezoni uspelo je NBA All-Rookie Second Team .. Če je to dosežek potem pa ne vem kaj naj rečem. Skratka povrečen igralec, ki se bo sam posedel najprej na klop v eni od drugih ekip, nato pa bo izpadel iz lige.
Danes pa Dončić izključen, dve tehnični.;)
Ni nisem mislil, da so NBA sodniki tako, kot komarji.
hlače13 ::
hlače13 ::
1 na 1 proti vsem SUPER ZVEZDNIKOM! Ni problema!
Kurzweil ::
Danes je še zadnji dan, za glasovanje Dončiča in Dragiča. In pa mogoče se reminder, da je danes ob 20:00 po našem času tekma DALLASa v gosteh proti MILWAUKEEju, tudi s prenosom na Šport TV. Vsaj enkrat, da se bo dalo v miru pogledat eno tekmo, da drug dan ne bo trpela služba in še kaj drugega.
Groot ::
Kurzweil je izjavil:
Prenos je na Sportklubu ;)
Kurzweil ::
ups, zatipkal... itak... bo pa pravo čudo, če uspe Dallasu danes zmagat, ampak kot se za nas klasične band wagon navijače Dončiča spodobi, bomo gledali samo njegovo statistiko in morebitne možnosti za zmago, če seveda do tega slučajno pride.
FTad ::
ma kdo link za kak free stream?
Vazelin ::
koyotee ::
Ah doncic prva cetrtina zelo svoh.
Rear DVD collector!
JTD power!
perci ::
no, zdele, ko ga ni not, se vidi, da ni nobene ideje
FTad ::
Vazelin je izjavil:
https://www.reddit.com/r/nbastreams/
hvala :)
No, vsaj prvi triple double je dosegel danes :)
Reaper ::
Res je, norc pravi. Samo tako naprej :D Pa kakšno trojko je spet zadel proti koncu tekme, se je samo nasmehnil :)
Samael ::
Meni deluje kot, da ga zafrkava zdravje že od Pacersov dalje. Praktično od začetka igre je ves rdeč v obraz.
Pro_moted ::
Malo ga tudi živci izdajajo. Preveč se sekira za sodnike, na katere itak nima vpliva. Pa saj je komaj 19 let. Se bo že navadil. Se pa strinjam, da ne deluje najbolj pri močeh!
AMD FX8120;GB 990FXA-UD3
Reaper ::
Tudi ta zaporedna srečanja na nekaj dni, kjer igraš na polno te izmučijo. Ta NBA košarka je itak eno samo letanje, malo drugačna kot EU basket, kjer se mogoče malo igralec lahko pomiri, ko se postavlja akcija. Tu je pa samo pick pa gas.
firbec ::
Zelo zanimivo je spremljanje komentarjev kjerkoli glede Luka.
slab met, neverjetne trojke, lepa mama, mlad je še, fenomenalno igra, nima mišic, mladosten nasmeh, ločeni starši, leader ekipe, kaj bi bilo, če bi ostal v Olimpiji in ne bi odšel v Madrid, drugi najmlajši triple/double v zgodovini NBA, moral bi igrati v boljši ekipi, odličen stepback met, ogromno izgubljenih žog, zelo lepo vzgojen.......................................
................. skratka, vsega po malo je res, vendar vsakdo ki je kdajkoli igral vsaj malo košarke, ve, kako težko je biti med boljšimi v katerikoli prijateljski, trim ali vaški ekipi, kakorkoli hočete, kaj šele v resnem klubu v državi, ali Madridu, da ne govorim v NBA. In Luka to je, to je njegova prva sezona v NBA, pa je krepko nad povprečjem, zelo izstopa in to je za njegov razvoj super. Če bi pristal v kateri boljših ekip, kot je Dallas, bi igral veliko manj, veliko manj bi bilo pompa okoli njega in veliko manj bi napredoval, tako da je Dallas čudovita odskočna stopnička zanj, kar se NBA tiče. Nikakor ne smemo biti razočarani, ker se letos Dallas ne bo uvrstil v play off. Že če bo Luka izbran v All star ekipo, bo to nekaj neverjetnega. Že zdaj se vidi, da ima nek renome, kaj šele bo. Ni power player, niti ne more biti glede na mišično konstrukcijo bele rase, je pa neverjetno inteligentn igralec, za svojih 19 let, neverjetno inteligenten. Da mu le ne bi slava stopila v glavo in da ga bohnedaj ne doleti kakšna košarkaška poškodba.
Luka ostani, kakršen si, zapomni si, meja med tem da te ljudje občudeujemo in med tem, da pljuvamo po tebi, je na sončni strani Alp zelo majhna,.
Uživaj v tem, kar počneš najraje.
  • odbrisal: perci ()
hlače13 ::
Meizu ::
firbec je izjavil:
Kakšno mišično konstrukcijo bele rase? Med črnci in belci večinoma razen pigmentacije ni bioloških razlik, kaj šele tako velikih razlik kot je npr. mišična masa.
mlamat ::
To si slišal verjetno od kakšnega politično-korektnega SJW-ja. Potem pa nam prosim razloži zakaj je 75% igralcev črncev, če jih je v prebivalstvu samo 13%.
mlamat je izjavil:
Zato, ker ste lene pičkice, ki se vam ne da trenirat, črnci (in Luka Dončić) pa niso.
  • predlagalo izbris: MostWanted ()
Gajec ::
DOnčić, Dončić, Dončić.
Vsak dan v Delu o vsakem njegovem koraku, tudi če je čisto neizjemen.
https://www.delo.si/tag/luka-doncic
Čestitke seveda za izjemnost, ampak kaj je fora, da se toliko piše o njem? Športa se dogaja veliko, je njegov uspeh res sorazmerno s količino prispevkov o njem tako velik?
jype je izjavil:
mlamat je izjavil:
Hear hear. NOT.
  • spremenil: D3m ()
Samael ::
Gajec je izjavil:
Da, seveda.
Smurf ::
Samael je izjavil:
Gajec je izjavil:
Da, seveda.
Se strinjam. Se v Ameriki se najvec pise ravno o njem. Zna biti najboljsi slovenski sportnik vseh casov (pardon drugi, po Iztoku Copu).
Vazelin ::
Iztok Čop se je nekam potuhnil odkar je šel full retard
vahid ::
Glede na to, da je tole slo-tech in ne slo-sport, ali celo medovernet (psiholoska sekcija), se mi zdi smiselno omenit, da bi bolj pasala sem kaksna debata tega tipa:
https://www.psychologicalscience.org/ob...
  • predlagalo izbris: orcinus ()
Smurf je izjavil:
Samael je izjavil:
Gajec je izjavil:
Da, seveda.
Plus to, da je trenutno med popularnejšimi slovenskimi športniki (če ne celo najpopularnejši, pa ne le med športniki) pisanje o njem prinaša klike na spletne strani. Zaradi njega sedaj NBA spremljajo ljudje, ki prej za košarko še slišali niso.
13 / 26
NBA sezona 2021-2022 (strani: 1 2 3 4 … 52 53 54 55 )
Oddelek: Šport
2733365966 (159599) mersault
