Forum » Informacijska varnost » WikiLeaks Vault 7 in Cisco
jukoz ::
No, pa se je začelo:
https://arstechnica.com/security/2017/0...
"Cisco Systems said that more than 300 models of switches it sells contain a critical vulnerability that allows the CIA to use a simple command to remotely execute malicious code that takes full control of the devices. There currently is no fix."
Cisco Advisory:
https://tools.cisco.com/security/center...
Cisco Advisory:
čuhalev ::
Mislim, da se je o tem šušljalo že deset let nazaj.
Čudno se mi zdi, da te CMP storitve ni mogoče izklopiti.
aleksander10 ::
CMP teče samo če imaš vključeno naslednje:
Cisco devices running a vulnerable Cisco IOS XE release are affected by this vulnerability when the following conditions are met:
- The CMP subsystem is present on the Cisco IOS XE software image running on the device, and
- The device is configured to accept incoming Telnet connections
Aleksander
"A friend is someone who gives you total freedom to be yourself. (J.M.)"
jukoz ::
Update:
"Cisco has released free software updates that address the vulnerability described in this advisory."
| » | Cisco odkril ranljivosti v svoji opremi na podlagi Vault 7Oddelek: Novice / Varnost | 6240 (4745) | brodul |
| » | Odkrita zlonamerna koda v usmerjevalnikih (strani: 1 2 )Oddelek: Novice / Varnost | 50230 (32262) | AC_DC |
| » | Cisco SOHO91-konfiguracijaOddelek: Omrežja in internet | 2526 (2134) | ponky |
| » | Cisco router import konfiguracije.Oddelek: Strojna oprema | 2030 (1955) | Mr.B |
| » | Linux varnostne luknjeOddelek: Operacijski sistemi | 3344 (3097) | BigWhale |
