Forum » Programiranje » napaka v c++
napaka v c++
kretze ::
zdravo folk malo se obračam na vas ker mi compailer javi to napako(Error1 error C3861: 'ordered': identifier not found) in nevem kaj je narobe
class person
protected:
string name;
public:
void setName()
cout << "enter name "<<endl;
cin >> name;
void putname()
cout << "\nName is " << name;
string getname()
return name;
void Bsort(person **pp, int n)
for (int i = 0; i < n - 1;i++)
for (int j = i + 1; j < n; j++)
ordered(pp + i, pp + j);
void ordered(person **pp1, person **pp2)
if ((*pp1)->getname() > (*pp2)->getname())
person*temptr = *pp1;
*pp1 = *pp2;
*pp2 = temptr;
int main()
person *ptrper[100];
int n = 0;
char choice;
do
ptrper[n] = new person;
ptrper[n]->setName();
n++;
cout << "enter another [y/n] ";
cin >> choice;
} while (choice == 'y');
cout << "\nUsorted list ";
for (int i = 0; i < n; i++)
ptrper[i]->putname();
Bsort(ptrper, n);
cout << "\nsorted list";
cout << endl;
smacker ::
V vrstici 27 kličeš funkcijo ordered, ki je compiler še ne pozna, ker še ni prišel do vrstice 35, kjer jo definiraš
Lahko pa rešiš tako, da na vrhu deklariraš funkcijo (poveš da obstaja), spodaj pa jo definiraš(napišeš kodo ki se izvaja v funkciji).
Tutorial: http://www.cplusplus.com/doc/tutorial/f...
Glej odsek "Declaring functions" čisto spodaj.
- spremenil: smacker ()
kretze ::
hej ena vprašanje še mama kak bi naredil to funkcijo buble sort da bi delovala??
void buble_sort(person **pp, int n)
person* temp;
for (int i = 0; i < n - 1; i++)
if ((*pp + i)->getname()>(*pp + j)->getname())
temp = *(pp + i);
*(pp + i) = *(pp + j);
*(pp + j) = temp;
kretze ::
error: Unhandled exception at 0x7551C54F in OOPI25(1) person pointer,buble sort.exe: Microsoft C++ exception: std::bad_alloc at memory location 0x0039E9D0.
class person
private:
string name;
public:
void setname()
cout << "\nEnter name ";
cin >> name;
void printname()
cout << "name is " << name << endl;
string getname()
return name;
person* temp;
temp = *(pp + i);
*(pp + j) = temp;
int main()
person *per[10];
char choice;
int n = 0;
do
per[n]->setname();
n++;
cin >> choice;
cout << "\nUnsorted list ";
per[i]->printname();
buble_sort(per, n);
cout << "\nsorted list ";
mijav7 ::
person* temp;
if (pp[i]->getname()>pp[j]->getname())
temp = pp[i];
pp[i] = pp[j];
pp[j] = temp;
} Uranij ::
Problem je v if stavku, metode bubble sort. Problem je, da
nista enaki zadevi.
Poskusi na praktičnem primeru ugotoviti razliko.
*pp + iin
*(pp + i)
nista enaki zadevi.
mojca ::
Predlagam uporabo smart pointerjev iz standarda C++11.
Zgornji program ima sicer memory leak. Kar inicializiraš z new, moraš tudi pobrisati, razen če prepustiš programskemu jeziku, da to naredi zate, in 'new' sploh nikjer ne uporabiš.
marjan_h ::
Eno vprašanje, ali je pomnilniški naslov ki ga dobiš v C/C++
&spr, fizični ali virtualni?
Randomness ::
čuhalev ::
Tam živiš v realnem načinu in takrat procesor izvaja le en program, ki nima omejitev (razen širine vodila) pomnilnika. Tam je edini naslov absoluten, skratka fizičen.
Pozabil si segmente.
čuhalev ::
To je zgodovina omejitev, ki prinese še omejitev na pomilnik. Malo manj kot 1 MB. To, kar bi potreboval je flat mode, vendar s tem nimam izkušenj.
| » | Java skeniranje map in podmapOddelek: Programiranje | 1634 (1523) | nightrage |
| » | c++ enumOddelek: Programiranje | 1535 (1369) | Bistri007 |
| » | [C++] Insertion sort - problemOddelek: Programiranje | 1404 (1243) | Thomas |
| » | Pomoč z C++ nalogoOddelek: Programiranje | 1865 (1672) | denis123 |
| » | vprasanje c++Oddelek: Programiranje | 2800 (2799) | Volk| |
