Spectrum24ethernet access point
gregc1 ::
Od kolega sem dobil Spectrum24ethernet access pint. In nimam pojma kako se povezati oz. spraviti v pogon. Zadeva je stara okoli 15-20 let. Na internetu ne najdem nobenih pametnih navodil. Je pa type LA302C or LA302D. Je pa zadeva iz Lek-a. Mogoče kašen stručko iz leka ki bo kaj več znal povedati o tem....
Modem je tocno taki kot ta na linku... http://www.ebay.co.uk/itm/Symbol-AP-302...
  • spremenil: bluefish ()
konspirator ::
To je wifi acces point (range extender), ki ga priklopiš preko utp kabla iz routerja.
https://www.cnet.com/products/symbol-sp...
http://cybarcode.com/symbol/wireless/ac...
Zadeva je stara vsaj 17 let
https://fccid.io/CMII-ID-2000AJ0288
Reset to default:
http://www.fixya.com/support/t501872-re...
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Če vpišeš v google "Spectrum24 AP", je prvi link
http://documentation.extremenetworks.co...
Na extremenetworks.com 3021 ap ne najdem, večtno gre za preveč staro zadevo.
Moj nasvet: pozabi na to starino in raje kupi nov wifi AP, če ga potrebuješ.
gregc1 ::
OK. Samo kako pa pridem do menija? do nasavitev? preko routerja ne gre. Mislim da ima com port, vendar ga pa nimam na nobenmu računalniku. ?
konspirator ::
Ga router sploh zazna ?
gregc1 ::
se mi zdi da ne. kje tocno se pa to vidi? Drugače samo za info pra lučka itrupa rdeče. se mi zdi da to ni uredu :)
Arduino in luči (strani: 1 2 )
9814787 (12413) FX6300B
Windows XP Black screen
124823 (4563) Twix
Win 7 blue screen in restart
Oddelek: Operacijski sistemi
132927 (2666) Duhec
računalnik se ne boota
81627 (1526) IvoJan
BSOD pri Remote Desktopu v Win 2003 Server R2 Enterprise SP2
212358 (2185) ender
