Forum » Strojna oprema » AMD Vega GPU
AMD Vega GPU
![](https://static.slo-tech.com/stili/bel_non_grata.png)
Predator X ::
D3m0r4l1z3d je izjavil:
Geforce Stock Power Limit: 100%
Geforce AIB Power Limit: 150%
VEGA Power Limit: 200%![]()
Strix ma identicen cooler kot GTX 1080TI. Tako, da ne pretiravajte.
- predlagal izbris: SuperVeloce ()
![](https://static.slo-tech.com/stili/avatar_gray.gif)
D3m0r4l1z3d ::
D3m0r4l1z3d ::
Tolk so power efficient, da gredo čist v eko, preimenovali se bodo v Endivia, zeleno že itak imajo trademark, Geforce Živa, skupaj z lončkom in zemljo.
Predator X je izjavil:
http://greentechreviews.ru/2017/09/18/o...
omg
So dobili popravljen BIOS od Asus-a?
|HP EliteBook|R5 6650U|
m0LN4r ::
Vega si vec k 1080 cooler ne zasluzi, tudi z 1080ti coolerjem je glasnejsa/toplejsa od obeh
https://ref.trade.re/38mvdvxm
Trade Republic 38MVDVXM
Predator X ::
hbm je vroc.
Predator X ::
A je kdo kej opisal IF na VEGI? Kaksen je clock?
- spremenilo: Predator X ()
D3m0r4l1z3d ::
https://www.techpowerup.com/237156/cust...
Custom bodo do srede oktobra.
Pennywis3 ::
Glede na to, da so pogruntali, da Vega rudari Monero kot pri norcih, bo kartice zelo težko dobiti pred minerji
![:))](https://static.slo-tech.com/smeski/icon_lol.gif)
D3m0r4l1z3d ::
AMD initially wanted to supply GPUs to the partners by September 11th for the custom cards. Currently it seems this delivery date was missed and delayed by an unknown timeframe. The board partners are confused because they have no further information on how to proceed. This means shop availability of Vega 64 in a custom design will not see the light of day anytime sooner than Late October, maybe even November.
Takrat bo tudi 1070Ti
Manufacturer A: The custom models for the Radeon RX Vega 64 and Vega 56 are ready to market. However they waiting for AMD's GPUs. Radeon-RX-Vega-56 might be delayed indefinitely.
Manufacturer B: AMD's product planning involved first placing the reference models on the market. However, availability is a major concern also cuasing a the delay of custom models. They can not specify an appointment or time period when you can expect your own designs.
Manufacturer C: According to the manufacturer the release and final specification specification of AMD is missing. GPUs should not be delivered yet, assuming that there will be no products before mid-October. They did not want to comment on the development of your custom cards.
Manufacturer D: Also a delay in the delivery of GPUs. To the actual state of the development of one's own custom cards, they did not want to express themselves.
Buggy ::
...kakorkoli, jaz sem se ze mocno nacakal Vege in trenutno vzel 1080TI, ki bo nadomestila R9 290, ki se je ponovno iz gaming kartice spremenil v mining
Spock83 ::
Pennywis3 ::
...kakorkoli, jaz sem se ze mocno nacakal Vege in trenutno vzel 1080TI, ki bo nadomestila R9 290, ki se je ponovno iz gaming kartice spremenil v mining![]()
Glej, da boš orenk downvoltal tega požeruha :)
Glede na to, da so pogruntali, da Vega rudari Monero kot pri norcih, bo kartice zelo težko dobiti pred minerji![]()
Nice. Bo treba nabavit vsaj een 6 kosov. :D
Ja ne, ene par Vega rigov bomo pa naredil
- spremenil: Pennywis3 ()
Predator X ::
Noro ja.
Buggy ::
Pennywis3 :: danes, 10:48:17
citiraj
Buggy je danes ob 10:33:06 izjavil:
...kakorkoli, jaz sem se ze mocno nacakal Vege in trenutno vzel 1080TI, ki bo nadomestila R9 290, ki se je ponovno iz gaming kartice spremenil v mining :))
to pa vsekakor...osnovna higiena vsakega rudarja :)
Pri DaggerHashimoto 100% utilizaciji, prebrano iz GPUZ (sensors) je default poraba bila 210W oz 17A VDDC. Po "optimizaciji"...Power limit na -21, GPU voltaza na -37mV ter AUX voltaza na -12 je padlo na 10A in 120W, dela pa zadovoljivih 28MHs.
Temperature max 73 vent na 53%, VRM-ji 70 stopinj, GPU dovnclockam na 900Mhz.
Sej ko 1080Ti ne bo gaming utilizirana bo tudi mogla kaj od sebe dati, sam tam bo bolj na ziher Nicehash padu....drugo leto pa upam se kaksno ugodno Vego refresh posvojim :)
BTW: ce koga zanima Gigabyte WF3 GTX780OC na ZS
- spremenil: Buggy ()
m0LN4r ::
citiraj
Z 1080ti minaj VTC je lihkar narasel z danes na jutri za 60%
mihco ::
citiraj
tudi z nicehash-om bo rudaril Lyra2REv2 in zasluzil priblizno enako. Celo boljse je PO pumpu nekega coina rudarit na nicehashu, ker je instantno pretvorjeno v btc, medtem ko direktno shitcoin obicajno pade na vrednosti dokler narudaris, preneses na borzo,...
Jst ::
Pa kaj se Vege sploh ne more dobiti? Tudi če piše, da je še recimo 69 kosov, in že plačam, dobim na mail čez par ur standardno sporočilo, da mi vračajo denar, ker izdelka nimajo na zalogi.
Kaj je Vega na zalogi samo "virtualno"? Ali kako bi se izrazil....
Zaloge je kolikor hočeš, le cene so smešne, zato "nihče" ne kupi teh jajc.
Kje si naročil oz. poskušal naročit?
- spremenil: DarwiN ()
Noch 100 Stück verfügbar. Kartic kot šalate. Take a pick. ;)
m0LN4r ::
Izza vasih narocil so se rezervacije
Custom AMD Vega Boards Reportedly Delayed By Technical Issues
XFX and Sapphire have cards in the works, but no firm release date. PowerColor has a design but has yet to receive the DRAM it needs. Asus has pushed back the launch date on its own cards, Gigabyte hasn’t firmly committed, and MSI is apparently skipping the party altogether.
- First, the quality of AMD’s Vega GPUs has been variable enough that OEMs don’t feel comfortable establishing an overclock frequency they can guarantee and ship.
- Second, there have been temperature reporting discrepancies between what the board reports and what AIBs are measuring.
- Finally, there are mounting differences that’s making it difficult to mass produce Vega. Unlike previous GPUs, not every Vega card uses the same mounting. There are three variants of Vega in-market: One with HBM that’s the same height as the GPU, one with HBM that’s 40 micrometers lower than the GPU and apparently a third variant with Hynix memory.
Zdaj vemo, zakaj je šel Raja na "dopust".![8-O](https://static.slo-tech.com/smeski/icon_eek.gif)
D3m0r4l1z3d ::
še mal pa lahk kr na navi počakamo![]()
Zelo pomenljivo
D3m0r4l1z3d ::
Ne, le Blowerje je treba delat naprej.
Predator X ::
Pa sej niso resni?!!!
Lahko kr zaprejo GPU oddelek, res![]()
To bi lahkatud nvidia naredila glede na vse njihove velike faile.
Lahka sespomnimo vista faila, killer driver etc.
Čeprav so bile GTX 8800 odlične kartice, so crkovale po letu ali dveh brez razlogov.
Če AMD ukine GPU division bo večino no-liferjev pobral v letu ali dveh, sej se sploh nič pametnega ne dogaja po forumih, bo pa take stvari.
Grey ::
Ne razumem.. Če ciljaš na vire, očitno ni bil potreben, saj ga plenilec tudi ni navedel glede crkovanja 8800. Zanimivo, da potemtakem nisi Predatorja označil za Kristusa.
Sicer pa ima vsak dostop do Googla.. Naj ti pomagam.
A to mislite crkovanje G80 v Apple produktih. ![:P](https://static.slo-tech.com/smeski/icon_razz.gif)
In ostalih prenosnikih.
Tisto je bil šele LOL.
- spremenil: D3m ()
D3m0r4l1z3d ::
Bil.
D3m0r4l1z3d ::
Bil kot bilo, preteklik, zaključena zadeva. Me pa še vedno zanima koliko je bilo procentualno crknjenih ravno iz Apple prenosnikov?
Grey ::
Ja, ciljal sem na supportive text. Grafe lahko nalima vsak. In brez obrazložitve, kaj človek gleda in kako so bili podatki obdelani, si lahko vsak razlaga nekaj po svoje kot pri tisti sliki, ki sem ti jo nalimal. Vedno, ko prikazuješ neke podatke, je pomembno napisati zraven kako si meril, kaj si meril in kakšen vzorec si imel.
Navajajo, da so to gledali izključno na ASUS karticah, ker te vgrajujejo v svoje sisteme. To je navedeno v njihovem tekstu. Tako, da je to bolj kot karkoli drugega, failure rate ASUS kartic.
We've received some questions about what brands and models of card we used. We primarily use Asus DirectCU cards whenever possible, and the basic Asus models when there are not DirectCU versions available. It is possible that the high failure rates are limited to Asus cards, but we have used Asus as our primary supplier for video cards for a long time now.
This includes NVIDIA cards as well as the Radeon HD 7xxx and Radeon HD 6xxx cards which have a much lower failure rate than the Radeon R7/R9 cards. This is a clear indication to us that Asus is not the problem, but rather something fundamental to the R7/R9 cards themselves.
Tole je čisto skakanje do zaključkov. Če bi testirali še druge izdelovalce, bi to lahko bil valid zaključek. Tako so pa s širokim čopičem obarvali R9 serijo kot nezanesljivo. Taki, znanstveno nepodprti, javni zaključki in sploh, če jih izdajajo taka, "priznana" podjetja, kot so tile kerlci, delajo hudo finančno škodo AMDju.
Lepo sovpada tudi s Q2 pričetkom razmikanja v tržnem deležu. Negativni marketing (naklepni ali nenaklepni) je zelo škodljiva stvar.
Link
Pišejo tudi, da so delali torture test na njih - Furmark.
Če je velik del teh procentov povzročil šele Furmark (zaradi mogoče slabega hlajenja ali odpovedi kake druge komponente na PCBju) - don't f*cking use it.
- spremenilo: Grey ()
Praktično vsa objavljena statistika v zadnjem desetletju se ujema v prid Nvidije.. Sej je menda tudi logično. AMD so šalabajzerji, ki sekajo ovinke, višji TDP v zadnjih letih pa tudi doda svoje.
Evo ti še en link iz hardware.fr. 2x višji failure rate. Vse po pričakovanjih. Kdor išče kakovost, kupi Nvidio. /heads explode
Še ena druga raziskava, ravno tako zajete vse različne znamke.
Averages:
Nvidia: 2.715%
AMD: 5.746%
Grey ::
Averages:
Nvidia: 2.715%
AMD: 5.746%
Super, še več podatkov. In kaj vidimo? Nič posebnega. Še vedno je več kot 95% kartic v redu direkt iz tovarne. Nekaj škart robe se povsod najde.
Inno3D GTX980Ti so pa kaj? Blizu 10% returned? Že to kaže, da so ti podatki čisto brezveze, ker ti ne povedo nič.
10,34% Sapphire R9 290 4G GDDR5 Tri-X OC (New Edition)
9,80% Inno3D iChill GTX 980 Ti X3 Air Boss Ultra
8,85% Inno3D iChill GTX 980 Ti Black Series
7,59% Sapphire R9 290 4G Vapor-X
6,47% Gigabyte GV-N970IXOC-4GD
7,96% Sapphire Radeon R9 290 Vapor-X OC
6,01% MSI Radeon R9 290 GAMING
5,79% Sapphire Radeon R9 290 Tri-X OC
5,45% MSI Radeon R9 290X GAMING
5,17% Sapphire Radeon R9 290X
Razlika je zanemarljiva med obema vendorjema. Oba imasta približno enak return rate - odvisno od modela do modela in od batcha do batcha.
Sploh za AMD manjka varianca pri tej francoski strani. Kje so MSI? Gigabyte? Asus?
Tako, da sprenevedanje o neki kvaliteti je tu povsem odveč in preprosta brand izmišljotina. Pač še ena zelo izkrivljena stvar (kot dosti ostalih), ki ustvarjajo nek halo effect superiorne kvalitete s strani nVidie.
Why even bother.
Over and out!
Over and out!
D3m0r4l1z3d ::
Grey, preveč te boli.
Grey ::
Tako je. Glava me boli od teh zelenih mass manipulacij.
D3m0r4l1z3d ::
Eh, dve firmi imaš, enkrat gre eni slabše, enkrat drugi, odvisno sicer kateri dlje časa. Lahko nehaš, ker enkrat bo nvidiji šlo slabše, če že to toliko čakaš.
D3m0r4l1z3d ::
AMD Might Replace RX 500 Cards with RX Vega 28 and 32
http://www.guru3d.com/news-story/amd-mi...
Edino problem je, ker novica omenja HBM2 na teh grafah, kar ni logično oziroma bi dobesedno kanibalizirali rx 580 in cenovno sploh nebi dohajali, ker je to 1060 teritorij, že pod 300 eur.
- spremenilo: D3m0r4l1z3d ()
D3m0r4l1z3d ::
CrossFire ne bo več brandirano, zdaj je mGPU, ker dx12 prelaga na developerje.
Bodo počasi morali še svoje napajalce prodajat, brand bo mPSU.
m0LN4r ::
Magicne SSDje pa Rame ze majo. Konco bo lahko cel PC rdec
- spremenil: m0LN4r ()
