AMD Vega GPU
AMD Vega GPU
chucki ::
Ka zdej? Tak hype pa 4 dni sem gledal odštevanje... Zdaj pa nič? :D
neo5468 ::
http://www.anandtech.com/show/11002/the...
First and foremost, today's detail release is a teaser, not a deep dive, or even a preview. AMD is only releasing a few details about Vega, and those are being kept at a high level. In fact it's fair to say that there's just enough information to answer little and raise even more questions; just what a proper teaser should be.
Why? Well part of the reason is that we're still months off from the launch of Vega. I believe it's fair to say that by announcing a first-half of the year launch date when we're already in 2017 is a strong indicator that Vega will not launch until later in that window, likely some time in Q2. So we're still a good three to five months out from the launch of Vega, which means AMD doesn't want to (or need to) release too many details this far out. Rather they can trickle out chosen details for maximum impact.
Upam da ni z zen procesorjom isto.
D3m0r4l1z3d ::
Za voljo čim bolj realistične grafike, bi morala ena dobro stoječa firma kupiti RTG od AMD in naj se pri AMD samo CPUjem posvetijo, ker Ryzen bo vsaj zunaj kmalu, kot so obljubili. Na temeljih Vege pa bi druga firma sigurno uspela ustvariti Geforce killerja.
Po pravici povedano, če top Vega s hbm2 ne bo ogrožala Volte, je žalost, ker Pascal je le shrink Maxwella in res že konec poti, če lahko sklepamo, da bo Volta na novo ustvarjena kot Vega, sicer pa pri slednji GCN malo pokvari zabavo.
D3m0r4l1z3d ::
chucki je izjavil:
Zdaj je nekaj več, pod RX razdelkom si oglej video, striček na koncu reče High end gaming will never be the same.
H1 je precej bedno, da tako raztegujejo, ko bi vsaj q1 ali q2 pisalo, zdaj ko smo že v 2017. Mogoče pa za nalašč tako, da bo presenečenje marca recimo.
Grey ::
Hmm...
Ultra, 4k resolucija in pljuva ven 70 fps v Doom z Vulkanom. V Star Wars Battlefront pa na Ultra, 4k resolucija v paru z Ryzen maxed out 60 Hz rock solid (niti pade ne za malo fps). Zadeva ne bo poceni...definitivno se bodo prodajale med 400 in 500EUR...cca okoli 2x RX480. Not bad, not bad at all.
Link
  • spremenilo: Grey ()
D3m0r4l1z3d ::
Sigurno ne bo med 400 in 500eur, tukaj si se zelo zmotil. Hitrejše od 1080 ne bo za ceno 107o, vsaj prvo leto ne.
Grey ::
D3m0r4l1z3d je izjavil:
Bi rekel, da bodo, ker jih drugače ne bodo kaj veliko prodali glede na to da v novejših DX12/Vulkan igrah dela Crossfire odlično. Se ti bo bolj splačalo, da kupiš dve RX470 ali pa RX480, ker performančno ne boš veliko zaostajal.
D3m0r4l1z3d ::
Fury x verjetno zaradi tega niso veliko prodali, ampak pod 600eur si upam trditi, da kar lep čas ne bodo, glede na to, da je hbm2, na novo razvita,...
D3m0r4l1z3d ::
Grey je izjavil:
Hmm...
Link
Če bi bil top Vega čip počasnejši od 1080, potem je konec z radeonkami.
Mi je dalo mislit, ko sem prebral na tujem forumu skrb o tem, da je gcn dozorel, zdaj pa so vse spremenili, vendar avtor očitno ni prebral, da gcn ostaja.
D3m, kako je zdaj s Hat-trickom?
next3steps ::
AapocalypseE je izjavil:
iloveboobz je izjavil:
jst pa finewine tech 280x... bo dobro spet za neki casa v kombinaciji z peasentstation ;)
Kako to, da si 280X nabavil?
Prej si mel 7950, tako da ni neke razlike.
Nabaviš PS4 Pro, naložiš Linux, furaš Steam.
Profit!
dottor ::
Čim bo AMD izdal top Vego ima pomoje nVidia že pakirane 1080Ti :P
D3m0r4l1z3d ::
1 leto starejši čip, samo gddr5x pa da bo top Vego (nov dizajn, hbm2, gaming will never be the same) poscal, no way!
D3m0r4l1z3d ::
https://www.techpowerup.com/229322/this...
Doom video na i7 4790k procu, v 25 sekundi pade iz 67 na 37 fps in je tudi vidno med premikanjem. Verjetno morajo Doom, Vulkan in Crimsona še porihtat.
damirez ::
Zdej čisto kmečki izračun.
RX 480 8gb 6gflops = R9 380x 4gflops = cenovni razred 50% powerja več je sedaj.
R9 Fury X = 8,6gflops to je več kot 2x več od mainstream r9 380x
Če bo Vega več kot 2x več od mainstreama (rx 480) je to nekako 13gflops. Ali pa če bo 50% powerja več kot prejšnja generacija(fury X) = cca 13gflops
AMD 13GFLOPS = NVIDIA 10GFLOPS po trenutnih zadevah, vačsih je bila še večja razlika, sedaj je nekako fury X = 980 ti, pač odvisno od igre, ampak pri novejših je nekako tako par odstokov gore dole.
Titan X = 11gflops
GTX 1080 = 9 GFLOPS
Se pravi po skrajno kmečemu damirez izračunu, bi bila Vega lahko malce počasnejša od Titan X in malce hitrejša od GTX 1080.
Če pa bo izkoistek večji, tako kot napovedujejo, je pa lahko top Vega celo hitrejša od Titan X.
Še enkrat, preden se kdorkoli vtakne to so samo Damirez špekulacije.
D3m0r4l1z3d ::
"lahko malce počasnejša od Titan X in malce hitrejša od GTX 1080"
Tole kar si napisal, tudi po disclaimerju o damirez čist kmečkem izračunu, ni logično za večino iger.
Q1 2017 Anymal. Samo še to me lahko reši.
D3m0r4l1z3d ::
 za damirez kmečki izračun
D3m je izjavil:
Saj lahko, da pohitijo, vendar da je še vedno le H1 v PR materialu, verjetno pomeni, da bo maja, junija, če sploh
next3steps je izjavil:
Profit!
Ko je zvedel, da so 280x ukinili async, je nabavil, da bo kot če bi imel geforca :|
Če bo maj-junij to hell with them.
hahahaha, made my day :D
damirez ::
@anymal
Pa sej če je 10% hitrejša od GTX 1080 in 10% počasnejša od Titan X je to to? Ali, kaj sem narobe napisal?
D3m0r4l1z3d ::
Jah, H1 je zelo mlačna napoved, najava ali karkoli že zdaj ta preview pomeni, ponavadi vsaj po četrtletjih ločijo.
damirez je izjavil:
@anymal
Mislim, da bi bilo boljše napisano z ALI, malce hitrejša ali malce počasnejša
Titan x je v povprečju za petino hitrejša od 1080, je pa res da se ji custom varijante kar približajo in tako bo kar držalo kar si napisal, bo kar kmečka razlaga zmagala.
D3m0r4l1z3d ::
Le kaj hočejo zdaj, a je bilo 8gb vrama brez veze na 390 in 480?
Ne. Gre se za to, da se počasi menja GDDR.
Predator X ::
Če se 530mm^2 chip drži oziroma je komaj hitrejši od GTX 1080 potem bo fail. Res pride samo en CHIP vege al pridejo RX 570/580/90
Grey ::
Mislim, da bo nekje v rangu 60%-75% Titan XP SLI. Namreč na 4k Ultra doseže Titan XP v SLI načinu okoli 120 fps. Vega pa doseže gladek lock na 60 fps na 4k Ultra. Če postavijo ceno nekje vmes med 1070 in 1080 bo bomba.
Predator X ::
Z takim die sizom bi pričakoval, da bo hitrejši od TITAN XP za 15%
Ahim ::
Predator X je izjavil:
Koliko hitrejsi od GTX 1080 je edini NVidiin produkt s HBM2, GP100? (610 mm^2 die size)
Predator X ::
Ahim je izjavil:
HBM ti da prednosti kjer je Memory bottleneck, enako velja za proce. Če misliš, da boš dobil z hitrejšim DDR4 boljši perf v CB15 ...
Ahim ::
Ahim je izjavil:
Ti si pisaril debilizme o korelaciji die size in hitrosti/uspesnosti.
Torej odgovori: koliko hitrejsi je GP100 (610 mm^2) od GP102?
Senitel ::
Simpl. GP100 je 16x hitrejši od GP102. Če se ti jebe za razloge za ta dva čipa potem je ta odgovor čisto legit.
Predator X ::
Ahim je izjavil:
Ahim je izjavil:
Jst sm govoril o AMD.
232mm^2 rx 480.
530mm^2 vega hbm.
Bi nekak pricakoval x2.5 perft ratio. Odvisn od taska.
Ahim ::
232mm^2 rx 480.
530mm^2 vega hbm.
Ti si napisal sledece:
"Če se 530mm^2 chip drži oziroma je komaj hitrejši od GTX 1080 potem bo fail."
in
"Z takim die sizom bi pričakoval, da bo hitrejši od TITAN XP za 15%"
Nobenega govora o RX480 (do zdaj).
Čip bo hitrejši od GTX 1080 in bo konkurenca Titan XP.
te držimo za besedo :)
GenZNPC ::
AMD Vega, "Today's performance, next year!"
8-)
skibidi
@hojnik
Prav.
  • spremenil: D3m ()
Joze_K ::
Hm, na žalost se mi je ustvarila slika, da bo tale VEGA zadeva precej medla,... pa sklepam samo po prispevkih komentatorjev... ko je bilo pričakovanje in smo odštevali minute je bilo komentarjev ogromno,... zdaj ko je pa Vega predstavljena je pa enostavno mrtvilo, nobenega entuziazma več (in tudi po ostalih straneh je vse bolj mlačno)... škoda, pa sem tudi jaz gojil upanje :(
Mrtvilo predvsem zato, ker je AMD zgolj vrgel kost za glodanje v obliki nekega teaserja, kar daje slutiti, da je vega še zelo daleč od izzida.. Nebi se čudil, če bomo čakali do junija, in potem avgusta na dejansko zalogo. :S
GenZNPC ::
Jah sej kaj pa je blo lani pred Fury, vecinoma megla. Po izidu pa tudi.
skibidi
DarwiN je izjavil:
Prehuda, ker potlej je pa že Navi najavljen.
Napajalc ::
Joze_K je izjavil:
2 AMD veliki temi sta bile zaklenjeni, kot kaže so nvidijaši le dojel da je dx12 neizbežen in da je prektično skoraj vsak nVidia GPU vključno s kaplerjam navzgor velik fail.
011011100111010101100010
D3m0r4l1z3d ::
DarwiN je izjavil:
Vsaj, da bi včeraj dali datum izida ali pa vsaj kateri quater, tako da q1 je malo verjetno, q2 pa je lahko res junija, umiritev cen in zaloga septembra
Napajalc je izjavil:
Joze_K je izjavil:
Ko dokažeš, da Rise of Tomb Rider in Gears of War 4 nista dx12, potem se bomo naprej pogovarjali.
Predator X ::
28nm Fury X ~ 600mm^2
4096SP, 1050MHz core clock, HBM1 4GB = 8.6TFLOPs
14nm VEGA ~ 530mm^2
~ 4096SP, ~1550MHz core clock, HBM2 16GB
Zgleda, da je manj shaderjev/die, glede nato da 14nm nekak odbije 50% placa. Vrjetn bi 14nm Fury X čip velik okol 300mm^2.
Vega 20 menda proti koncu 2018.
Predator X ::
Še brca Fury X
Če sta opazil ma zdej uporablja podoben tech oziroma enako finto.
Tile-based immediate-mode rasterizer
https://www.extremetech.com/gaming/2327...
to bo zdej tud v vegi.
GenZNPC ::
 Nevem zka bi se ubadal z DX12 v tej igri
 Ce pa DX11 dela enostavno boljse na vseh GPUjih
skibidi
  • spremenil: GenZNPC ()
Predator X ::
GenZNPC je izjavil:
Nope. Tale mož očitno res navija za nvidijo. SP dela lepo na DX12 + FPS boost.
Pa on je eden redkih, ki kaže da je Fury X 15-20% počasnejša od GTX 1070.
GenZNPC ::
Tja lej, pokazi side by side tko lepo kot on, kar si izjavil na nekem legit linku.
Bi to podkrepil z necim?
skibidi
Predator X ::
Jap glej ostale benchmarke.
Pokaži guru3d, techspot, itd... pa premisl.
GenZNPC ::
Pokazi ti nam, DX12 vs. DX11 grafek z AIB Graficnami.
skibidi
7 / 138
