BSOD pri igrah vedno z istim porocilom o napaki 1000008e
Yeznick ::
Torej recimo ko igram Morrowind, v pol ure sigurno dobim tale BSOD.
Stvari se mi ne pregrevajo, ker je vse dobro hlajeno. Vidim da je problem v driverju za graficno: nv4_disp.dll. Probal se vse nvidia driverje, Omega driverje in isto. Graficna je brezhibna sigurno.
Overclockano ni nic. Se RAM sem underclockal na 100 Mhz (SDRAM 256 MB)
V bistvu sem vse skupaj sprobal se z underclockanjem procesorja in vsega mogocega.
Kaj za vraga se dogaja?
Bodite pozorni na vrstico spodaj, kjer pise:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced
memory at "0x%08lx". The memory could not be "%s".
Zgleda kot da je probal za naslavljanje RAMa podati STRING 8-O . Smesno....
Graficna je Gainward Geforce 4 MX440
Windows XP SP1
Via 4-in-1 Hyperion
ABIT KT7E
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
An exception code of 0x80000002 (STATUS_DATATYPE_MISALIGNMENT) indicates
that an unaligned data reference was encountered. The trap frame will
supply additional information.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: bfaa21ca, The address that the exception occurred at
Arg3: f3370b98, Trap Frame
Arg4: 00000000
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
nv4_disp+e71ca
bfaa21ca 8b4804 mov ecx,[eax+0x4]
TRAP_FRAME: f3370b98 -- (.trap fffffffff3370b98)
ErrCode = 00000000
eax=00000000 ebx=f3370d04 ecx=e31731a4 edx=e3173040 esi=e3173080 edi=e31731a4
eip=bfaa21ca esp=f3370c0c ebp=e1873800 iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010282
nv4_disp+e71ca:
bfaa21ca 8b4804 mov ecx,[eax+0x4] ds:0023:00000004=????????
Resetting default context
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x8E
LAST_CONTROL_TRANSFER: from 00000000 to bfaa21ca
STACK_TEXT:
e1873800 00000000 00000000 00000000 00000000 nv4_disp+0xe71ca
FOLLOWUP_IP:
nv4_disp+e71ca
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: nv4_disp+e71ca
MODULE_NAME: nv4_disp
IMAGE_NAME: nv4_disp.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 3e1248ee
STACK_COMMAND: .trap fffffffff3370b98 ; kb
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
Yeznick
BSOD problem
92242 (1900) Oktan
Windows XP Black screen
124790 (4530) Twix
Bluescreen
102422 (2124) slickerSLO
BSOD pri Remote Desktopu v Win 2003 Server R2 Enterprise SP2
212344 (2171) ender
infinite loop ???
51414 (1280) AngelOfDeath
